pirpy Član
Pridružen-a: Ned 30 Maj 2004 21:57 Prispevkov: 772 Aktiv.: 3.46 Kraj: Topolšica
Objavljeno: Pon Nov 25, 2019 7:38 pm Naslov sporočila: |
s traktorjem mešam pol ure s porabo 8 l na uro...
_________________ Ne, ne moreš dodajati novih tem v tem forumu
Ne, ne moreš urejati svojih prispevkov v tem forumu |
pirpy Član
Objavljeno: Pon Nov 25, 2019 7:40 pm Naslov sporočila: |
pa da ne govorim o delovnih urah, ki na traktorju tečejo , mora pa biti tavelik traktor zaradi zajema silaže.
kastaneda Član
Pridružen-a: Pet 23 Okt 2009 11:18 Prispevkov: 458 Aktiv.: 2.59
Objavljeno: Tor Nov 26, 2019 9:00 am Naslov sporočila: |
pirpy je napisal/a: |
Hvala
Ker imam 25 A priključno moč je vsak A dobrodošel. |
Jalove energije ti ne plačuješ.
_________________ LP
Srečko |
pirpy Član
Objavljeno: Tor Nov 26, 2019 1:05 pm Naslov sporočila: |
Res je
Pancerko mi pa vseeno skuri .
pirpy Član
Objavljeno: Sob Nov 30, 2019 7:19 pm Naslov sporočila: |
Ni mi čisto jasno tole s kondenzatorju.?
primer:
A Single phase 400V, 50Hz, motor takes a supply current of 50A at a P.F (Power factor) of 0.6. The motor power factor has to be improved to 0.9 by connecting a capacitor in parallel with it. Calculate the required capacity of Capacitor in both kVAR and Farads.
Solution.:
(1) To find the required capacity of Capacitance in kVAR (i.e, Convert Capacitor Farads into kVAR) to improve P.F from 0.6 to 0.9 (Two Methods)
Solution #1 (By Simple Table Method)
Motor Input = P = V x I x Cosθ
= 400V x 50A x 0.6
= 12kW
From Table, Multiplier to improve PF from 0.60 to 0.90 is 0.849
Required Capacitor kVAR to improve P.F from 0.60 to 0.90
Required Capacitor kVAR = kW x Table Multiplier of 0.60 and 0.90
= 12kW x 0.849
= 10.188 kVAR
Solution # 2 (Classical Calculation Method)
= 400V x 50A x 0.6
= 12kW
ActualP.F = Cosθ1 = 0..6
Required P.F = Cosθ2 = 0.90
θ1 = Cos-1 = (0.60) = 53°.13; Tan θ1 = Tan (53°.13) = 1.3333
θ2 = Cos-1 = (0.90) = 25°.84; Tan θ2 = Tan (25°.50) = 0.4843
Required Capacitor kVAR = P (Tan θ1 – Tan θ2)
= 12kW (1.3333– 0.4843)
= 10.188 kVAR
(2) To find the required capacity of Capacitance in Farads (i.e, Convert Capacitor Farads into kVAR) to improve P.F from 0.6 to 0.9 (Two Methods)
Solution #1 (Using a Simple Formula)
We have already calculated the required Capacity of Capacitor in kVAR, so we can easily convert it into Farads by using this simple formula
Required Capacity of Capacitor in Farads/Microfarads
C = kVAR / (2 π f V2) in microfarad
Putting the Values in the above formula
= (10.188kVAR) / (2 x π x 50 x 4002)
= 2.0268 x 10-4
= 202.7 x 10-6
= 202.7μF |
jaz pa rabim za 11 kW motor z 0.71 cos phi 3 x 100 uF ?
vir:
https://www.electricaltechnology.org/2013/11/how-to-calculate-required-capacitor.html
eldi2011 Član
Pridružen-a: Pon 29 Sep 2014 15:55 Prispevkov: 257 Aktiv.: 2.21
Objavljeno: Sob Nov 30, 2019 8:47 pm Naslov sporočila: |
Običajni motorji 11 kW imajo cos fi nekje okrog 0,85.
lojzek Član
Pridružen-a: Pet 25 Jan 2008 8:00 Prispevkov: 3356 Aktiv.: 16.97
Objavljeno: Ned Dec 01, 2019 9:17 am Naslov sporočila: |
Ena večjih težav pri kompenzaciji jalove komponente pri motorju je, da ne veš karakteristike jalove moči (no, ja tudi delovne oz. navidezne) pri različnih obremenitvah. Če bi si to karakteristiko izmeril z enim instrumentom, bi bilo veliko laže...
Namreč, tok motorja se med praznim tekom in polno obremenitvijo ne spreminja toliko, spreminjata se predvsem deleža jalove in delovne energije.
pirpy Član
Objavljeno: Ned Dec 01, 2019 8:00 pm Naslov sporočila: |
https://youtu.be/1fHBYzjKY8s
pri 1400 kg tok iz omrezja 14-17 A pf 0.85-09
lipa Član
Pridružen-a: Ned 27 Sep 2009 9:39 Prispevkov: 734 Aktiv.: 4.14 Kraj: Lipa Beltinci
Objavljeno: Ned Dec 01, 2019 8:51 pm Naslov sporočila: |
Z frekvenčnikom se rešiš tega problema, saj se jalova energija v tem primeru pretaka le med motorjem in kondenzatorji v frekvenčniku.
Boris Z. |
pirpy Član
Objavljeno: Ned Dec 01, 2019 9:23 pm Naslov sporočila: |
jutri preizkusim 2 tone.
Energetik-m Član
Pridružen-a: Pon 07 Dec 2009 19:16 Prispevkov: 1345 Aktiv.: 7.68 Kraj: Zagorje
Objavljeno: Ned Dec 01, 2019 11:29 pm Naslov sporočila: |
Neobremenjen motor še polovico nazivnega toka ne bo vlekel, zato ti je takrat čisto vseeno, kakšen bo fazni kot. Dovolj mora biti kompenzirani pri nazivni obremenitvi, da ti ne bo odbilo varovalke.
_________________ lp |
psevdonim Član
Pridružen-a: Čet 21 Sep 2006 21:42 Prispevkov: 3370 Aktiv.: 15.74 Kraj: slo
Objavljeno: Pon Dec 02, 2019 12:05 am Naslov sporočila: |
kaj pa če bi izmeril koliko toka teče skozi navitja pri 24VAC in potem navitjem vzporedno vezal kondenzator skozi katerega pri 24VAC teče enak tok ?
_________________ ___ |
pirpy Član
Objavljeno: Pon Dec 02, 2019 6:44 pm Naslov sporočila: |
Danes sem mešal 1600 kg , odčitek A, kW in pf po fazah na glavnih varovalkah.
kW ali 2 vzamejo ostali porabniki.
Izgleda, da je kar ok kompenzirano.
Za 2 tone bodo verjetno 20 A varovalke malo majhne.?
https://www.youtube.com/watch?v=FIv5hI8ej_w
pirpy Član
Uptime: 73 dni
