Pridružen-a: Pon 24 Feb 2003 17:09 Prispevkov: 14551 Aktiv.: 65.53 Kraj: Koroška-okolica Dravograda
Objavljeno: Ned Maj 20, 2018 11:37 am Naslov sporočila: Bluetooth ZS-040 |
Imam zgoraj omenjen bluetooth -> RS232 modulček. (Cipset CC2541) Koliko sem uspel najti gre dejansko za klona HM10.
Zadeva s strani RS232 deluje - se odziva na AT ukaze. Z strani BT pa je "mrtva" . Ni vidna na nobeni napravi. (preizkušeno na več različnih telefonih) Poskusil sem dva komada. Nobeden ne deluje. Rdec led utripa v ritmu ca 1.sec.
Mogoče kdo ve kje je problem? So modulčki zanič? Imam enega starejšega(mislim, daje HC06), ki pa dela brez problema.
Nabor ukazov, ki jih vrača AT+HELP
Koda: |
* Command Description *
* AT Check if the command terminal work normally *
* AT+RESET Software reboot *
* AT+VERSION Get firmware, bluetooth, HCI and LMP version *
* AT+HELP List all the commands *
* AT+NAME Get/Set local device name *
* AT+PIN Get/Set pin code for pairing *
* AT+PASS Get/Set pin code for pairing *
* AT+BAUD Get/Set baud rate *
* AT+LADDR Get local bluetooth address *
* AT+ADDR Get local bluetooth address *
* AT+DEFAULT Restore factory default *
* AT+RENEW Restore factory default *
* AT+STATE Get current state *
* AT+PWRM Get/Set power on mode(low power) *
* AT+POWE Get/Set RF transmit power *
* AT+SLEEP Sleep mode *
* AT+ROLE Get/Set current role. *
* AT+PARI Get/Set UART parity bit. *
* AT+STOP Get/Set UART stop bit. *
* AT+START System start working. *
* AT+IMME System wait for command when power on. *
* AT+IBEA Switch iBeacon mode. *
* AT+IBE0 Set iBeacon UUID 0. *
* AT+IBE1 Set iBeacon UUID 1. *
* AT+IBE2 Set iBeacon UUID 2. *
* AT+IBE3 Set iBeacon UUID 3. *
* AT+MARJ Set iBeacon MARJ . *
* AT+MINO Set iBeacon MINO . *
* AT+MEA Set iBeacon MEA . *
* AT+NOTI Notify connection event . *
* AT+UUID Get/Set system SERVER_UUID . *
* AT+CHAR Get/Set system CHAR_UUID . *
* Note: (M) = The command support slave mode only. *
* For more information, please visit http://www.bolutek.com *
* Copyright@2013 www.bolutek.com. All rights reserved. *
+VERSION=Firmware V3.0.6,Bluetooth V4.0 LE
+NAME=CC41-A
PS
EN pin naj ne bi bilo potrebno priklopit nikamor. Sem ga sicer poskusil na visoko in nizko stanje a ni sprermemb. _________________ lp
Vlado Član
Pridružen-a: Sre 03 Mar 2004 21:35 Prispevkov: 561 Aktiv.: 2.53 Kraj: Ljubljana
Uptime: 48 dni
