Programiranje v bascom avr
Pojdi na stran Prejšnja  1, 2, 3, 4 ... 36, 37, 38  Naslednja
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Bascom sekcija
vilko
Prispevkov: 3363
Aktiv.: 14.17
Kraj: Dragomer
PrispevekObjavljeno: Sob Apr 26, 2008 11:09 am    Naslov sporočila:  Točno Odgovori s citatom
Točno, le da ne smeš imeti byte spremenljivke ampak odgovarjajoče večje, da bo tudi največje število, ki nastopa v računu šlo v spremenljivko.
Janez Menart
program_er
Prispevkov: 2173
Aktiv.: 10.31
Kraj: Maribor (Pohorje)
PrispevekObjavljeno: Sob Apr 26, 2008 11:41 am    Naslov sporočila:   Odgovori s citatom
Pa sem iskal v helpu, pa nisem našel kake tabele ali pa kaj, kjer bi pisalo, katera spremenljivka lahko ima koliko števk. Ker jaz ponavadi dam kar nekaj "na blef" pol pa preizkušam, kako daleč gre... A ima kdo to tabelo?
Pa če pri 8-bitnem ADC-ju delim z 256, z koliko morem delit pri 10-bitnem ADC-ju?
vilko
Prispevkov: 3363
Aktiv.: 14.17
Kraj: Dragomer
PrispevekObjavljeno: Sob Apr 26, 2008 5:42 pm    Naslov sporočila:  Eh, Odgovori s citatom
v Helpu piše med 'Language fundametals' tudi sledeče:
Data Types
Every variable in BASCOM has a data type that determines what can be stored in the variable. The next section summarizes the elementary data types.
Elementary Data Types
Bit (1/8 byte). A bit can hold only the value 0 or 1. A group of 8 bits is called a byte.
Byte (1 byte). Bytes are stores as unsigned 8-bit binary numbers ranging in value from 0 to 255.
Integer (two bytes). Integers are stored as signed sixteen-bit binary numbers ranging in value from -32,768 to +32,767.
Word (two bytes). Words are stored as unsigned sixteen-bit binary numbers ranging in value from 0 to 65535.
Long (four bytes). Longs are stored as signed 32-bit binary numbers ranging in value from -2147483648 to 2147483647.
Single. Singles are stored as signed 32 bit binary numbers. Ranging in value from 1.5 x 10^–45 to 3.4 x 10^38
Double. Doubles are stored as signed 64 bit binary numbers. Ranging in value from 5.0 x 10^–324 to 1.7 x 10^308
String (up to 254 bytes). Strings are stored as bytes and are terminated with a 0-byte. A string dimensioned with a length of 10 bytes will occupy 11 bytes.
Odgovor na zadnje vprašanje je 1024
Janez Menart
program_er
Prispevkov: 2173
Aktiv.: 10.31
PrispevekObjavljeno: Sob Apr 26, 2008 9:13 pm    Naslov sporočila:  Re: Eh, Odgovori s citatom
vilko je napisal/a:
Aha, se pravi da je pri 10-bitnem ADC-ju račun takšen:
&H80 = Zy <--neka cifra (če mi to vrže v programu)
Zy x referenčna napetost = Rz
Rz x 1000 (ne 10) = Kp
Kp : 1024 = mV
V tem primeru sem dal kar neke spremenjlijke, ker nisem vedel točnih cifer. Zahvala, da zdaj to razumem (delno) gre @vilkotu! Hvala.
videosony
Pridružen-a: Čet 15 Nov 2007 1:32
Prispevkov: 21
Aktiv.: 0.10
PrispevekObjavljeno: Sre Apr 30, 2008 4:17 pm    Naslov sporočila:   Odgovori s citatom
Da ne odpiram nove teme bom kar tu vprašal.
Kako v bascomu napisat program da bo bral podatke iz SPI vodila enega drugega vezja ki pošilja binarne podatke 0 do 1023.
Pogledal sem literaturo o SPI pa mi je približno jasno delovanje, samo meni program noče delat-brat.
Rad bi prebral prek hardware SPI in izpisal na LCDju.
Config Lcdpin = Pin , Db4 = Porta.4 , Db5 = Porta.5 , Db6 = Porta.6 , Db7 = Porta.7 , E = Portd.6 , Rs = Portd.4
Dim I As Byte
Config Lcd = 16 * 2
Initlcd
Cls
Spiinit
Do
Waitms 50
Spiin I , 1
Cls
Lcd I
Loop
End
probal sem tudi ta prog:
' SPI-SLAVE.BAS
' (c) MCS Electronics
' sample shows how to create a SPI SLAVE
' use together with sendspi.bas
' Tested on the STK500. The STK200 will NOT work.
' Use the STK500 or another circuit
$regfile = "m16def.dat"
Dim B As Byte , Rbit As Bit , Bsend As Byte
'First configure the MISO pin
Config Pinb.6 = Output ' MISO
'Then configure the SPI hardware SPCR register
Config Spi = Hard , Interrupt = On , Data Order = Msb , Master = No , Polarity = Low , Phase = 0 , Clockrate = 128
'Then init the SPI pins directly after the CONFIG SPI statement.
Spiinit
Cls
'specify the SPI interrupt
On Spi Spi_isr Nosave
'enable global interrupts
Enable Interrupts
'show that we started
Lcd "start"
Wait 1
Spdr = 0 ' start with sending 0 the first time
Do
If Rbit = 1 Then
Lcd "r" ; B
Reset Rbit
Bsend = Bsend + 1 : Spdr = Bsend 'increase SPDR
End If
' your code goes here
Waitms 100
Cls
Loop
'Interrupt routine
'since we used NOSAVE, we must save and restore the registers ourself
'when this ISR is called it will send the content from SPDR to the master
'the first time this is 0
Spi_isr:
push r24 ; save used register
in r24,sreg ; save sreg
push r24
B = Spdr
Set Rbit ' we received something
pop r24
!out sreg,r24 ; restore sreg
pop r24 ; and the used register
Return
rene_9
Pridružen-a: Sob 01 Mar 2008 16:13
Prispevkov: 64
Aktiv.: 0.30
PrispevekObjavljeno: Tor Maj 06, 2008 10:18 pm    Naslov sporočila: icon_question Štetje pristiskov tipke Odgovori s citatom
Zdravo
Da ne bom nove teme odpiral bom kar tu vprašal.Pgogram bi naj štel število pritiskov tipke in ob vsakem pritisku naredil določeno stvar. Bascom pa mi javo 2 napaki in ne vem kaj bi blo narobe, pa sem gledo help pa nisem najdo rešitve za napaki:
Error:7 Line:67 IF THEN expectet[67]
Error:269 Line:67 END SELECT expectet
Program ja je sledeč:
$regfile = "m8515.dat"
$crystal = 12000000
Config Debounce = 40
Dim Stevec As Byte
Config Porta = Input
Config Portb = Output
Tipka1 Alias Pina.0
Led1 Alias Portb.0
Led2 Alias Portb.1
Zacetek:
Do
Debounce Tipka1 , 0 , Vklop
Loop
Vklop:
Incr Stevec
If Stevec = 3 Then
Stevec = 0
Goto Izbira
Izbira:
Select Case Stevec
Case 0 : Goto Prog1
Case 1 : Goto Prog2
Case 2 : Goto Prog3
Prog1:
Set Led1
Prog2:
Do
Reset Led1
Wait 1
Set Led1
Wait 1
Set Led2
Loop
Prog3:
Do
Set Led2
Wait 1
Set Led1
Wait 1
Loop
Goto Zacetek
igo
Prispevkov: 3641
Aktiv.: 15.98
PrispevekObjavljeno: Tor Maj 06, 2008 11:36 pm    Naslov sporočila: icon_question Re: Štetje pristiskov tipke Odgovori s citatom
rene_9 je napisal/a:
$crystal = 12000000
Dim Stevec As Byte
Tipka1 Alias Pina.0
Led1 Alias Portb.0
Led2 Alias Portb.1
Zacetek:
Do
Loop
Vklop:
Incr Stevec
If Stevec = 3 Then
Stevec = 0
End If
Goto Izbira ' tega ni treba
Izbira:
Select Case Stevec
Case 0 : Goto Prog1
Case 1 : Goto Prog2
Case 2 : Goto Prog3
Prog1:
Set Led1
Goto Zacetek
Prog2:
Reset Led1
Wait 1
Set Led1
Wait 1
Set Led2
Goto Zacetek
Prog3:
Set Led2
Wait 1
Set Led1
Wait 1
Goto Zacetek
V "Vklop: " si pozabil na "End If" . Pa preden vprašaš, zakaj se program povsem zaplete, kar tega popravljenega uporabi. Pa še kak "Reset Led2 in Led1 " dodaj, da bo vedno definirano, kaj naj se zgodi.
LP,
Igor
LP, Igor
Pobesneli
Prispevkov: 1070
Aktiv.: 5.02
Kraj: Ajdovščina
PrispevekObjavljeno: Sre Maj 07, 2008 12:01 am    Naslov sporočila:   Odgovori s citatom
za tem delom
Select Case Stevec
Case 0 : Goto Prog1
Case 1 : Goto Prog2
Case 2 : Goto Prog3
manjka tudi End select
Pobesneli
Prispevkov: 1070
Aktiv.: 5.02
Kraj: Ajdovščina
PrispevekObjavljeno: Sre Maj 07, 2008 12:05 am    Naslov sporočila:   Odgovori s citatom
Sedaj mam pa še jaz eno vprasanje..in sicer z 1wire DS1820.Zanima me kako se preveri koliko senzorjev je na vodilu in kako se potem prebere vsakega posebaj.
rabim kak namig Wink
Zanima me če ima kdo tiste primere iz Bascom seminarja (pdf),glede teh senzorjev.
Ker v pdfju jih ni.
rene_9
Prispevkov: 64
Aktiv.: 0.30
PrispevekObjavljeno: Sre Maj 07, 2008 12:45 pm    Naslov sporočila:   Odgovori s citatom
Hvala.
Bom popravo, kaj se pa tiče pdf-ja iz Bascom seminarja pa ti ga lahko na e-mail pošljem.
Pobesneli
Prispevkov: 1070
Aktiv.: 5.02
Kraj: Ajdovščina
PrispevekObjavljeno: Sre Maj 07, 2008 6:49 pm    Naslov sporočila:   Odgovori s citatom
seminar iz bascoma že imam.rabim le tiste primere ki naj bi pokazali delovanje 1wire
Kopirano iz Pdf-ja:
Program DS1820-5 je primer branja temperature konkretnega termometra
Program DS1820-6 je primer branja temperature iz treh termometrov.
če ima kdo ?
tozir
Pridružen-a: Pon 17 Mar 2008 19:10
Prispevkov: 187
Aktiv.: 0.89
Kraj: Celje
PrispevekObjavljeno: Sre Maj 07, 2008 10:40 pm    Naslov sporočila:   Odgovori s citatom
http://datasheets.maxim-ic.com/en/ds/DS18S20.pdf
na začetku, pod drugo točko:
Koda:
Each device has a unique 64-bit serial code stored in an onboard ROM
na strani 5 imaš pa zgradbo tega registra razloženo. npr. jaz bi šel preverjat koliko različnih vrednosti teh registrov pa imam, ter bi iz tega sklepal koliko senzorjev je priključeno. samo ideja Wink
http://www.rielektronika.comule.com/
Prispevkov: 5536
Aktiv.: 24.04
PrispevekObjavljeno: Čet Maj 08, 2008 12:52 pm    Naslov sporočila:   Odgovori s citatom
Programi, ki smo jih uporabili na seminarju ...
LP, Grega
seminar.zip
 Ime datoteke:  seminar.zip
 Velikost datoteke:  46.34 KB
 Downloadano:  185 krat
Pobesneli
Prispevkov: 1070
Aktiv.: 5.02
Kraj: Ajdovščina
PrispevekObjavljeno: Čet Maj 08, 2008 10:22 pm    Naslov sporočila:   Odgovori s citatom
o hvala,to sem potreboval Wink
program_er
Prispevkov: 2173
Aktiv.: 10.31
PrispevekObjavljeno: Pet Maj 09, 2008 8:13 am    Naslov sporočila:   Odgovori s citatom
Pozdravljeni, spet jaz! Laughing
Zdaj tisto z ADC-jem razumem! Ampak tisto deluje samo, če mam naprimer fotoupor vezan men neko točno določeno npetostjo in enim pinom uC-ja.
Kaj pa če si jaz hočem narediti merilec napetosti baterij, in le to prikazovati na dveh 7-segmentnih prikazovalnikih ali LCD-ju?
To pa potem mora biti drugače zasnovano... Kaj lahko odgovori kdo, ki se ukvarja z Bascomom in AVR-ji (ATmega16) in to točno ve?
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Bascom sekcija Časovni pas GMT + 2 uri, srednjeevropski - poletni čas
Stran 3 od 38
Uptime: 3 dni
