Jaka57 Moderator
Pridružen-a: Ned 12 Dec 2004 21:47 Prispevkov: 5773 Aktiv.: 25.89 Kraj: Grosuplje
Objavljeno: Pet Jan 12, 2018 6:46 pm Naslov sporočila: |
Medtem, ko čakam še na ostali material za nov 3D tiskalnik, se igram z novim Smothieboard kompatibilnim kontrolerjem in ugotavljam, kaj se vse da narediti z njim.
Zanimivo je to, da ne potrebuješ prevajanja firmwarea za vsako malenkost, kot smo to počeli pri naši drvarnici, ker je konfiguracijska datoteka navadna tekst datoteka na SD kartici,
v katero vpišeš konfiguracijo tiskalnika, dodaš, recimo, abort tipko in G ukaze, ki se izvedejo po pritisku na tipko, lahko dodajaš dodatne menuje itd.
Del konfiguracijske datoteke za Core-XY tiskalnik:
Koda: |
#Robot module configurations : general handling of movement G-codes and slicing into moves
default_feed_rate 4000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 4000 # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment 0.1 # Arcs are cut into segments ( lines ), this is the length for
# these segments. Smaller values mean more resolution,
# higher values mean faster computation
mm_per_line_segment 5 # Lines can be cut into segments ( not usefull with cartesian # coordinates robots ).
#Arm solution configuration : Corexy. Translates mm positions into stepper positions
arm_solution corexy
alpha_steps_per_mm 400 # Steps per mm for alpha (X) stepper
beta_steps_per_mm 400 # Steps per mm for beta (Y) stepper
gamma_steps_per_mm 3200 # Steps per mm for gamma (Z) stepper
alpha_max_rate 30000
beta_max_rate 30000
#Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING
acceleration 2000 # Acceleration in mm/second/second.
z_acceleration 60 # Accl for Z only mov in mm/s2, 0 use accl which is def. DO NOT SET ON A DELTA
acceleration_ticks_per_second 1000 # Number of times per second the speed is updated
junction_deviation 0.005 # Similar to the old "max_jerk", in millimeters,
# see https://github.com/grbl/grbl/blob/master/planner.c
# and https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.8
# Lower values mean being more careful, higher values means being
# faster and have more jerk
z_junction_deviation 0.0 # for Z only moves, -1 uses junction_deviation, zero disables junction_deviation on z moves DO NOT SET ON A DELTA
minimum_planner_speed 0.0 # sets the minimum planner speed in mm/sec
#Stepper module configuration
microseconds_per_step_pulse 1.5 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping, higher gives smoother movement
#Cartesian axis speed limits
x_axis_max_speed 15000 # mm/min
y_axis_max_speed 15000 # mm/min
z_axis_max_speed 300 # mm/min
#Stepper module pins ( ports, and pin numbers, appending "!" to the number will invert a pin )
alpha_step_pin 2.0 # Pin for alpha stepper step signal
alpha_dir_pin 0.5! # Pin for alpha stepper direction
alpha_en_pin 0.4 # Pin for alpha enable pin
alpha_current 1.3 # X stepper motor current
alpha_max_rate 15000.0 # mm/min
beta_step_pin 2.1 # Pin for beta stepper step signal
beta_dir_pin 0.11! # Pin for beta stepper direction
beta_en_pin 0.10 # Pin for beta enable pin
beta_current 1.3 # Y stepper motor current
beta_max_rate 15000.0 # mm/min
gamma_step_pin 2.2 # Pin for gamma stepper step signal
gamma_dir_pin 0.20! # Pin for gamma stepper direction
gamma_en_pin 0.19 # Pin for gamma enable
gamma_current 1.1 # Z stepper motor current
gamma_max_rate 300.0 # mm/min |
Sedaj pa se bom spravil tiskat kose iz ASA filamenta za ta tiskalnik
_________________ Lp, Jaka |
mosqito Član
Pridružen-a: Čet 07 Apr 2016 23:22 Prispevkov: 3241 Aktiv.: 33.09
Objavljeno: Pet Jan 12, 2018 9:11 pm Naslov sporočila: |
Jaz sem pa uporabil kar CSP.
CHEAP SHITTY PLASTIC
solomojster Član
Pridružen-a: Tor 18 Maj 2010 12:26 Prispevkov: 845 Aktiv.: 4.98 Kraj: NOVA GORICA
Objavljeno: Ned Jan 14, 2018 2:57 pm Naslov sporočila: |
Jaka57 je napisal/a: |
Koda: |
arm_solution corexy
beta_max_rate 30000
Sedaj pa se bom spravil tiskat kose iz ASA filamenta za ta tiskalnik |
Kako pa poteka nalaganje stl datoteke , če imaš na SD kartici konfiguracijske datoteke? Je uporaba USB ključka možna?
Branez Moderator
Pridružen-a: Pon 14 Apr 2003 7:21 Prispevkov: 7771 Aktiv.: 34.86 Kraj: Koprivnica HR
Objavljeno: Ned Jan 14, 2018 6:42 pm Naslov sporočila: |
Vedno manjka kakšen instrument.
Če se to zgodi,
Branko si ga naredi!
60.44 KB |
11 krat |
169.99 KB |
8 krat |
Albert Einstein |
lado Član
Pridružen-a: Pon 09 Feb 2004 13:22 Prispevkov: 987 Aktiv.: 4.43 Kraj: Trbovlje
Objavljeno: Ned Jan 14, 2018 7:06 pm Naslov sporočila: quartz anl |
Branko to bi pa tudi mene zanimalo!!!
Lahko kaj več?
lado
_________________ In brake we trust... |
Pridružen-a: Ned 23 Feb 2003 21:26 Prispevkov: 6555 Aktiv.: 29.40 Kraj: Ljubljana (JN76GB)
Objavljeno: Ned Jan 14, 2018 8:01 pm Naslov sporočila: |
Branez je napisal/a: |
Vedno manjka kakšen instrument. |
A boš kamne brusil ? Tole bi bil pa glede na trenutne trende lahko dober biznis
S53DZ Član
Pridružen-a: Čet 28 Apr 2011 9:27 Prispevkov: 951 Aktiv.: 6.01 Kraj: Ljubljana
Objavljeno: Pon Jan 15, 2018 10:04 am Naslov sporočila: |
...Če se to zgodi,
Branko si ga naredi! |
Branko, zgleda uporabno, zelo lepo in v barvah, kaj pa zna? Sweep-anje in avtomatski zoom, pa izpis parametrov?
LP, Bojan
blay44 Član
Pridružen-a: Ned 19 Dec 2010 18:17 Prispevkov: 603 Aktiv.: 3.71
Objavljeno: Pon Jan 15, 2018 8:55 pm Naslov sporočila: |
Tekma je preveč napeta!
Moram malo prekiniti in počekirat kaj so mi Kitajci poslali.
Pa spajkalnik vključiti.
250.51 KB |
31 krat |
blay44 Član
Objavljeno: Sre Jan 17, 2018 5:18 pm Naslov sporočila: |
Včeraj je prišlo do nenadnega interrupta.......
Tako, da je šele danes zlotana. Prvi poizkus z bascomom v teku.
Zdej pa servič z povratnim dajalnikom pozicije.
242.81 KB |
19 krat |
mosqito Član
Objavljeno: Sre Jan 17, 2018 6:02 pm Naslov sporočila: |
Hiba renault trafic menjalnika je plastični nosilec za zajlo, ki je nataknjen na zunanji vzvod menjalnika. Ko se "znuca", pade dol. Ko natakneš nazaj, spet pade dol.... posledica je, da ostane v prestavi, kjer si nazadnje "prešaltal". Se mi je že zgodilo, da je ostalo v prvi, sam še nisem vedel, za kaj gre, do servisa pa je bilo 8 km. Kar zabavno, če imaš v prvi. Še dobro, da ni ostalo v rikvercu.
Tisto so mi takrat popravili na servisu. Menjava celotne zajle + 1 ura dela: 70+40 EUR. Ker sta zajli dve, je bilo samo vprašanje časa, kdaj se ponovi še na drugi strani. Bilo je sredi Gorjancev, v avtu pa nisem imel nič za popravit. K sreči je bilo do radioamaterske postojanke samo par km in tam sem potem dobil plastične vezice za hitro popravilo.
Menjava zajle mi nekako ni "dišala". Na srečo sem potem našel tole:
https://imgur.com/a/S5yH2
Na ebayu 4 funte+1,5 funta poštnine. Za namestitev pa manj dela kot z vezicami. Sem spraševal serviserja in se je samo nasmehnil: "mi menjamo celo zajlo"
shmandi Član
Pridružen-a: Čet 09 Maj 2013 9:20 Prispevkov: 634 Aktiv.: 4.75 Kraj: Ljubljana
Objavljeno: Sre Jan 17, 2018 9:22 pm Naslov sporočila: |
Zvežeš skupi z drotom pa je.
mosqito Član
Objavljeno: Sre Jan 17, 2018 11:36 pm Naslov sporočila: |
shmandi je napisal/a: |
Zvežeš skupi z drotom pa je. |
... za koliko časa?
Branez Moderator
Objavljeno: Sre Jan 17, 2018 11:39 pm Naslov sporočila: |
Drži vodu dok...
Albert Einstein |
GUMY trgovec
Pridružen-a: Sre 22 Sep 2010 11:03 Prispevkov: 464 Aktiv.: 2.80 Kraj: Bled
Objavljeno: Čet Jan 18, 2018 9:14 am Naslov sporočila: |
Na katerih je to problem? Starih 1.9, novih 2.0 ali na vseh? Jaz sem imel letnik 2003 celih 9 let, pa se mi to ni nikoli zgodilo. Sedaj imam Vivaro 2011.
Jaka57 Moderator
Objavljeno: Čet Jan 18, 2018 9:44 am Naslov sporočila: |
solomojster je napisal/a: |
.......Kako pa poteka nalaganje stl datoteke , če imaš na SD kartici konfiguracijske datoteke? Je uporaba USB ključka možna? |
Šele sedaj sem videl tvoje vprašanje .
Na SD kartici je samo ena konfiguracijska datoteka (config (.txt)), ki se prebere ob zagonu kontrolerja, potem je ne potrebuje več.
Nalaganje stl datoteke (misliš g kode?), poteka tako kot pri Marlinu v povezavi s Curo.
Da bi lahko uporabil USB ključek pa nisem zasledil.
Trenutno uporabljam GLCD od RAMPSa, ki ima slot za SD kartico in kontroler vidi tudi ta slot oz. kartico.
Uptime: 74 dni
