Povezava niha ali pa je sploh ni
geslo
Pridružen-a: Sre 30 Sep 2009 19:17
Prispevkov: 39
Aktiv.: 0.20
Kraj: Pod pohorjem
PrispevekObjavljeno: Ned Jan 23, 2011 3:19 pm    Naslov sporočila:  Povezava niha ali pa je sploh ni Odgovori s citatom
Najprej lep laičen pozdrav!
Iz nekakšnega obupa se obračam še na vas saj mi internet zadnje 1/2 leta povzroča sive lase. Poveza je stabilna kot tunizijska vlada občasno pa vlada brezvladje.
Včeraj, kot že X krat se mi je povezava čisto porušila, je pa potrebno poudariti, da TV-ji normalno funkcionirajo torej nek signal pa vendarle je.
Oprema oz. dodeljen modem je: THOMSON THG540
Povezava: 10/1
ISP: Kabel TV d.o.o , Petrovče (Telemach)
Prilagam še "včerajšnji" scan, ko se je modem čez noč zopet "pobral";
DOCSIS je napisal/a:
Date/Time Event ID Event Level Description
01/23/2011 05.46 73000200 03 REG RSP not received
01/23/2011 05.46 68000300 03 DHCP WARNING - Non-critical field invalid in response.
01/23/2011 05.46 84000100 03 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
01/23/2011 05.46 84000200 03 SYNC Timing Synchronization failure - Failed to acquire FEC framing
01/23/2011 05.45 68000100 03 DHCP FAILED - Discover sent, no offer received
01/23/2011 05.22 82000200 03 No Ranging Response received - T3 time-out
01/23/2011 05.22 82000400 03 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 timeout
01/23/2011 05.21 82000500 03 Started Unicast Maintenance Ranging - No Response received - T3 time-out
01/23/2011 05.21 68000100 03 DHCP FAILED - Discover sent, no offer received
01/23/2011 05.20 68000100 03 DHCP FAILED - Discover sent, no offer received
01/23/2011 05.20 82000500 03 Started Unicast Maintenance Ranging - No Response received - T3 time-out
01/23/2011 05.19 68000100 03 DHCP FAILED - Discover sent, no offer received
01/23/2011 05.18 82000200 03 No Ranging Response received - T3 time-out
01/23/2011 05.18 82000400 03 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 timeout
01/23/2011 05.17 68000100 03 DHCP FAILED - Discover sent, no offer received
01/23/2011 05.17 82000500 03 Started Unicast Maintenance Ranging - No Response received - T3 time-out
01/23/2011 05.16 82000500 03 Started Unicast Maintenance Ranging - No Response received - T3 time-out
01/23/2011 05.16 82000200 03 No Ranging Response received - T3 time-out
01/23/2011 05.16 85000100 03 No UCD's Received - Timeout
01/23/2011 05.15 82000400 03 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 timeout
01/23/2011 05.15 68000100 03 DHCP FAILED - Discover sent, no offer received
01/23/2011 05.15 82000500 03 Started Unicast Maintenance Ranging - No Response received - T3 time-out
01/23/2011 05.14 68000100 03 DHCP FAILED - Discover sent, no offer received
01/23/2011 05.14 82000500 03 Started Unicast Maintenance Ranging - No Response received - T3 time-out
PacketCable je napisal/a:
Index Time Level Event ID Description
1 2011.01.23 04:46:58 4 4000951501 Provisioning Complete - Warnings
http://ndt.arnes.si/ je napisal/a:
TCP/Web100 Network Diagnostic Tool v5.5.4a
click START to begin
** Starting test 1 of 1 **
Connected to: ndt.arnes.si -- Using IPv4 address
Checking for Middleboxes . . . . . . . . . . . . . . . . . . Done
checking for firewalls . . . . . . . . . . . . . . . . . . . Done
running 10s outbound test (client-to-server [C2S]) . . . . . 1.01Mb/s
running 10s inbound test (server-to-client [S2C]) . . . . . . 3.39Mb/s
Your PC is connected to a Cable/DSL modem
[S2C]: Packet queuing detected
click START to re-test
Sedaj pa k vprašanjem.... je možno iz prilepljenih scan-ov razbrati v katerem grmu tiči zajec - v čem je težava? Že nešteto krat sem o mojih težavah obvestil mojega lokalnega ponudnika kakor tudi Telemach, vendar je odgovor vedno enak prejšnjemu "Bomo poslali tehnika, zaupajte nam vašo tel. št." vendar žive duše ni bilo na spregled.
Kako postopati dalje? Na koga se pravzaprav naj obrnem?
Naj še dodam, da mi je zadeva delovala 4 leta brez vsakršne težave sedaj pa se lomi nepretrgoma.
Hvala za morebitne odgovore ter lep pozdrav
P.s upam, da je tema v pravilnem podforumu - sumim, da je modem zanič Smile
RUros
Prispevkov: 1031
Aktiv.: 4.40
PrispevekObjavljeno: Ned Jan 23, 2011 3:59 pm    Naslov sporočila:   Odgovori s citatom
V log-e se nisem poglabljal, ker je verjetno napak bolj strojne napake. Jaz bi na tvojem mestu najprej poskusil modemu zagotoviti zares stabilno napajanje. Ker tisti adapterji, ki jih dobiš zraven so čisto na meji in nekaj časa delajo potem pa začne nagajat. Se pravi najprej zamenjaj napajalnik in potem poročaj Angel .
hudamravljica
Prispevkov: 872
Aktiv.: 4.93
Kraj: LUCIJA
PrispevekObjavljeno: Ned Jan 23, 2011 4:10 pm    Naslov sporočila:   Odgovori s citatom
Pred leti, ko sem imel še kabelsko se je meni dogajalo podobno.
Ko sem čisto vse že poskusil, po zagotovilih operaterja je bila napaka na moji strani, sem jih pisno obvestil, da ne bom več plačal interneta dokler ne odpravijo napake. Ponovno so rekli, da je napaka na moji strani in, če bojo oni odpravljali napako bom moral storitev plačat. Strinjal sem se in so poslali tehnika. Pri meni ni našel nič. Dan kasneje je bil v omarici na začetku ulice kjer je odpravil, meni neznano, napako. Na naslednjem računu je bil 80% popust. Imel sem pa več kot 2 meseca občasne probleme.
Kadar koli sem jih klical pa vedno isti neumni odgovor:" Resetirajte modem!!"
L.p.
Nazadnje urejal/a hudamravljica Ned Jan 23, 2011 4:10 pm; skupaj popravljeno 1 krat
airwolf
Prispevkov: 2219
Aktiv.: 10.69
Kraj: Polhov Gradec
Se pa tole občasno dogaja tudi meni, stvar se je poslabšala med novoletnimi prazniki. Malo jim zateži (telemachu) ker Thompson modemi so zastareli, da dobiš novega Arris-a.
LP Gašper
Aktiv.: 39.72
PrispevekObjavljeno: Ned Jan 23, 2011 4:12 pm    Naslov sporočila:   Odgovori s citatom
Lahko je res napaka na napajalniku. Kdo je lastnik modema in napajalnika? Ponudnik ali ti?
Lahko pa da je kje preščipnjen koaksialni kabel.
Glede na log-e modem nima povezave s centralo.
Ko vidiš, kako mojstri na terenu montirajo coax konektorje ti tudi slabo rata. Pray
Si kaj premikal modem ali kable v zadnjem času? So kje kaj kopali po ulici ali šarili po zračno napeljanih kablih?
Je napaka povezana s tem, ali dežuje ali je sonce? Mogoče s temperaturami?
V glavnem, tisti, ki jim plačuješ, so dolžni zagotoviti stabilno obratovanje. Zato se jim kar pogumno obesi na telefon. Magari večkrat na dan. Ne se pustit.
geslo
Prispevkov: 39
Aktiv.: 0.20
Kraj: Pod pohorjem
PrispevekObjavljeno: Ned Jan 23, 2011 4:53 pm    Naslov sporočila:   Odgovori s citatom
Najprej najlepša hvala za exspresne odgovore!
@RUros
A, da bi res lahko bila napaka v napajalnem kablu? Takoj, ko sem to prebral sem ga šel premaknit sem ter tja vendar napajanje deluje.
@hudamravljica
Enkrat v času moje odisejade sem imel to čast, da sem govoril z tehnikom. Ta mi je razložil, da bi res naj bil problem v omarici in da jo bodo odpravili v par uricah. Ok težave so res izginile za dober teden dni, potem so bile pa znova prisotne.
Namreč izgubljanje paketkov, ki pa so očitno še vedno prisotni. (To je edino, kar je rekel, da vidi, vse ostalo naj bi bilo v zelenem območju)
@aly
Modem je njihov, zato mi tista idejo o zamenjavi napajalnega kabla v tem trenutku ne diši ravno preveč. Nenazadnje lahko kdo reče, da je bila ravno težava v tem, da sem ga zamenjal.
Na vreme nisem bil nič pozoren vsaj, do sedaj ne Wink
Kablov nisem nič premikal oz. vsaj v zadnjem času ne. Pred cirka tremi leti sem napeljal nove po celi hiši, vse od glavnega, do zadnjega. Ampak takrat je zadeva delovala b.p. nikakršnih izpadov ali kaj podobnega.
@airwolf
Je imela kolegica v MB enak problem pa so ji modem zamenjali in od takrat ni več težav. Nenazadnje ravno iz tega razloga najbolj sumim, da je modem zanič.
______________
Na splošno ideja o kablih, mi je zelo všeč. Najlažje bi bilo, če bi kdo zadevo premeril saj bi jih le tako lahko izključil kot vzrok za težave, na oko zgleda vse v redu.
Sedaj, ko modem deluje so tisti parametri na prvi strani vsi v zelenem območju vsaj po prebranem na internetu
RF Parameters
Downstream
Frequency Power -4 dBmV
Signal to Noise Ratio 38 dB Modulation QAM256
Upstream
Frequency Power 45 dBmV
Upstream Data Rate 5120 Ksym/sec Modulation QAM64
Status
System uptime 0 days 16h:32m:22s
Computers detected 1
CM Status Operational
WAN Isolation OFF
Time and Date Sun Jan 23 15:49:13 2011
Interface Parameters
Interface Name :
Provisioned Enabled State Up
Speed 100 Mbps MAC address
Za enkrat hvala za odgovore, če pa še kdo kaj ve pa se priporočam.
Lep pozdrav
RUros
Prispevkov: 1031
Aktiv.: 4.40
PrispevekObjavljeno: Ned Jan 23, 2011 4:59 pm    Naslov sporočila:   Odgovori s citatom
Nisem mislil kabla, ampak napajalnik. Sam sem imel to težavo in tudi mnogi drugi. Zato sem predlagal zamenjavo napajalnika.
Linijo ti bi lahko premeril serviser tvojega ponudnika, ki testira prepustnost in s tem vidi, koliko paketov se prenese oz. kakšna je izguba na liniji, in s tem ugotovi ali je napaka na modemu oz. na sami liniji, se pravi najpogosteje v kakšni razdelilni omari.
watts
Pridružen-a: Sob 06 Nov 2010 17:59
Prispevkov: 422
Aktiv.: 2.37
Kraj: Knežak
PrispevekObjavljeno: Ned Jan 23, 2011 5:08 pm    Naslov sporočila:   Odgovori s citatom
hudamravljica je napisal/a:
To je bila pa huda mravljica!
Geslo - poskusi jih nekako sprovocirat da ti zamenjajo modem, tam so 90% napake. Odkar je dušo oddal elektriki siolov pri prijatelju in je dobil novega, problemov ni več Dancing (je pa imel podobne kot ti)
Skrit Poglej uporabnikov profil Pošlji zasebno sporočilo MSN Messenger - naslov
Aktiv.: 39.72
PrispevekObjavljeno: Ned Jan 23, 2011 6:53 pm    Naslov sporočila:   Odgovori s citatom
Watts,
Siol in Telemach imata popolnoma drugačne modeme. Prvi za HF in TP, drugi pa za RF in Coax.
hudamravljica
Prispevkov: 872
Aktiv.: 4.93
Kraj: LUCIJA
PrispevekObjavljeno: Ned Jan 23, 2011 9:35 pm    Naslov sporočila:   Odgovori s citatom
watts je napisal/a:
Kaj je hudo...da so mi dali popust???
Pred 9-10 leti se je v Luciji kar pogosto dogajalo, da smo popoldne in zvečer pozno v noč ostali brez interneta. V pogovoru z serviserji sem zvedel, da vse posege na omrežju delajo popoldne, da firme ne ostajajo brez interneta in, če si se dovolj bunil so ti priznali določen % popusta na naslednjem računu.
L.p.
Azrael
Prispevkov: 4432
Aktiv.: 22.24
Kraj: Gorje
PrispevekObjavljeno: Ned Jan 23, 2011 9:59 pm    Naslov sporočila:   Odgovori s citatom
TM je in še vedno slovi po "čudoviti" upload zanesljivosti. Nisi edini s takimi težavami.
Dokler sem jih še prenašal, je bil upload vedno na meji zmogljivosti modema (Thomson.jpg), ko so izvedeli, da grem preč, je delalo sploh enkratno.
Seveda so ves čas govorili napaka je pri vas. To so imeli čisto prav. Napaka je bila, da sem jih sploh vzel, samo kaj ko takrat Siol še ni bil mogoč. Namreč težave so izginile takoj po menjavi ISPja.
 Velikost datoteke:  49.38 KB
 Pogledana:  14 krat
 Velikost datoteke:  329.75 KB
 Pogledana:  20 krat
geslo
Prispevkov: 39
Aktiv.: 0.20
Kraj: Pod pohorjem
PrispevekObjavljeno: Pon Mar 07, 2011 1:52 pm    Naslov sporočila:   Odgovori s citatom
Lep pozdrav po dolgem času!
Očitno je, da so moje težave z internetom izginile, saj bi v nasprotnem primeru še naprej težil Very Happy
No, kakorkoli, stvar je sledeča; zamenjali so mi modem s tem "novim" Aris-om, uredili signal v omarici in malenkost spremenili domačo napeljavo. Sedaj internet, kakor tudi telefon, funkcionira brezhibno 24/7. Povezava je stabilna, prenos se ujema s tistim na papirjih, itd. . Skratka, sem zopet zadovoljen uporabnik Smile
Hvala vsem za pomoč ter lep dan še naprej!
MarkoM
Prispevkov: 2825
Aktiv.: 12.37
Kraj: Lovrenc na P.
PrispevekObjavljeno: Pon Mar 07, 2011 2:29 pm    Naslov sporočila:   Odgovori s citatom
Drugače pa vedno, ko je kaj narobe jim moraš zagroziti, da ne boš plačal računa oz. ga boš zavrnil z utemeljitvijo, ker ti ne zagotavljajo tega kar ponujajo. Potem se še vedno zmigajo. In skoraj vsi so enaki.
Najboljši so bili pri siolu, ko so kolegu rekli po telefonu, naj jim pošlje email, ko je imel težave z internetom. Seveda jim je povedal par krepkih, kako naj pošlje email, če internet ne dela. So mu celo zagrozili, da se pogovori snemajo... Mr. Green
Uptime: 490 dni
