borber Član
Pridružen-a: Pon 23 Maj 2005 8:40 Prispevkov: 3111 Aktiv.: 13.11 Kraj: LJUBLJANA
Objavljeno: Sob Dec 01, 2007 10:36 am Naslov sporočila: 160 projektov |
Tu je 160 projektov in člankov iz revije S i l i c o n c h i p:
http://rapidshare.com/files/73482863/silicagel.part1.rar
http://rapidshare.com/files/73484620/silicagel.part2.rar
http://rapidshare.com/files/73487737/silicagel.part3.rar
http://rapidshare.com/files/73490548/silicagel.part4.rar
http://rapidshare.com/files/73491112/silicagel.part5.rar
geslo: mala_vas
vsega je okoli 250MB
vsebina:
10-Channel IR Remote Control Receiver
12-channel Infrared Remote Control
12V Flourescent Lamp Inverter
2.4ghz antenna
240V Mains Filter For Hifi Systems
4 Digit Crystal-Controlled Timing Module
4-Minute Shower Timer
45-Second Voice Recorder Module
50-Watt DC Electronic Load
50mhz frequency meter
6-Channel IR Remote Volume Control - Part 2
9V battery replace
A 2.4GHz High-Power Audio-Video Link
A Digital ThermometerThermostat
A Dirt-Cheap, High Current Power Supply
A Low Cost Audio-Video Distribution Amplifier
A Low-Cost 50MHz Frequency Meter
A Poor Man's Q Meter
A Programmable Continuity Tester
A Programmable PIC-Powered Timer
A Real Yagi Antenna For UHF CB
A Rolling Code 4-Channel UHF Remote Control
A Shielded Loop Antenna For DX AM Reception
Active 3-Way Crossover for Loud Speaker Systems
Adjustable DC-DC Converter For Cars
Alternative Power Regulator
An RFID Security Module
Appliance Energy Meter
Automatic Single-Channel Light Dimmer
Balanced Microphone Preamp
Bidirectional Motor Speed Controller
Big-Digit 1224 Hour Clock
Bringing a dead cordless drill back to life
Build A V8 Doorbell
Build A Water Level Indicator
Build An AVR ISP Serial Programmer
Build The Decision Maker
Bulid Your Seismograph
Car Battery Monitor
Carbon Monoxide Alarm
Charger
Charger For Deep-Cycle 12V Batteries
Compact 0-80A Automotive Ammeter
Component video to RGB converter
Courtesy Light Delay For Cars
Current Clamp Meter Adaptor for DMMs
D-I-Y remote control for a model train layout
Digital Instrument Display for Cars
Direct Conversion Receiver For Radio Amateurs - Part 1
Direct Conversion Receiver For Radio Amateurs - Part 2
Dr Video Mk.2 An Even Better Video Stabiliser
Driving Light and Accessory Protector for Cars
ESR Meter Mk.2
ESR Meter Mk.22
ESR Meter Mk_2
Fridge-Door Open Alarm
Heartbeat CPR Training Beeper
High Voltage Megohm Tester
High-efficiency power supply For 1W Luxeon Star LEDs
Home-Brew Weatherproof 2.4GHz WiFi Antennas
IR Remote Control Checker
Improved Speed Controller for Universal Motors
Inductance & Q-Factor Meter
Inductance & Q-Factor Meter; Part 1+2
Lapel microphone adaptor for PA systems
Lead-Acid Battery Zapper
Level meter for home theatre systems
Linear Supply For Luxeon 1W Star LEDs
Long-Range 4-Channel UHF Remote Control
Long-range 16-channel Remote Control System
MIDI Theremin, Part 2
MUDLARK A205 Valve Stereo Amplifier
More Fun With The PICAXE - Part 3 Heartbeat Simulator
More Fun With The PICAXE - Part 4 Motor Controller
More Fun With The PICAXE - Part 5 A Chookhouse Door Controller
More Fun With the PICAXE A Shop Door Minder
Never buy another 9V battery
OLED Displays Better Than Plasma Or LCD
Oh no Not Another CFL Inverter
One-chip Transceivers for easy UHF Data Communications
PC Infrared Remote Receiver
PIC Controlled 32-LED Knightrider
PICAXE Application Special PICAXE 08 Port Expansion
PICAXE Application Special PICAXE Telephone
PICAXE Infrared Remote Control
PICAXE The New Millennium 555
Picaxe-18X 4-channel datalogger
Poor Man's Metal Locator
PortaPAL Public Address System - Part 2
Portable PIC Programmer
Printer Port Hardware Simulator
Programmable Flexitimer
RFID Tags - How They Work
Regulated High-Voltage Supply For Valve Amplifiers
Remote Volume Control For Stereo Amplifiers
Remote Volume Control For the Ultra-LD Amplifier
Remote-Controlled Automatic Table Lamp Dimmer
SMS Controller
SMS Controller\SMS Controller, Part 1
SMS Controller\SMS Controller, Part 2
Serial Stepper Motor Controller
Shut That Mutt
Simon Says
Simple Alcohol Level Meter
Smart Card Reader and Programmer
Smart-Slave Flash Trigger
Solar Powered Wireless Weather Station
Starpower - A Switching Supply For Luxeon Star LEDs
Studio 350 Power Amplifier Module
Studio Series Stereo Headphone Amplifier
Sunset Switch
Super Speedo Corrector
SuperCharger Addendum
SuperCharger For NiCd & NiMH Batteries
Telephone Dialler For Burglar Alarms
Telephone Headset Adaptor
Test Your Reaction Times With A Digital Reaction Timer
The Battery Guardian
The Coolmaster FridgeFreezer Temperature Controller
The Mesmeriser Circular Clock
The Micromitter Stereo FM Transmitter
The PICAXE Part 6 - Data Communications
The PICAXE Part 8 - A Datalogger and Sending it to Sleep
The PICAXE- Part 9 Keyboards 101
Three Do-It-Yourself PIC Programmer Kits
Tiptronic-StyleGear Indicator
Touch Dimmer
TwinTen Stereo Amplifier
UHF Prescaler For Frequency Counters
USB Power Injector
USB Power Supply
USB-Controlled Power Switch
Ultra-LD 2x100W Stereo Amplifier Pt_1
Ultra-LD 2x100W Stereo Amplifier pt_2
Updating the PIC Programmer and Checkerboard
VU-Peak Meter With LCD Bargraphs
Versatile Micropower Battery Protector
Versatile Multi-Mode Timer
Video Enhancer & YC Separator
Video Formats Why Bother
Video-Audio Booster For Home Theatre Systems
Weather Satellites VHF Receiver
Weather satellites Antenna & RF preamp
What You Need To Receive Weather Satellite Images
Whistle & Point Cable Tracer
White LED Driver
WiFry Cooking up 2.4 GHz Antennas
Windows Based EPROM Programmer
Windows Based EPROM Programmer\Windows-Based EPROM Programmer - Part 1
Windows Based EPROM Programmer\Windows-Based EPROM Programmer - Part 2
antenna&preamplifier for weather satellite
appliance power meter
ballanced microfone
circuit notebooks
direct conversion rx
esr meter
high voltage power supply
motorised ir remote
q meter
shorted turns tester
weather satellite receiver |
Domenius Član
Pridružen-a: Sre 30 Nov 2005 14:15 Prispevkov: 1188 Aktiv.: 5.01 Kraj: Medvode
Objavljeno: Sob Dec 01, 2007 12:07 pm Naslov sporočila: |
Še nasvet za odpravo omejitev downloada - po vsaki prenešeni datoteki prekinite povezavo, malo počakajte in se še 1x povežite. Tako dobite nov IP in je spet treba počakati samo 1,6 minute namesto 50 ali več. To deluje samo pri dinamičnem IPju. _________________ It's electric! |
zajec Član
Pridružen-a: Čet 07 Dec 2006 19:03 Prispevkov: 34 Aktiv.: 0.15 Kraj: slovenske konjice
Objavljeno: Sob Dec 01, 2007 2:28 pm Naslov sporočila: |
Hvala za dober nasvet.
L.P. Zajec |
jur Član
Pridružen-a: Pet 02 Dec 2005 14:45 Prispevkov: 5142 Aktiv.: 21.67 Kraj: [color=zelena]Ljubljana[/color]
Objavljeno: Sob Dec 01, 2007 4:29 pm Naslov sporočila: |
Uh, ali ne bi blio bolje, če bi nekdo, ki je tole že dol pobral, poslal na filemanager...??
Jur |
borber Član
Objavljeno: Sob Dec 01, 2007 4:52 pm Naslov sporočila: |
V direktorijih so tudi večje slike, ki se ne odprejo skupaj s htm. Ime se jim konča z mg.
Probal bom omogočiti direkten download, da ne bo čakanja.
Sporočite kako je z downloadom sedaj. |
ro-bi Član
Pridružen-a: Ned 28 Jan 2007 16:53 Prispevkov: 3580 Aktiv.: 15.97
Objavljeno: Sob Dec 01, 2007 5:01 pm Naslov sporočila: |
Sem našel večje slike in zato zbrisal prejšnji post.
Gre kar hitro dolpotegnit. Hvala za vse to
lp _________________ 3 x 3 = 9 |
branko47 Član
Pridružen-a: Sob 07 Jan 2006 11:10 Prispevkov: 164 Aktiv.: 0.69 Kraj: Pozarevac
Objavljeno: Sob Dec 01, 2007 5:05 pm Naslov sporočila: |
Sedaj je super  |
ro-bi Član
Objavljeno: Sob Dec 01, 2007 6:26 pm Naslov sporočila: |
S katerim programom se odpre .eps file? _________________ 3 x 3 = 9 |
borber Član
Objavljeno: Sob Dec 01, 2007 6:34 pm Naslov sporočila: |
.eps je Encapsulated Post Script filet. Za odpiranje običajno uporabljamo Ghostview. Odpre ga tudi IrfanView. |
protoncek Član
Pridružen-a: Sre 31 Jan 2007 9:41 Prispevkov: 9573 Aktiv.: 42.72 Kraj: Mengeš
Objavljeno: Ned Dec 02, 2007 12:17 pm Naslov sporočila: |
DOMENIUS...odličen nasvet za nekatere, za druge napačen...T2 recimo ti zamenja IP če si 24 ur neprekinjeno nepovezan, tako da je hitreje počakat 100 minut kot 24 ur...
res bi eden lahko to dal na filemanager.  |
ro-bi Član
Objavljeno: Ned Dec 02, 2007 1:54 pm Naslov sporočila: |
protoncek je napisal/a: |
Čudno! Meni je takoj direkt iz linkov potegnilo, le prvi del sem cuzal od tam!? _________________ 3 x 3 = 9 |
Domenius Član
Objavljeno: Ned Dec 02, 2007 2:42 pm Naslov sporočila: |
DOMENIUS...odličen nasvet za nekatere, za druge napačen...T2 recimo ti zamenja IP če si 24 ur neprekinjeno nepovezan, tako da je hitreje počakat 100 minut kot 24 ur... |
Siol prav tako. Če pa se povezava prekine prej kot v 24 urah ne obdržiš starega IPja ampak dobiš novega. _________________ It's electric! |
protoncek Član
Objavljeno: Ned Dec 02, 2007 2:52 pm Naslov sporočila: |
hm...sem narobe napisal...T2 ti zamenja IP SAMO če si več kot 24 ur prekinjen. Jaz imam isti IP že par mesecev, ker imam router ki je stalno povezan na net. Zato mi ta finta ne deluje. Če v routerju prekinem povezavo, počakam lahko tudi par ur, se mi poveže na isti IP, razen, kot rečeno, če bi čakal vsaj 24 ur...
ro-b-->linkov? saj linki so direkt do rapidshare... v tem je problem. |
Domenius Član
Objavljeno: Ned Dec 02, 2007 3:06 pm Naslov sporočila: |
Jaz sem pa bolj površno prebral in je nastala zmeda.  _________________ It's electric! |
protoncek Član
Objavljeno: Ned Dec 02, 2007 3:11 pm Naslov sporočila: |
neeee...
sicer smo pa vajeni čakanja samo malce čudno si napisal pa nisem vedel kaj misliš...čeprav vem da Siol načeloma zelo hitro menja IP-je. To je lahko dobro, po drugi strani pa tudi ne...meni je sicer vseeno, samo ob takih stvareh kot tale...  |
