Misko Član
Pridružen-a: Ned 16 Apr 2006 15:15 Prispevkov: 549 Aktiv.: 2.50 Kraj: MS
Jule Član
Pridružen-a: Sob 27 Okt 2007 12:48 Prispevkov: 2533 Aktiv.: 12.61 Kraj: Ajdovščina
Objavljeno: Čet Jul 17, 2008 3:32 pm Naslov sporočila: |
Saj ej kot Ray Charles!
_________________ lp Jure |
aly Član
Pridružen-a: Tor 28 Sep 2004 14:51 Prispevkov: 9407 Aktiv.: 42.19 Kraj: Kranj - struževo
Objavljeno: Pet Jul 18, 2008 11:09 am Naslov sporočila: |
Datasheet Write Only Memory
Opis, zakaj je to nastalo:
The origin of the WOM - the "Write Only Memory"
An engineer at Signetics, frustrated by the long and useless sequence of approvals for data sheets (during which no actual checking occurred), once made up a spec for a "Write Only Memory" (a "WOM") and sent it along with a batch of other data sheets to be approved. After all, if you are selling "Read Only Memories", why not have a "Write Only Memory"? It's perfectly logical - - which is why the managers saw nothing wrong with the data sheet.
The WOM data sheet went through the approval chain, just fine, and wound up in Signetics' new products catalog. This came to the attention of the managers at Signetics, only after customers began asking for price and delivery. Signetics shortly printed up new "corrected" databooks, without any WOMs, and asked for the "erroneous" ones to be returned. But customers soon got word of why they asked for returns, and hid them properly.
About 1974, Signetics bought a two-page, full-color spread in the April issue of ELECTRONICS Magazine, and published the WOM data sheet, as a (rather expensive) April Fool's Joke. This version of the WOM data sheet shows the various features of Signetics' Model 25120 "fully-encoded, 9046 x N Random Access, Write Only Memory". This advertisement has been saved, and greatly prized by engineers, for many years.
At many companies, managers are accused of not having any sense of humor. But in this case, the Signetics guys did it right! Even if it did cost them a lot of money!!
Ime datoteke: |
Write Only Memory Datasheet.pdf |
2.34 MB |
Downloadano: |
181 krat |
_________________ I'm going to stand outside, so if anyone asks, I'm outstanding
Nazadnje urejal/a aly Tor Jul 22, 2008 9:18 am; skupaj popravljeno 1 krat |
gumby Član
Pridružen-a: Sob 28 Apr 2007 12:32 Prispevkov: 4066 Aktiv.: 19.66
Objavljeno: Pet Jul 18, 2008 12:39 pm Naslov sporočila: |
aly hvala za tole... crkavam od smeha
DrRogla Član
Pridružen-a: Tor 18 Jan 2005 18:00 Prispevkov: 336 Aktiv.: 1.51 Kraj: Hrastnik, Maribor
Objavljeno: Pet Jul 18, 2008 9:14 pm Naslov sporočila: |
Opomba 2 je zmagala!!!
_________________ LP, Božo |
salvador Član
Pridružen-a: Pon 04 Okt 2004 18:51 Prispevkov: 87 Aktiv.: 0.39 Kraj: koroška
Objavljeno: Tor Jul 22, 2008 1:27 am Naslov sporočila: |
Posle svakog leta piloti avio-prevoznika Quantas ostave belesku mehanicarima
sa opisom problema, a pred sledeci let mehanicari ostave odgovor sta su
uradili. Inace, Quantas je jedina svetska avio-kompanija kojoj nikada nije
pao avion.
Zahtev: Leva guma skoro treba da se zameni.
Izvestaj: Leva guma skoro zamenjena.
Zahtev: Nesto se otkacilo u kabini.
Izvestaj: Nesto smo zakacili u kabini.
Zahtev: Autopilot sam gubi visinu za po 200 stopa u minuti.
Izvestaj: Nismo uspeli da ponovimo problem na zemlji.
Zahtev: Tragovi curenja na levom stajnom trapu.
Izvestaj: Tragovi obrisani.
Zahtev: Zvuk iz DME instrumenta glasan da ne poverujes.
Izvestaj: Zvuk iz DME podesen na nivo u koji mozes da poverujes.
Zahtev: IFF instrument neoperativan.
Izvestaj: IFF instrument je uvek neoperativan kad je iskljucen.
Zahtev: Sumnjamo na pukotinu u staklu vetrobrana.
Izvestaj: Sumnjamo da ste u pravu.
Zahtev: Nema motora broj 3
Izvestaj: Vizuelnim pregledom letilice pronadjen motor na levom krilu.
Zahtev: Avion smesno reaguje na komande.
Izvestaj: Avion upozoren da se uozbilji.
Zahtev: cudan zvuk iz instrument table, kao da neki patuljak udara cekicem.
Izvestaj: Patuljku oduzet cekic.
_________________ "Ni pomembno , da se mi danes nič ne da, važno je, da se mi nič ne vzame!!!!!" |
Pridružen-a: Pet 24 Sep 2004 21:58 Prispevkov: 14228 Aktiv.: 63.82 Kraj: Divača (Kačiče)
Objavljeno: Ned Jul 27, 2008 6:03 pm Naslov sporočila: |
šef !
83.8 KB |
12 krat |
robert Član
Pridružen-a: Sob 29 Maj 2004 21:48 Prispevkov: 1871 Aktiv.: 8.39 Kraj: Tolmin
Objavljeno: Ned Jul 27, 2008 11:00 pm Naslov sporočila: |
Komentar iz enega drugega foruma:
WD je smrt za štrom z zakasnjenim efektom .......
_________________ LP Robert |
Iztok Član
Pridružen-a: Pet 08 Okt 2004 0:55 Prispevkov: 4974 Aktiv.: 22.31 Kraj: LJ
Objavljeno: Ned Jul 27, 2008 11:04 pm Naslov sporočila: |
robert je napisal/a: |
WD je smrt za štrom z zakasnjenim efektom ....... |
Jao, jao ... spet me prepisujete ...
Jan Član
Pridružen-a: Sob 10 Jun 2006 14:19 Prispevkov: 313 Aktiv.: 1.44 Kraj: Dolenjska
Objavljeno: Tor Jul 29, 2008 7:55 am Naslov sporočila: |
Vse, kar rabiš v mehaniki sta WD40 in izolirni trak. Če se kaj ne premika, pa bi se moralo, uporabiš WD. Če pa se kaj premika in se ne bi smelo, uporabiš izolirni trak.
Jan
polhar Član
Pridružen-a: Sob 04 Mar 2006 9:11 Prispevkov: 360 Aktiv.: 1.63 Kraj: Dol pri Ljubljani
Objavljeno: Tor Jul 29, 2008 5:10 pm Naslov sporočila: |
za šalo
http://www.snotr.com/video/1366
tale je maral imet pa vsaj dvojno hitrost napram vozniku s kamero
aljoš Član
Pridružen-a: Čet 08 Sep 2005 20:03 Prispevkov: 3132 Aktiv.: 14.05 Kraj: Škofja loka-poljanska dolina
Objavljeno: Ned Avg 03, 2008 10:21 pm Naslov sporočila: |
GRE RADOVAN KARAĐIČ V BEOGRADU NA "PIJACU" ,DA KUPI PARADAJZ...
GA NEKA STARA ŽENSKA POCUKA ZA ROKAV IN TIHO REČE: KARAĐIČU,KARAĐIČU...REČE ON:
"MA ŠTO TI JE,BABO STARA,JEBO TE BOG,PA NISAM TI JA KARAĐIĆ,TI ME S NEKOM ZAMIJENILA!
GRE ON ČEZ TRI DNI SPET NA "PIJACU",DA SI KUPI PARADAJZ...
SPET ISTA STARA ŽENSKA GA POCUKA ZA ROKAV IN TIHO REČE: KARAĐIĆU,KARAĐIĆU...REČE ON:
MA,BEŽI,GRDOSIJU JEDNA STARA,KO TE [cenzurirano],NISAM TI JA KARAĐIĆ,TI ME S NEKOM ZAMIJENILA!
POTEM KARAĐIĆU "GRATALA PRPA" IN GA NI BILO DVA TEDNA NA "PIJACU",POTEM PA SE OJUNAČI
IN SPET GRE TJA KUPITI PARADAJZ,KO GA SPET ISTA STARA ŽENSKA POCUKA ZA ROKAV
IN MU SPET TIHO REČE:KARAĐIĆU,KARAĐŽIČU...REČE ON:
MA,KOJI TI JE [moški spolni organ],PIČKO JEDNA,PA NISAM TI JA KARAĐŽIČ,OPET SI ME S NEKOM ZAMIJENILA!
REČE BABA: PSSSSST,MA TO SAM TI JA,RATKO MLADIĆ! ...
hehe,ni jim lahko...
[g0ran24] Član
Pridružen-a: Pon 15 Avg 2005 11:27 Prispevkov: 503 Aktiv.: 2.26 Kraj: Brežice
zrij Član
Pridružen-a: Sre 21 Jan 2004 14:40 Prispevkov: 157 Aktiv.: 0.70 Kraj: Ajdovščina
Objavljeno: Pet Avg 08, 2008 2:46 pm Naslov sporočila: |
Težave strašev
102.51 KB |
126 krat |
ule Član
Pridružen-a: Tor 13 Jan 2004 20:32 Prispevkov: 1561 Aktiv.: 7.00 Kraj: Babno Polje
Objavljeno: Pet Avg 08, 2008 4:49 pm Naslov sporočila: |
Predor Šentvid.
80.16 KB |
137 krat |
Uptime: 74 dni
