lucca brassi Član
Pridružen-a: Ned 01 Feb 2004 12:46 Prispevkov: 4222 Aktiv.: 17.84 Kraj: KOČEVJE
Objavljeno: Pon Avg 24, 2009 8:14 am Naslov sporočila: CPU ventilator INTEL |
V soboto sem instaliral nov procesor Q9550 . Nisem uporabil stock hladilnika - oporabil sem starega zalmana 9500.
med instalacijo sem opazil da nove plošče imajo za CPU fan 4 pine - moj stari jih ima 3. Vtič sem postavil tako da je sedel v zarezo in pustil en pin nepokrit.
Ko sem prvič startal sistem , se mi postavi ekran od matične plošče (izhod v BIOS)
S tipkovnico nisem mogel pritisnit DEL da bi šel v BIOS natavit diske , niti nisem mogel vžgati LED za NUM , CAPS LOCK ali SCROLL- sem si mislilmogoče je s tipkovnico kaj narobe in sem jo vzel v službo da jo sprobam ( je PS2- čista klasika - tu deluje BP)
MB je ta
http://www.trustedreviews.com/motherboards/review/2008/10/08/Gigabyte-GA-EP45-DS3P/comments
Sedaj razmišljam ali bi bilo mogoče da ti novi ventilatorji , ki imajo termistor na 4 pinu ne dovaja plošči informacij ki bi jih moral pa zato blokira vse in se po cca 7s delovanja resetira? bi bilo to mogoče ali je za probat še kaj?
Boxed Intel processor thermal solution overview
As processor power has increased, required thermal solutions have generated more noise. Intel has added an option to the boxed processor that allows system integrators to have a quieter system in the most common usage.
Previous generation boxed Intel fan heatsinks contain built-in circuitry to control fan speed. They have a thermistor in the fan hub which measures the chassis ambient air temperature. The fan circuitry then adjusts the fan speed to properly cool the processor at the slowest speed allowable. If the chassis ambient temperature is cool, then the fan will run slower and quieter. If the ambient temperature is hot, the fan will run faster.
This fan has to work in a variety of operating conditions so it had to be designed in such a way that it would cool the processor when running at its maximum power at any given ambient temperature (up to 38°C). In normal operating environments the processor rarely reaches its maximum power rating.
Under most conditions the fan is spinning faster and louder than necessary. (The fan heatsink is required to work this way so that it will properly cool the CPU in all specified operating environments.)
Intel has been aware of customer concerns over increasing fan noise. Intel has now designed a new fan speed control technology to take advantage of the fact that the processor is not always running at its maximum power. This was done by basing the fan speed control on actual CPU temperature and power usage.
The speed of the new fan heatsink is controlled by the additional 4th wire of the fan cable. (The new technology is sometimes referred to as "4-wire fan speed control.")
The additional 4th wire sends a signal from the motherboard to the fan heatsink to control its speed. There is a thermal diode in the processor which measures actual CPU temperature. The processor sends information to the motherboard about its specific thermal requirements and the actual processor temperature. The motherboard then uses this information to optimally control the speed of the processor fan.
Figure 2 shows the current fan speed curve (red) of a 3-wire, fan heatsink-thermistor based fan speed control. The additional curves in blue represent fan operations at lower CPU temperature and power consumption levels based on the 4-wire fan speed control fan heatsink.
Figure 2. Internal chassis temperature effect on boxed processor variable speed fan heatsink noise
The "Max Temp" in Figure 2 represents the upper set point or worst case ambient temperature of 38°C. The "Min Temp" represents the lower set point or the slowest possible fan speed at an ambient temperature of 30°C. (See Table 1)
The acoustic benefits of the 4-wire based fan speed control may vary depending on the specific motherboard implementation. (The acoustic benefits are reliant on the motherboard implementation of fan speed control.)
Intel has recently developed a new revolutionary motherboard based fan speed control included with Intel 965 and Intel 963 chipset-based motherboards called Intel® Quiet System Technology (Intel® QST). This new technology uses a PID controller that can measure the rate of change of the processor temperature, thus predicting when the processor will reach its maximum temperature. If implemented correctly by the motherboard manufacturer, the control algorithm will operate the processor fan at minimum speed under most operating conditions. Since Intel QST can predict when the processor will reach its maximum temperature, it will delay increasing the fan speed until just the right moment in order to keep the processor from exceeding its maximum temperature. Consult your motherboard manufacturer to see which motherboards they offer with support for Intel QST.
A 4-wire fan does not guarantee a quieter system. If the processor is being used in a hot environment and under heavy loads the fan will have to run fast enough to properly cool the processor. The internal chassis temperature is required to be maintained at 38°C (or lower). Selecting the correct chassis (see Chassis Selection) and verifying proper thermal management is critical for integrating a high quality boxed Intel Core Quad processor-based system.
Table 1. Boxed processor variable fan heatsink set points
For boxed Intel® Core™ i7 processors in the 1336-land package
Internal Chassis Temperature (°C) Boxed Processor Fan Heatsink Set Points
X <= 301,2 Lower set point: Fan speed constant at lowest fan speed. Recommended temperature for nominal operating environment.
Y = 35 Recommended maximum internal chassis temperature for boxed Intel Core 2 Quad processor-based systems.
Z >= 391,2 Higher set point: Fan speed constant at highest fan speed.
1Set point variance is approximately ±1°C from fan heatsink to fan heatsink.
2DBX-A FHS does not use a thermistor, therefore upper and lower set points are not relevant. |
MarkoM Član
Pridružen-a: Tor 12 Sep 2006 15:29 Prispevkov: 2825 Aktiv.: 12.38 Kraj: Lovrenc na P.
Objavljeno: Pon Avg 24, 2009 10:03 am Naslov sporočila: |
Nisem poskušal priklopiti navadni ventilator na novi plošči. 4 pinski ventilatorji imajo PWM regulacijo. Mogoče si ga napačno priklopil in matična nima povratne informacije o delovanju ventilatorja. Drgače pa bi jaz kar uporabil original hladilnik/ventilator, je relativno tiho, če ga v biosu nastaviš na silent mode. |
Pyr0Beast Član
Pridružen-a: Pon 16 Jun 2008 14:11 Prispevkov: 4969 Aktiv.: 24.03
Objavljeno: Pon Avg 24, 2009 12:51 pm Naslov sporočila: |
4 in 3 pin naj bi bili združljivi. 4 pinski konektor je kot tri pinski z dodanim enim pinom, to je, da imaš še plastični zatič kot na starem konektorju in tam zatakneš tisti 3 pinski konektor.
Težava bi bila lahko tudi v disku ali cd-romu odklopi če jih ne rabiš in ustrezno skonfiguriraj bios. |
Azrael Član
Pridružen-a: Čet 29 Jan 2009 19:46 Prispevkov: 4432 Aktiv.: 22.25 Kraj: Gorje
Objavljeno: Pon Avg 24, 2009 1:15 pm Naslov sporočila: |
Koliko je stara tipkovnica?
Namreč nekatere plošče novejšega datuma ne delujejo s starejšimi tipkovnicami, npr Asus Commando. pa tudi mnogo novejših Asrock plošč ne deluje skupaj s tipkovnico Cherry G80 iz leta 1995. Oboje brezhibno, vendar ne več združljivo.
BIOS ne javi nobene napake (da bi bilo s tipkovnico kaj narobe), samo tipkovnica ne dela. Na nekaterih ploščah pa ta tipkovnica dela v BIOSu, toda ne v OS, brez izjeme, ne v DOS, Windows ali Linux.
Razni čungalunga približki tipkovnic, ki nudijo enak občutek kot radirke na ZX Spectrum, pa začuda delajo povsod. |
lucca brassi Član
Objavljeno: Pon Avg 24, 2009 2:01 pm Naslov sporočila: |
Ja tipkovnica je zelo cenena po tem ko sem ponesreči polil Keytronic .
Zelo me je presenetilo tudi to ker - ko sem hotel preverit kako vtikač stoji pa sem ga izvlekel in ponovno vstavil sem opazil rahle iskrice ( ne dabi delal kratek stik med maso in pini ) To se mi je zgodilo prvič !!!
Bom poskusil s službenim Logitech Internet 350 Keyboard pa poročam _________________ Moments before detonation ,....... TT |
lucca brassi Član
Objavljeno: Pon Avg 31, 2009 7:23 am Naslov sporočila: |
No rešil težavo.... - nesel na servis 33€ /1h dela. Napaka je bila v MOBO. Sam verjetno ne bi mogel diagnosticirat napake.
V torek jo bom nesel nazaj na servis - me pa zanima če je bil že kdo v taki situaciji
Ali sem upravičen do vračila stroškov servisa ker je bila pokvarjena nova komponenta v garanciji - sestavil pa sem računalnik sam ?? (montaža ni kriva za napako)
no si kar sam odgovarjam
Reklamacije
V primeru, da ste po pošti prejeli okvarjen izdelek, nas o tem obvestite v najkrajšem možnem času preko elektronske pošte na naslov info@agt.si ali na telefonsko številko +386 (01) 518 12 38. Prav tako nas kar najhitreje obvestite, če se prejeti izdelek razlikuje od kupljenega, da lahko napako odpravimo v najkrajšem možnem času. Potrošnik lahko uveljavlja stvarno napako, če o napaki obvesti prodajalca v roku dveh (2) mesecev od dneva, ko je bila napaka odkrita, vendar najkasneje v roku enega (1) leta, odkar je bila stvar izročena. Reševanje reklamacij bo potekalo v skladu z določili Obligacijskega zakonika in Zakona o varstvu potrošnikov. |
aly Član
Pridružen-a: Tor 28 Sep 2004 14:51 Prispevkov: 9407 Aktiv.: 39.75 Kraj: Kranj - struževo
Objavljeno: Pon Avg 31, 2009 4:57 pm Naslov sporočila: |
Če kupuješ po komponentah, potem za vsako komponento velja zanjo deklarirana garancija... Enako kot za mlinček za kavo Dokler uporabljaš po navodilih proizvajalca, je garancija veljavna. _________________ I'm going to stand outside, so if anyone asks, I'm outstanding  |
Uptime: 486 dni
