Programiranje v bascom avr
Pojdi na stran Prejšnja  1, 2, 3 ... 6, 7, 8 ... 36, 37, 38  Naslednja
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Bascom sekcija
program_er
Prispevkov: 2173
Aktiv.: 11.12
Kraj: Maribor (Pohorje)
PrispevekObjavljeno: Sob Maj 17, 2008 3:19 pm    Naslov sporočila:   Odgovori s citatom
Malo sem spremenil kodo:
Koda:
$regfile = "m16def.dat"
$crystal = 1000000
Enable Adc
Config Portd.6 = Output
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db7 = Portd.0 , Db6 = Portd.1 , Db5 = Portd.2 , Db4 = Portd.3 , E = Portd.4 , Rs = Portd.5
Cursor Off
Osvetlitev Alias Portd.6
Osvetlitev = 1
Config Adc = Single , Prescaler = Auto , Reference = Off
Start Adc
Dim W As Word , Rz As Word , Kp As Word , Rezultat As Single , Channel As Byte
Channel = 0
'now read A/D value from channel 0
'Aha, se pravi da je pri 10-bitnem ADC-ju račun takšen:
'&H80 = W <--neka cifra (če mi to vrže v programu)
'W x referenčna napetost = Rz
'Rz x 1000 (ne 10) = Kp
'Kp : 1024 = Mv
Do
 W = Getadc(channel)
 Rz = W * 5.05
 Kp = Rz * 1000
 Rezultat = Kp / 1024
 Gosub Prikaz
 Incr Channel
 If Channel > 3 Then Channel = 0
Loop
Prikaz:
Cls
Home U
Lcd "ADC:" ; Channel ; " = " ; Rezultat
Wait 1
Return
End
'The new M163 has options for the reference voltage
'For this chip you can use the additional param :
'Config Adc = Single , Prescaler = Auto, Reference = Internal
'The reference param may be :
'OFF      : AREF, internal reference turned off
'AVCC     : AVCC, with external capacitor at AREF pin
'INTERNAL : Internal 2.56 voltage reference with external capacitor ar AREF pin
'Using the additional param on chip that do not have the internal reference will have no effect.
Pin AREF sem povezal z + 5V
Zdaj pa mi kaže kup decimalk.
Pa ista pesem. Če imam upore mi kaže vedno isto, 3.xxxxxxxx (ne vem točno) če pa so pini nepovezani, pa mi kaže različno
eddie
Prispevkov: 706
Aktiv.: 3.18
Kraj: Severna primorska
PrispevekObjavljeno: Sob Maj 17, 2008 6:33 pm    Naslov sporočila:   Odgovori s citatom
Če si upore vezal vsakega iz +5V pa na en pin ADC-ja nisi naredil prav nič! Napetost na vseh pinih je 5V.
Vzemi en potenciometer, zunanja pola veži na +5V in maso, srednji odcep pa na enega od vhodov adc-ja!
Tako boš videl spreminjanje vrednosti, ko boš vrtel potenciometer od 0 do maksimalne(zato ker bo napetost na pinu od 0 do 5V)!
Pini, ki so "v zraku" vedno kažejo neko vrednost, ki se spreminja.
Kanale, ki jih ne potrebuješ vežeš na maso in je.
program_er
Prispevkov: 2173
Aktiv.: 11.12
PrispevekObjavljeno: Sob Maj 17, 2008 9:01 pm    Naslov sporočila:  Re: Poizkusi tako, kot piše v help-u Odgovori s citatom
Hvala vam, deluje!
vilko je napisal/a:
In če hočeš napisati rezultat kot 5.0V potem moraš še ločiti desetinke od celih voltov v dve ločeni spremenljivki
Koda:
dim volti as word
dim desetinke as word
volti = W2 / 10
desetinke = W2 mod 10
print "Napetost je ";volti;".";desetinke;"V  "
Najbolje je, da probaš.
Tudi to odlično deluje, od 0.0 do 5.0 V.
Tu pa je moj kos računske kode:
Koda:
Config Adc = Single , Prescaler = Auto , Reference = Internal
Start Adc
Dim W As Word , Rz As Word , Kp As Word , Rezultat As Word , Channel As Byte , Volti As Word , Desetinke As Word
Channel = 0
Do
 W = Getadc(0)
 Rz = W * 5.45
 Kp = Rz * 10
 Rezultat = Kp / 1023
 Volti = Rezultat / 10
 Desetinke = Rezultat Mod 10
 Gosub Prikaz
 Loop
Prikaz:
 Cls
 Home U
  Lcd "ADC = " ; Volti ; "." ; Desetinke ; " V"
 Lowerline
  Lcd "ADC izvir:" ; W
 Waitms 500
Return
End
@Vilko, a lahko prosim pogledaš moj primer in mi poveš, kako bi naredil prikaz z dvema decimalkama, torej od 0.00 do 5.00 V.
Hvala!
program_er
Prispevkov: 2173
Aktiv.: 11.12
PrispevekObjavljeno: Sob Maj 17, 2008 9:10 pm    Naslov sporočila:   Odgovori s citatom
Ah, sem že "pogruntal". Dela mi odlično!
Imam pa en problem. Referenčne napetosti nimam vedno točno take, kot imam v programu napisano.
Ali obstaja kakšna nastavitev, da bi mi program avtomatsko množil moj račun - ne z 5.45 zgoraj - ampak z napetostjo, ki bi jo pripeljal na AREF pin, se pravi + okoli 5V. Tako bi imel vedno točen rezultat.
vilko
Prispevkov: 3351
Aktiv.: 15.09
Kraj: Dragomer
PrispevekObjavljeno: Sob Maj 17, 2008 9:13 pm    Naslov sporočila:  no Odgovori s citatom
No, analogno.
Če si desetinke dobil kot
Koda:
dim volti as word
volti = W2 / 10
potem boš vrednostnos s stotinkami dobil kot
Koda:
dim volti as word
dim stotinke as word
volti = W2 / 100
stotinke  = W2 mod 100
print "Napetost je ";volti;".";stotinke;"V  "
Prepričan sem, da je inteligentnih bitij v vesolju veliko. A ker so inteligenta, se nam nočejo prikazati.
program_er
Prispevkov: 2173
Aktiv.: 11.12
PrispevekObjavljeno: Ned Maj 18, 2008 10:38 am    Naslov sporočila:   Odgovori s citatom
Hvala vam! Vse mi dela. Nebi si mislil, da je to taka lahka stvar. Zdaj ko sem pogruntal mi je to nekaj najlažjega! Cool
Sem že naredil sledibota, sem dal fotoupor med ADC in +, pa še 10k upor med ta isti ADC in minus. Namesto motorjev pa sem dal ledice. Very Happy
Moja koda:
Koda:
Do
 W = Getadc(0)
 Rz = W * 5.45
 Kp = Rz * 10
' Rezultat = Rezultat * 10
 Volti = Rezultat / 10                                      ' Rezultat / 100
 Desetinke = Rezultat Mod 10                                'Mod 100
 If W > 600 Then Portc.7 = 0
 If W < 600 Then Portc.7 = 1
 Gosub Prikaz
Loop
Prikaz:
 Home U
 Lowerline
 Waitms 300
Return
End
Kot se vidi, imam If ukaze pred in po rutini Gosub Prikaz. Zakaj? Ko sem imel to samo pred tem ukazom, je bil odzivni čas uC-ja 300ms, ker subrutina Prikaz traja 300ms. To me je motilo. Zato pa imam vprašanje, če obstaja kaka zanka ali ukaz, ki bi vedno ponavljal ta ukaz, ampak med tem bi jaz v glavnem programu delal nekaj drugega. Z Do-Loop ne gre, ker je lahko v programu samo ena taka zanka. Ker ne morem jaz za vsakim Wait ukazom spet napisati ta dva ukaza ponovno. Ja, pa pomembno je, da bi se ta zanka izvajala med Wait ukazi!
Ne razumem pa, zakaj moj uC nikoli ni hotel poganjati servotov. Vse sem pravilno zvezal, kot piše v helpu, pa ne gre. Mogoče pa servo ne podpira krmiljenja preko uC? Uporabljam Standard HITEC HS-311 servo.
Hvala za odgovore!
poule
Prispevkov: 800
Aktiv.: 3.82
PrispevekObjavljeno: Ned Maj 18, 2008 9:02 pm    Naslov sporočila:   Odgovori s citatom
pozdravljeni,...končno sem se tudi jaz lotil s programiranjem,.....in prva težava.
uporabljam minipin in attiny2313.
ko hočem naložiti program mi javi napako:
ko jo potrdim mi javi še tole:
čip imam definiran takole:
programiram preko sample programatorja (LPT)
čip imam definiran tudi na začetku programa ($regfile = "ATTiny2313.dat")
Nekje sem najbrž nekaj spregledal v nastavitvah,da se mi ne poveže. Hvala za vsak nasvet.
dkone
Prispevkov: 2104
Aktiv.: 10.13
Kraj: Krško
PrispevekObjavljeno: Ned Maj 18, 2008 10:20 pm    Naslov sporočila:   Odgovori s citatom
To ti javlja,da nimaš pravilno povezan uC ter programator. Preveri še enkrat povezave,nastavitve imaš pravilno izbrane. Tako da je verjetno napaka na programatorju. Preveri če si pravilno poveza tiste signale miso,mosi,sck.....ter če si pravilno naredil programator.
Denis
poule
Prispevkov: 800
Aktiv.: 3.82
PrispevekObjavljeno: Ned Maj 18, 2008 10:37 pm    Naslov sporočila:   Odgovori s citatom
povezano imam (preverjeno) takole:
mi pa isto napako izpiše, če imam programator iztaknjen iz računalnika. Kako lahko preverim, če LPT sploh deluje?
dkone
Prispevkov: 2104
Aktiv.: 10.13
Kraj: Krško
PrispevekObjavljeno: Ned Maj 18, 2008 10:43 pm    Naslov sporočila:   Odgovori s citatom
Poglej rajši v Help bascoma,tam imaš lepo razloženo o tem sample programatorju,pa še za LPT konektor imaš lepo napisane številke Pina.
Denis
jurem
Pridružen-a: Tor 02 Dec 2003 15:53
Prispevkov: 408
Aktiv.: 1.84
PrispevekObjavljeno: Ned Maj 18, 2008 10:57 pm    Naslov sporočila:   Odgovori s citatom
V BIOS-u poglej vse možne LPT naslove in jih enega za drugim preizkusi v nastavitvah za Sample programmer.
Jure
poule
Prispevkov: 800
Aktiv.: 3.82
PrispevekObjavljeno: Ned Maj 18, 2008 10:59 pm    Naslov sporočila:   Odgovori s citatom
v help-u je napisano takole,
, v dokumentaciji za razvojno plato pa imam napisano:
konektor K6:
RST pin3
MOSI pin 8
MISO pin9
SCKpin10
GND pin2
Kako je pravilno?
jurem
Prispevkov: 408
Aktiv.: 1.84
PrispevekObjavljeno: Ned Maj 18, 2008 11:21 pm    Naslov sporočila:   Odgovori s citatom
poule je napisal/a:
konektor K6:
RST pin3
MOSI pin 8
MISO pin9
SCKpin10
GND pin2
Kako je pravilno?
K6 je IDC konektor, ne LPT.
Jure
poule
Prispevkov: 800
Aktiv.: 3.82
PrispevekObjavljeno: Pon Maj 19, 2008 6:33 am    Naslov sporočila:   Odgovori s citatom
Itak da je IDC, saj je vidno iz slike, par prispevkov višje. Na eni strani flat kabla je 10 pin IDC, na drugi 25pin D-sub (LPT).
poule
Prispevkov: 800
Aktiv.: 3.82
PrispevekObjavljeno: Pon Maj 19, 2008 6:52 pm    Naslov sporočila:   Odgovori s citatom
a moram kaj nastaviti tudi tukaj, oz. kako lahko s tem potipam, če je živ?
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Bascom sekcija Časovni pas GMT + 2 uri, srednjeevropski - poletni čas
Stran 7 od 38
Uptime: 48 dni
