Malo za šalo VI
Pojdi na stran Prejšnja  1, 2, 3, ... 51, 52, 53  Naslednja
Objavi novo temo   Ta tema je zaklenjena: ne moreš urejati sporočil ali odgovarjati na objave.   Printer-friendly version    www.elektronik.si Seznam forumov -> Dobra volja je najbolja, ...
Misko
Pridružen-a: Ned 16 Apr 2006 15:15
Prispevkov: 549
Aktiv.: 2.51
Kraj: MS
PrispevekObjavljeno: Čet Jul 17, 2008 11:39 am    Naslov sporočila:   Odgovori s citatom
Mačka ki ima več posluha kot jaz http://www.genspot.com/video-65786/smesna-macka.aspx
Jule
Prispevkov: 2533
Aktiv.: 12.67
Kraj: Ajdovščina
PrispevekObjavljeno: Čet Jul 17, 2008 3:32 pm    Naslov sporočila:   Odgovori s citatom
Saj ej kot Ray Charles!
lp Jure
Prispevkov: 9406
Aktiv.: 42.36
PrispevekObjavljeno: Pet Jul 18, 2008 11:09 am    Naslov sporočila:   Odgovori s citatom
Datasheet Write Only Memory Mr. Green
Opis, zakaj je to nastalo:
The origin of the WOM - the "Write Only Memory"
An engineer at Signetics, frustrated by the long and useless sequence of approvals for data sheets (during which no actual checking occurred), once made up a spec for a "Write Only Memory" (a "WOM") and sent it along with a batch of other data sheets to be approved. After all, if you are selling "Read Only Memories", why not have a "Write Only Memory"? It's perfectly logical - - which is why the managers saw nothing wrong with the data sheet.
The WOM data sheet went through the approval chain, just fine, and wound up in Signetics' new products catalog. This came to the attention of the managers at Signetics, only after customers began asking for price and delivery. Signetics shortly printed up new "corrected" databooks, without any WOMs, and asked for the "erroneous" ones to be returned. But customers soon got word of why they asked for returns, and hid them properly.
About 1974, Signetics bought a two-page, full-color spread in the April issue of ELECTRONICS Magazine, and published the WOM data sheet, as a (rather expensive) April Fool's Joke. This version of the WOM data sheet shows the various features of Signetics' Model 25120 "fully-encoded, 9046 x N Random Access, Write Only Memory". This advertisement has been saved, and greatly prized by engineers, for many years.
At many companies, managers are accused of not having any sense of humor. But in this case, the Signetics guys did it right! Even if it did cost them a lot of money!!
Write Only Memory Datasheet.pdf
 Ime datoteke:  Write Only Memory Datasheet.pdf
 Velikost datoteke:  2.34 MB
 Downloadano:  181 krat
Nazadnje urejal/a aly Tor Jul 22, 2008 9:18 am; skupaj popravljeno 1 krat
gumby
Prispevkov: 4066
Aktiv.: 19.74
PrispevekObjavljeno: Pet Jul 18, 2008 12:39 pm    Naslov sporočila:   Odgovori s citatom
aly hvala za tole... crkavam od smeha Laughing
Tule nisem več aktiven.
DrRogla
Prispevkov: 336
Aktiv.: 1.51
Kraj: Hrastnik, Maribor
PrispevekObjavljeno: Pet Jul 18, 2008 9:14 pm    Naslov sporočila:   Odgovori s citatom
Opomba 2 je zmagala!!!
LP, Božo
salvador
Pridružen-a: Pon 04 Okt 2004 18:51
Prispevkov: 87
Aktiv.: 0.39
Kraj: koroška
PrispevekObjavljeno: Tor Jul 22, 2008 1:27 am    Naslov sporočila:   Odgovori s citatom
Posle svakog leta piloti avio-prevoznika Quantas ostave belesku mehanicarima
sa opisom problema, a pred sledeci let mehanicari ostave odgovor sta su
uradili. Inace, Quantas je jedina svetska avio-kompanija kojoj nikada nije
pao avion.
Zahtev: Leva guma skoro treba da se zameni.
Izvestaj: Leva guma skoro zamenjena.
Zahtev: Nesto se otkacilo u kabini.
Izvestaj: Nesto smo zakacili u kabini.
Zahtev: Autopilot sam gubi visinu za po 200 stopa u minuti.
Izvestaj: Nismo uspeli da ponovimo problem na zemlji.
Zahtev: Tragovi curenja na levom stajnom trapu.
Izvestaj: Tragovi obrisani.
Zahtev: Zvuk iz DME instrumenta glasan da ne poverujes.
Izvestaj: Zvuk iz DME podesen na nivo u koji mozes da poverujes.
Zahtev: IFF instrument neoperativan.
Izvestaj: IFF instrument je uvek neoperativan kad je iskljucen.
Zahtev: Sumnjamo na pukotinu u staklu vetrobrana.
Izvestaj: Sumnjamo da ste u pravu.
Zahtev: Nema motora broj 3
Izvestaj: Vizuelnim pregledom letilice pronadjen motor na levom krilu.
Zahtev: Avion smesno reaguje na komande.
Izvestaj: Avion upozoren da se uozbilji.
Zahtev: cudan zvuk iz instrument table, kao da neki patuljak udara cekicem.
Izvestaj: Patuljku oduzet cekic.
"Ni pomembno , da se mi danes nič ne da, važno je, da se mi nič ne vzame!!!!!"
Aktiv.: 64.07
PrispevekObjavljeno: Ned Jul 27, 2008 6:03 pm    Naslov sporočila:   Odgovori s citatom
šef !
 Velikost datoteke:  83.8 KB
robert
Prispevkov: 1869
Aktiv.: 8.42
Kraj: Tolmin
PrispevekObjavljeno: Ned Jul 27, 2008 11:00 pm    Naslov sporočila:   Odgovori s citatom
Komentar iz enega drugega foruma:
WD je smrt za štrom z zakasnjenim efektom ....... Laughing
LP Robert
Iztok
Prispevkov: 4974
Aktiv.: 22.40
PrispevekObjavljeno: Ned Jul 27, 2008 11:04 pm    Naslov sporočila:   Odgovori s citatom
robert je napisal/a:
Jao, jao ... spet me prepisujete ... Laughing
Jan
Pridružen-a: Sob 10 Jun 2006 14:19
Prispevkov: 313
Aktiv.: 1.44
Kraj: Dolenjska
PrispevekObjavljeno: Tor Jul 29, 2008 7:55 am    Naslov sporočila:   Odgovori s citatom
Vse, kar rabiš v mehaniki sta WD40 in izolirni trak. Če se kaj ne premika, pa bi se moralo, uporabiš WD. Če pa se kaj premika in se ne bi smelo, uporabiš izolirni trak.
Smile
Jan
polhar
Pridružen-a: Sob 04 Mar 2006 9:11
Prispevkov: 360
Aktiv.: 1.64
Kraj: Dol pri Ljubljani
PrispevekObjavljeno: Tor Jul 29, 2008 5:10 pm    Naslov sporočila:   Odgovori s citatom
za šalo
http://www.snotr.com/video/1366
tale je maral imet pa vsaj dvojno hitrost napram vozniku s kamero
aljoš
Prispevkov: 3132
Aktiv.: 14.10
PrispevekObjavljeno: Ned Avg 03, 2008 10:21 pm    Naslov sporočila:   Odgovori s citatom
GRE RADOVAN KARAĐIČ V BEOGRADU NA "PIJACU" ,DA KUPI PARADAJZ...
GA NEKA STARA ŽENSKA POCUKA ZA ROKAV IN TIHO REČE: KARAĐIČU,KARAĐIČU...REČE ON:
"MA ŠTO TI JE,BABO STARA,JEBO TE BOG,PA NISAM TI JA KARAĐIĆ,TI ME S NEKOM ZAMIJENILA!
GRE ON ČEZ TRI DNI SPET NA "PIJACU",DA SI KUPI PARADAJZ...
SPET ISTA STARA ŽENSKA GA POCUKA ZA ROKAV IN TIHO REČE: KARAĐIĆU,KARAĐIĆU...REČE ON:
MA,BEŽI,GRDOSIJU JEDNA STARA,KO TE [cenzurirano],NISAM TI JA KARAĐIĆ,TI ME S NEKOM ZAMIJENILA!
POTEM KARAĐIĆU "GRATALA PRPA" IN GA NI BILO DVA TEDNA NA "PIJACU",POTEM PA SE OJUNAČI
IN SPET GRE TJA KUPITI PARADAJZ,KO GA SPET ISTA STARA ŽENSKA POCUKA ZA ROKAV
IN MU SPET TIHO REČE:KARAĐIĆU,KARAĐŽIČU...REČE ON:
MA,KOJI TI JE [moški spolni organ],PIČKO JEDNA,PA NISAM TI JA KARAĐŽIČ,OPET SI ME S NEKOM ZAMIJENILA!
REČE BABA: PSSSSST,MA TO SAM TI JA,RATKO MLADIĆ! ...
hehe,ni jim lahko...
[g0ran24]
Pridružen-a: Pon 15 Avg 2005 11:27
Prispevkov: 503
Aktiv.: 2.27
Kraj: Brežice
PrispevekObjavljeno: Pet Avg 08, 2008 1:47 pm    Naslov sporočila:   Odgovori s citatom
http://www.bolha.com/oglas3517539/intimno Laughing
http://hopsasa/f/2v/Fj/3bicEl0M/smesno.jpg
zrij
Pridružen-a: Sre 21 Jan 2004 14:40
Prispevkov: 157
Aktiv.: 0.71
Kraj: Ajdovščina
PrispevekObjavljeno: Pet Avg 08, 2008 2:46 pm    Naslov sporočila:   Odgovori s citatom
Težave strašev
 Velikost datoteke:  102.51 KB
 Pogledana:  126 krat
ule
Prispevkov: 1561
Aktiv.: 7.03
Kraj: Babno Polje
PrispevekObjavljeno: Pet Avg 08, 2008 4:49 pm    Naslov sporočila:   Odgovori s citatom
Predor Šentvid.
 Velikost datoteke:  80.16 KB
 Pogledana:  137 krat
Objavi novo temo   Ta tema je zaklenjena: ne moreš urejati sporočil ali odgovarjati na objave.   Printer-friendly version    www.elektronik.si Seznam forumov -> Dobra volja je najbolja, ... Časovni pas GMT + 2 uri, srednjeevropski - poletni čas
Stran 2 od 53
Uptime: 48 dni
