UVC sijalke?
ule
Prispevkov: 1583
Aktiv.: 6.66
Kraj: Babno Polje
PrispevekObjavljeno: Sre Jan 08, 2020 10:42 pm    Naslov sporočila:  UVC sijalke? Odgovori s citatom
Govora je o teh sijalkah
Zanima me, če ima kdo kakšne izkušnje z dezinfekcijo prostorov (ali pozna koga)? Koliko sijalk bi potreboval in koliko časa bi morale svetiti za dezinfekcijo prostora, velikega 5m x 5m x 3m?
lucca brassi
Prispevkov: 4225
Aktiv.: 17.79
Kraj: KOČEVJE
PrispevekObjavljeno: Pet Jan 10, 2020 9:16 am    Naslov sporočila:   Odgovori s citatom
"Even at the minimum acceptable irradiance in a biosafety cabinet of 40 W/cm2 (U.S. Department of Health and Human Services et al., 2000), it takes 12.5 minutes to reach 30,000 J/cm2 (1 W= 1 J/sec), which has been listed as germicidal for spore forming organisms by one UV manufacturer (www.uvp.com/pdf/ab-115.pdf)."
"Even using the NIH/CDC criterion of the minimum acceptable irradiance in a biosafety cabinet
of 40 W/cm2, it takes 12.5 minutes to reach the 30,000 J/cm2 found to inactivate spore forming organisms.
Use of a UV light in excess of an hour or overnight is massive overkill." from: http://www.ehs.ucsb.edu/files/docs/bs/Meechan_and_Wilson_2006.pdf
We typically leave the light on for 10 minutes prior to use, although after reading this, I'll up that to 15 minutes. '' potem pa jo premakneš po vseh kotih pa si dober z eno uro .
To moram naredit tudi jaz za našo hladilnico. Samo ko pomijemo hladilnico ( tudi sedaj v tem času je mokra in se potem suši (pa predprostor ni ogrevan )
Jasno je da ne smeš imeti mrtvih kotov , zato je fino da je svetilka premična v stilu
http://microchemlab.com/test/uv-room-disinfection-devices
https://www.cureuv.com/products/germawayuv-table-top-uvc-surface-sterilizer
ule
Prispevkov: 1583
Aktiv.: 6.66
Kraj: Babno Polje
PrispevekObjavljeno: Pet Jan 10, 2020 11:26 pm    Naslov sporočila:   Odgovori s citatom
Hvala. Sicer so v članku omenjeni "mikro" watt in "mikro" joule. Verjetno forum ne dopušča črke mi
joztom
Prispevkov: 275
Aktiv.: 2.95
PrispevekObjavljeno: Sob Jan 11, 2020 11:05 am    Naslov sporočila:   Odgovori s citatom
Poišči še LED izvire svetlobe za tak namen.
qwertz
Prispevkov: 2756
Aktiv.: 13.24
Kraj: Vrhnika
PrispevekObjavljeno: Tor Jan 14, 2020 7:15 pm    Naslov sporočila:   Odgovori s citatom
https://uvc-solutions.com/sl/
Tole delajo pri nas. Mogoče se obrni na njih za info.
Seveda forum podpira grško črko mi:
Greek letter μ or legacy micro symbol µ (oboje dela ne vem pa zakaj ima forum sliko simbola).
mmat
Pridružen-a: Ned 19 Jan 2020 12:52
Prispevkov: 20
Aktiv.: 0.30
PrispevekObjavljeno: Ned Jan 19, 2020 4:04 pm    Naslov sporočila:   Odgovori s citatom
Bi se obneslo v praksi za uničevanje pršič?
Sam sem skeptičen, ker so pršice tudi v jogiju in ne samo na njem.
Kaj pa kakšna mini enota za v čevlje - razkuževanje glivic?
Ima kdo kaj izkušenj?
