ule Član
Pridružen-a: Tor 13 Jan 2004 20:32 Prispevkov: 1561 Aktiv.: 7.01 Kraj: Babno Polje
Objavljeno: Sre Jan 08, 2020 10:42 pm Naslov sporočila: UVC sijalke? |
Govora je o teh sijalkah
Zanima me, če ima kdo kakšne izkušnje z dezinfekcijo prostorov (ali pozna koga)? Koliko sijalk bi potreboval in koliko časa bi morale svetiti za dezinfekcijo prostora, velikega 5m x 5m x 3m? |
lucca brassi Član
Pridružen-a: Ned 01 Feb 2004 12:46 Prispevkov: 4049 Aktiv.: 18.17 Kraj: KOČEVJE
Objavljeno: Pet Jan 10, 2020 9:16 am Naslov sporočila: |
"Even at the minimum acceptable irradiance in a biosafety cabinet of 40 W/cm2 (U.S. Department of Health and Human Services et al., 2000), it takes 12.5 minutes to reach 30,000 J/cm2 (1 W= 1 J/sec), which has been listed as germicidal for spore forming organisms by one UV manufacturer (www.uvp.com/pdf/ab-115.pdf)."
"Even using the NIH/CDC criterion of the minimum acceptable irradiance in a biosafety cabinet
of 40 W/cm2, it takes 12.5 minutes to reach the 30,000 J/cm2 found to inactivate spore forming organisms.
Use of a UV light in excess of an hour or overnight is massive overkill." from: http://www.ehs.ucsb.edu/files/docs/bs/Meechan_and_Wilson_2006.pdf
We typically leave the light on for 10 minutes prior to use, although after reading this, I'll up that to 15 minutes. '' potem pa jo premakneš po vseh kotih pa si dober z eno uro .
To moram naredit tudi jaz za našo hladilnico. Samo ko pomijemo hladilnico ( tudi sedaj v tem času je mokra in se potem suši (pa predprostor ni ogrevan )
Jasno je da ne smeš imeti mrtvih kotov , zato je fino da je svetilka premična v stilu
http://microchemlab.com/test/uv-room-disinfection-devices
https://www.cureuv.com/products/germawayuv-table-top-uvc-surface-sterilizer _________________ Moments before detonation ,....... TT |
ule Član
Objavljeno: Pet Jan 10, 2020 11:26 pm Naslov sporočila: |
Hvala. Sicer so v članku omenjeni "mikro" watt in "mikro" joule. Verjetno forum ne dopušča črke |
joztom Član
Pridružen-a: Sob 11 Nov 2017 0:42 Prispevkov: 272 Aktiv.: 3.47 Kraj: Ljubljana
Objavljeno: Sob Jan 11, 2020 11:05 am Naslov sporočila: |
Poišči še LED izvire svetlobe za tak namen. |
qwertz Član
Pridružen-a: Ned 01 Jun 2008 11:57 Prispevkov: 2542 Aktiv.: 13.14 Kraj: Vrhnika
Objavljeno: Tor Jan 14, 2020 7:15 pm Naslov sporočila: |
https://uvc-solutions.com/sl/
Tole delajo pri nas. Mogoče se obrni na njih za info.
Seveda forum podpira grško črko mi:
Greek letter μ or legacy micro symbol µ (oboje dela ne vem pa zakaj ima forum sliko simbola). |
mmat Član
Pridružen-a: Ned 19 Jan 2020 12:52 Prispevkov: 19 Aktiv.: 0.37
Objavljeno: Ned Jan 19, 2020 4:04 pm Naslov sporočila: |
Bi se obneslo v praksi za uničevanje pršič?
Sam sem skeptičen, ker so pršice tudi v jogiju in ne samo na njem.
Kaj pa kakšna mini enota za v čevlje - razkuževanje glivic?
Ima kdo kaj izkušenj? |
Uptime: 71 dni
