Bascom lcd4e2.lib sprememba
marko11
Prispevkov: 866
Aktiv.: 3.88
Kraj: Dobrepolje
PrispevekObjavljeno: Čet Jan 25, 2018 5:49 pm    Naslov sporočila:  Bascom lcd4e2.lib sprememba Odgovori s citatom
Hi
Zanima me, če je mogoče popraviti "lcd4e2.lib" datoteko?
Rad bi samo spremenil Rs = PortB.0 ( je sedaj ) na port Rs=PortB.1
To pa zato ker sem pri izdelavi PCB ploščice narobe potegnil vezico.
Prilagam lib datoteko, pa prosim, če je to mogoče, da mi jo nekdo popravi.
lp, marko
Koda:
copyright = MCS Electronics
www       = http://www.mcselec.com
email     = avr@mcselec.com
comment   = Optimized LCD library
libversion   = 1.00
date         = 2 februari 2001
statement    = No SOURCE code from the library may be distributed in any form
statement    = Of course this does not applie for the COMPILED code when you have a BASCOM-AVR license
history      = No known bugs.
;the default library for BASCOM can handle worst case scenarios where each pin of the LCD
;is connected to a random pin of the micro
;When we choose the data port pin in sequence, we can save some code
;This lib shows how to use the LCD in 4 bit mode with 2 E lines !
;Rs = PortB.0
;RW = PortB.1        we dont use the R/W option of the LCD in this version so connect to ground
; E = PortB.2
;E2 = PortB.3        for lcd with 2 chips
;Db4 = PortB.4       the data bits must be in a nibble to save code
;Db5 = PortB.5
;Db6 = PortB.6
;Db7 = PortB.7
;This routine is called when the LCD must be initialized
;dont forget to dimension a byte named ___LCDE
[_Init_LCD]
.EQU LCDDDR=$17       ; change to another address for DDRD ($11)
.EQU LCDPORT=$18      ; change to another address for PORTD ($12)
_Init_LCD:
 *BASIC: waitms 10
 Ldi R24, &B11111111               ; all outputs
 Out LCDDDR,R24                     ; write to Data direction
 Ldi R24, &B00110000               ; set logic level
 Out LCDPORT,R24                    ; write to output pins
 Ldi r16,3                          ; repeat 3 times
_Init_LCD1:
 SBi LCDPORT, 2                     ; E high
 Cbi LCDPORT, 2                     ; E low
 Sbi LCDPORT, 3                     ; E2 high
 Cbi LCDPORT, 3                     ; E2 low
 *BASIC: waitms 1
 Dec R16
 Brne _Init_LCD1                    ; until we are ready
 Cbi LCDPORT, 4                     ; DB4 must be set low now
 Sbi LCDPORT,3                      ; E2 high
 Cbi LCDPORT,3                      ; E2 low
 *BASIC: waitms 1
 Ldi R24,0
* Sts {___LCDE},R24                 ; we use E1 now
 Ldi R24, 40                        ; 4 bit mode
 rcall _Lcd_control
 Ldi _temp1,14                      ; Display on, Cursor on, Noblink
 rcall _Lcd_control
 Ldi _temp1,6                       ; Cursor moves right, text doesn't move
 rcall _Lcd_control
 Ldi R24,255
* Sts {___LCDE},R24                 ; we use E2 now
 rcall _Lcd_control
 rcall _Lcd_control
 Rjmp _Lcd_control
[END]
;high nibble must be written first
;rw must be low for a write
;rs must be low for control, high for data
;data passed in r24
[_Write_lcd]
_Write_lcd:
 Set                               ; RS flag must be made 1
 Rjmp _Write_lcd_Byte
_Lcd_control:
 Clt                               ; RS flag must be 0
_Write_lcd_Byte:
 Mov r25,r24                       ; save data
 Rcall _Write_lcd_Nibble           ; write lower nibble
 Mov R24,r25                       ; get data back
 Swap R24                          ; swap nibble
_Write_lcd_nibble:
* Lds R2,{___LCDE}
 Tst R2
 Brne _Write_lcd_nibble2            ; if E2 selected
 Bld R24,0                          ; RS flag
 Sbr R24,4                          ; E high
 Cbr R24,10                         ; E2 and RW low
 Out LCDPORT, R24                   ; write
 Cbi LCDPORT,2                      ; disable
 Rjmp _Write_lcd_nibble3
_Write_lcd_nibble2:
 Bld R24,0                          ; RS flag
 Sbr R24,8                          ; E high
 Cbr R24,6                          ; E1 and RW low
 Cbi LCDPORT,3                      ; disable
_Write_lcd_nibble3:
 @genus(100)                        ; wait for 100 uS
Ret
[END]
[_CLS]
$EXTERNAL _WRITE_LCD
_Cls:
  Ldi R24,1                         ; Clear display
  Rcall _Lcd_control
  *BASIC: waitms 3
  Ldi R24,128                       ; Select line 1
  Rjmp _Lcd_control                 ; finish
[END]
stursc
Prispevkov: 323
Aktiv.: 1.45
PrispevekObjavljeno: Čet Jan 25, 2018 8:33 pm    Naslov sporočila:  Re: Bascom lcd4e2.lib sprememba Odgovori s citatom
Napiši svoj config
Primer:
Koda:
Config Lcdpin = Pin , Db7 = PortB.7 , Db6 = PortB.6 , Db5 = PortB.5 , Db4 = PortB.4 , E = PortB.3 , Rs = PortB.2
Lp, sturs
mato1111
Prispevkov: 612
Aktiv.: 4.44
Kraj: Vrhnika
PrispevekObjavljeno: Čet Jan 25, 2018 8:36 pm    Naslov sporočila:  Re: Bascom lcd4e2.lib sprememba Odgovori s citatom
Jazbi probal tako (sem samo zamenjal pina Rs in RW):
Koda:
;Rs = PortB.1
;RW = PortB.0        we dont use the R/W option of the LCD in this version so connect to ground
; E = PortB.2
;Db5 = PortB.5
;Db6 = PortB.6
;Db7 = PortB.7
kose19
Prispevkov: 1228
Aktiv.: 5.51
Kraj: okolica Kobarida
PrispevekObjavljeno: Čet Jan 25, 2018 8:36 pm    Naslov sporočila:   Odgovori s citatom
Jaz ponavadi na začetku programa konfiguriram na katere pine imam priključen lcd. Poglej kak primer za lcdconfig. Potem ne rabiš knjižnice in tudi nastavitve v settings/lcd nimajo vpliva.
- Absens, carens -
Prispevkov: 5773
Aktiv.: 25.90
PrispevekObjavljeno: Čet Jan 25, 2018 8:43 pm    Naslov sporočila:  Re: Bascom lcd4e2.lib sprememba Odgovori s citatom
mato1111 je napisal/a:
Koda:
;Rs = PortB.1
; E = PortB.2
;Db5 = PortB.5
;Db6 = PortB.6
;Db7 = PortB.7
S tem nisi naredil popolnoma nič, ker tisto za podpičjem je samo komentar.
marko11 probaj tako kot je napisal stursc.
Je pa nekaj kar se te knjižnjice tiče, ne uporablja pina RW in ga pri LCDju enostavno vežeš na minus:
Koda:
When you want to have less code you need fixed pins for the LCD display.
With the statement $LIB "LCD4E2.LBX" you specify that the LCD4.LIB will be used.
The following connections are used in the asm code:
Rs = PortB.0
RW = PortB.1 we don’t use the R/W option of the LCD in this version so connect to ground
E = PortB.2
E2 = PortB.3 the second E pin of the LCD
Db5 = PortB.5
Db6 = PortB.6
Db7 = PortB.7
You can change the lines from the lcd4e2.lib file to use another port.
Just change the address used :
Tole zgoraj je napisano na Bascomovi strani.
Mogoče bi bilo najenostavneje popravit tiskanino, tj., prekinit povezavi, eno daš na maso, Rs pa povežeš tako, da bo program deloval.
Nazadnje urejal/a Jaka57 Čet Jan 25, 2018 8:55 pm; skupaj popravljeno 2 krat
marko11
Prispevkov: 866
Aktiv.: 3.88
Kraj: Dobrepolje
PrispevekObjavljeno: Čet Jan 25, 2018 8:47 pm    Naslov sporočila:  Re: Bascom lcd4e2.lib sprememba Odgovori s citatom
stursc je napisal/a:
Napiši svoj config
Primer:
Koda:
Lp, sturs
Nevem če bo to šlo to tako, ker imam 2 LCD-ja in moram preklapljati med E in E2.
marko11
Prispevkov: 866
Aktiv.: 3.88
Kraj: Dobrepolje
PrispevekObjavljeno: Pet Jan 26, 2018 8:50 pm    Naslov sporočila:   Odgovori s citatom
Hi
Me pa še vedno zanima, če je možna sprememba v lcd4e2.lib ? da bi bil RS na portB.1,
Rw je pa tako vezan na GND.
lp,
Prispevkov: 5773
Aktiv.: 25.90
PrispevekObjavljeno: Pet Jan 26, 2018 9:26 pm    Naslov sporočila:  Re: Bascom lcd4e2.lib sprememba Odgovori s citatom
marko11, probaj tole:
Koda:
libversion   = 1.00
;Rs = PortB.0
; E = PortB.2
;Db5 = PortB.5
;Db6 = PortB.6
;Db7 = PortB.7
[_Init_LCD]
_Init_LCD:
 *BASIC: waitms 10
_Init_LCD1:
 *BASIC: waitms 1
 Dec R16
 *BASIC: waitms 1
 Ldi R24,0
 rcall _Lcd_control
 rcall _Lcd_control
 rcall _Lcd_control
 Ldi R24,255
 rcall _Lcd_control
 rcall _Lcd_control
 Rjmp _Lcd_control
[END]
;data passed in r24
[_Write_lcd]
_Write_lcd:
_Lcd_control:
_Write_lcd_Byte:
_Write_lcd_nibble:
* Lds R2,{___LCDE}
 Tst R2
 Bld R24,1                          ; RS flag,            spremenil Jaka <-------------
 Sbr R24,4                          ; E high
_Write_lcd_nibble2:
 Bld R24,1                          ; RS flag,            spremenil Jaka <------------------
 Sbr R24,8                          ; E high
_Write_lcd_nibble3:
Ret
[END]
[_CLS]
_Cls:
  Rcall _Lcd_control
  *BASIC: waitms 3
[END]
Poglej proti koncu knjižnjice, kaj sem spremenil.
Torej, sedaj je RS PortB.1.
V priponki imaš lcd4e2s lib in prevedeno lbx, ki ju razpakiraš v mapo Bascom-AVR\LIB
in jo potem vključiš v svoj program z $LIB "LCD4E2S.LBX".
Na koncu sem dodal s (spremenjena), da ne boš originalne povozil.
lcd4e2s.rar
 Ime datoteke:  lcd4e2s.rar
 Velikost datoteke:  2.19 KB
 Downloadano:  3 krat
marko11
Prispevkov: 866
Aktiv.: 3.88
Kraj: Dobrepolje
PrispevekObjavljeno: Ned Jan 28, 2018 11:37 am    Naslov sporočila:   Odgovori s citatom
@Jaka Sem preizkusil popravljeno Lib, pa NE deluje. Mogoče je potrebno še kje kaj spremeniti.
Jaka hvala za trud. Pač sedaj sem predelal vezje, čeprav ni videti lepo, deluje pa po originalni datoteki.
lp,
Če ne veš kam greš, se ne moreš zgubiti.
blay44
Prispevkov: 603
Aktiv.: 3.71
PrispevekObjavljeno: Ned Jan 28, 2018 7:43 pm    Naslov sporočila:   Odgovori s citatom
Jaka57 ti je prepustil še popravek RW pina.
Prispevkov: 5773
Aktiv.: 25.90
PrispevekObjavljeno: Ned Jan 28, 2018 9:14 pm    Naslov sporočila:   Odgovori s citatom
RW pin MCUja ni vezan na LCD, res pa je, da nisem gledal, kaj se po spremembi dogaja v kodi, oz.,
če še kateri del kode vpliva na Rs pin po spremembi Rs=PortB.1.
Ja in vpliva.
Cbr R24,10 postavi PortB.1(ki je sedaj naš Rs pin) na 0, kar pomeni, da je LCD v ukaznem in ne podatkovnem načinu,
prav tako pa tudi Cbr R24,6, torej je potrebno spremeniti:
Cbr R24,10 v Cbr R24,9 (PortB.3(E2) in PortB.0(RW) bosta 0),
Cbr R24, 6 v Cbr R24,5 (PortB.2(E) in PortB.0(RW) bosta 0).
Spodaj je del, ki je spremenjen:
Koda:
;data passed in r24
[_Write_lcd]
_Write_lcd:
_Lcd_control:
_Write_lcd_Byte:
_Write_lcd_nibble:
* Lds R2,{___LCDE}
 Tst R2
 Bld R24,1                          ; RS flag           <---------- Spremenil Jaka
 Sbr R24,4                          ; E high
 Cbr R24,9                          ; E2 and RW low     <---------- Spremenil Jaka
_Write_lcd_nibble2:
 Sbr R24,8                          ; E high
 Cbr R24,5                          ; E1 and RW low     <---------- Spremenil Jaka
_Write_lcd_nibble3:
Ret
[END]
Marko, s katero Mego se to špilaš?
V prilogi je popravljena knjižnjica lcd4e2s.
lcd4e2s.rar
 Velikost datoteke:  2.22 KB
 Downloadano:  1 krat
marko11
Prispevkov: 866
Aktiv.: 3.88
Kraj: Dobrepolje
PrispevekObjavljeno: Pet Feb 02, 2018 11:26 am    Naslov sporočila:   Odgovori s citatom
Jaka še enkrat hvala.
Sem predelal PCB ploščo, tako da deluje na original knjižnico.
Sedaj delam z Mega128.
Ko bo prilika pa bom sprobal na testni plošči tvojo prenovljeno knjižnico.
Lp,marko
Uptime: 74 dni
