lipa Član
Pridružen-a: Ned 27 Sep 2009 9:39 Prispevkov: 734 Aktiv.: 4.14 Kraj: Lipa Beltinci
Objavljeno: Tor Jun 23, 2015 4:47 pm Naslov sporočila: Frekvenčni pretvornik in zaviranje |
Dobil sem starejši frekvenčnik , ki je brez zavornega modula in brez zavornega upora.
Vprašanje za poznavalce.
Ali ga lahko uničim, če parametre nastavim tako, da lahko na hitro zmanšam frekveco in bo začel frekvenčnik zavirati.
Ali pa bo frekvenčnik sam zaznal problem in izklopil zaviranje?
Bojim se namreč, da mi bo napetost na kondenzatorjih preveč narasla itd.
Upam da sem dovolj dobro opisal problem ki me muči in nimam izkušenj.
_________________ Lep pozdrav!
Boris Z.
Nazadnje urejal/a lipa Pon Avg 10, 2015 4:32 pm; skupaj popravljeno 1 krat |
Profesor Einstein Član
Pridružen-a: Ned 24 Sep 2006 0:13 Prispevkov: 1423 Aktiv.: 6.65 Kraj: Rogaška Sl.
Objavljeno: Tor Jun 23, 2015 5:34 pm Naslov sporočila: |
Zdravo
Tudi mene zanima kako je s tem...
S spleta...
Thread: What is the difference between DC braking and Dynamic Braking?
Dynamic braking is adjusting the VFD AC output so as to slow the motor, and recover the energy onto the DC bus.
The braking resistor then dissipates that energy, preventing the DC bus from rising.
"DC injection is when a drive applies a DC voltage to a three phase motor to create a stationary magnetic field which will in turn stop the motor.
This method of braking does create additional heat which could potentially damage the motor."
So dynamic brakes dissipate the energy by recovering it as voltage on the DC bus, and then dissipating it as heat (or using it).
DC braking would dump it as heat in the motor directly, and not need the braking resistor.
Lp.
_________________ --
lipa Član
Objavljeno: Sre Jun 24, 2015 3:24 pm Naslov sporočila: |
Danes sem probal prvi zagon (po 27 letih- toliko je namreč star). V službi sem priklopil 4 kW motor z ventilatorjem.
dela kot japonska urica..
Probal sem tudi previdno zavirati, vmes sem celi čas opazoval voltažo na kondenzatorjih, ki je normalno 570 - 580V.
No pri zaviranju se mi je napetost dvignila tudi nad 750V, za trenutek celo 800V. Ob tem ni javil nobene napake.
Tako da s tem je potrebna previdnost,
Vgrajena sta 2 veliiiika elkoja, na enem od strani komaj razberem 400V dc.
2.22 MB |
20 krat |
Boris Z.
Nazadnje urejal/a lipa Ned Feb 28, 2016 7:32 pm; skupaj popravljeno 1 krat |
lipa Član
Objavljeno: Sre Jun 24, 2015 3:26 pm Naslov sporočila: |
2.18 MB |
20 krat |
Boris Z. |
lipa Član
Objavljeno: Sre Jun 24, 2015 3:28 pm Naslov sporočila: |
2.18 MB |
10 krat |
Boris Z. |
lipa Član
Objavljeno: Sre Jun 24, 2015 3:29 pm Naslov sporočila: |
1.86 MB |
3 krat |
Boris Z. |
lipa Član
Objavljeno: Sre Jun 24, 2015 4:27 pm Naslov sporočila: |
Sem se potrudil in sem odčital še oznake na elko-jih, je malo težje dostopno...
4700MFD 400VDC
SURGE 450VDC
81 B3
Glede na zadnje številke je čisto možno da so elkoti 1981 letnik, frekvenčnik je namreč 1988 letnik.
Koliko smo že takrat bili stari....
Prvi dan ko so elkoti bili popolnoma prazni, sem meril tudi ESR, seveda je pokazalo 0,00 ohm
Boris Z. |
Branez Moderator
Pridružen-a: Pon 14 Apr 2003 7:21 Prispevkov: 7770 Aktiv.: 34.87 Kraj: Koprivnica HR
Objavljeno: Sre Jun 24, 2015 4:58 pm Naslov sporočila: |
lipa je napisal/a: |
Jaz dvaintrideset, a ti?
Albert Einstein |
lipa Član
Objavljeno: Sre Jun 24, 2015 5:54 pm Naslov sporočila: |
Branez je napisal/a: |
Jaz dvaintrideset, a ti? |
.... sem bil že STAREJŠI osnovnošolec, 14 let
Boris Z. |
Objavljeno: Ned Jun 28, 2015 7:45 pm Naslov sporočila: |
Zdravo
Zaradi zaviranja poraste DC in je potrebno uporabljati Greatzove mostiče za napetosti 1600V.... (800V DC in mreža cca 600V + rezerva).
V priponki vzorčni primer mostiča.
Lp.
64.31 KB |
15 krat |
cero Član
Pridružen-a: Čet 31 Jul 2003 17:37 Prispevkov: 1179 Aktiv.: 5.29 Kraj: vipava
Objavljeno: Ned Jun 28, 2015 9:45 pm Naslov sporočila: |
dobijo se tudi namenski zaviralni moduli, ki jih priklopiš v enosmerni tokokrog frekvenčnika ter breme in jih nastaviš pri kateri napetosti začnejo odvajat na breme.
jerjur Član
Pridružen-a: Čet 06 Maj 2010 22:09 Prispevkov: 459 Aktiv.: 2.70 Kraj: Žiri
Objavljeno: Ned Jun 28, 2015 10:37 pm Naslov sporočila: |
Med zaviranjem je motor v generatorskem načinu delovanja. Energija se pa preko diod v power modulu pretvarja v DC napetost na kondenzatorjih.
Frekvenčni lahko troši to energijo za lastno rabo. Mogoče je tudi več frekvenčnih povezati skupaj v DC-BUS in ostali frekvenčni trošijo energijo, ki se vrača iz motorja.
Viške pa je potrebno kuriti na uporu ali pa vračati v omrežje. V zadnjem času imajo frkvenčniki do nekje 22kW vgrajene tranzistorje, ki odvajajo energijo na zaviralni upor. Če pa tega ni se pa dogradi zaviralno enoto in zaviralni upor.
Frekvenčni pretvorniki imajo navadno 800V kondenzatorje zato napetost ne sme preseči te vrednosti.
_________________ Avtomatika je zakon |
Energetik-m Član
Pridružen-a: Pon 07 Dec 2009 19:16 Prispevkov: 1345 Aktiv.: 7.69 Kraj: Zagorje
Objavljeno: Pon Jun 29, 2015 8:49 am Naslov sporočila: |
Če boš pretiraval z zaviranjem, frekvenčnik zelo verjetno ne bo kar eksplodiral ampak se bo odklopil od motorja, ko napetost na kondenzatorjih doseže maksimum, se bo motor od tam naprej ustavljal prosto, enako kot če ga odklopiš od omrežja. Vsi FP, s katerim sem imel opravka, so imeli vgrajeno to zaščito.
_________________ lp |
lipa Član
Objavljeno: Sob Dec 10, 2016 10:50 am Naslov sporočila: |
Vgrajena sta 2 veliiiika elkoja, na enem od strani komaj razberem 400V dc. |
Dolžan sem še odgovor o težavi zaradi pretiranega naraščanja napetosti. Vzrok je bil banalen, pozabil sem priklopiti en kabelček (se mi je skril) na matično pološčo. Imel sem dva taka frekvenčnika in sem oba prodal. Eden žene tekoči trak pri nekem obrtniku, drugi pa v domači vasi sezonsko pere bučno seme
Frekvenčniki so tako robustni da je mogoče pričakovati še nadaljna desetletja uporabe. Skoraj nepredstavljivo za današnje čase.
Boris Z. |
