Pomoč pri programiranju PIC-a
Jakey
Prispevkov: 651
Aktiv.: 4.54
Kraj: Ravne/LJ/Kobarid
PrispevekObjavljeno: Pet Apr 04, 2014 9:24 pm    Naslov sporočila:  Pomoč pri programiranju PIC-a Odgovori s citatom
Moram opraviti za faks neke meritve ter podati poročila. Zanima me, če mi lahko kdo pomaga pri tem.
Pic: dsPIC33F modul z DSC krmilnikom dsPIC33FJ12GP202
Prva naloga:
"Izmerite interval prekinitev in interval preklopa LED diod."
Koda:
//* 28pin_UART_TX-RX_Using_USB
#include "p33FJ12GP202.h"
// the above include path may be different for each user.  If a compile
// time error appears then check the path for the file above and edit
// the include statement above.
//#define XTFREQ          7370000         //FRC frequency
#define FCY             39613000        //Instruction Cycle Frequency
#define BAUDRATE         9600
#define BRGVAL          ((FCY/BAUDRATE)/16)-1
int main(void)
// Configure Oscillator to operate the device at 40Mhz
// Fosc= Fin*M/(N1*N2), Fcy=Fosc/2
// Fosc= 7.37*43/(2*2)=79.23MHz
   PLLFBD=41;               // M=43
   CLKDIVbits.PLLPOST=0;      // N1=2
   CLKDIVbits.PLLPRE=0;      // N2=2
// Disable Watch Dog Timer
   RCONbits.SWDTEN=0;
// Wait for PLL to lock
   while(OSCCONbits.LOCK!=1) {};
   RPINR18 = 9;         // Make Pin RP9 U1RX
   RPOR4bits.RP8R = 3;      // Make Pin RP8 U1TX
   AD1PCFGL = 0x03C0;      // Make analog pins digital
   LATB = 0x0000;
   TRISB = 0x0FFF;         // Config LED's as output and U1RX as Input
   TMR1 = 0;            // clear timer 1
   PR1 = 0xFFFF;         // interrupt every 400ms
   IFS0bits.T1IF = 0;      // clr interrupt flag
   IEC0bits.T1IE = 1;      // set interrupt enable bit
   T1CON = 0x8030;         // 1:64 prescale, start TMR1
   U1BRG  = BRGVAL;
   U1MODE = 0x8000; /* Reset UART to 8-n-1, alt pins, and enable */
   U1STA  = 0x0440; /* Reset status register and enable TX & RX*/
_U1RXIF=0;
while(1)
      int a;
      while (_U1RXIF==0);         // Wait and Receive One Character
      a = U1RXREG;
      while(!U1STAbits.TRMT);
      U1TXREG = '"';
      while(!U1STAbits.TRMT);      // Echo Back Received Character with quotes
      U1TXREG = a;
      U1TXREG = '"';
      U1TXREG = ' ';
      _U1RXIF=0;               // Clear UART RX Interrupt Flag
return 0;
void __attribute__((__interrupt__, no_auto_psv)) _T1Interrupt(void)
   IFS0bits.T1IF = 0;   // clear interrupt flag
   LATB ^= 0xF000;      //Toggle LED's
Jakey
Prispevkov: 651
Aktiv.: 4.54
PrispevekObjavljeno: Pet Apr 04, 2014 9:26 pm    Naslov sporočila:  Re: Pomoč pri programiranju PIC-a Odgovori s citatom
Zanima me, kam naj vstavim breakpointe(za merjenje z stopwatchom) ter kam za merjenje dolžine utripa diode?
Uptime: 66 dni
