Atmega8 in shift registri
jozzze2000
Pridružen-a: Pet 25 Nov 2011 8:36
Prispevkov: 167
Aktiv.: 1.01
Kraj: Novo mesto
PrispevekObjavljeno: Čet Jul 02, 2015 11:23 am    Naslov sporočila:  Atmega8 in shift registri Odgovori s citatom
Rad bi zvezal 4 shift registre v "daisy chain" in z njimi krmilil 32 LED-ic. Z dvema deluje OK, z več kot dvema pa se zatakne.
Trenutna koda, ki deluje z dvema sh.registroma (columns = 16 LED-ic) je spodaj.
Ko dodam še en sh.register ter spremenim konstanto columns na 24 in povečam vhodni podatek v funkcijo Shift_Int na 24 bitov, se še vedno prikaže samo na dveh sklopih LED-ic (dva sh.registra). Prosim pomagajte.
Koda:
#include <avr/io.h>
#include <util/delay.h>
typedef unsigned char u8;
#define F_CPU 1000000UL
//V1
#define DS_PORT    PORTC   // Data pin
#define DS_PIN     1
#define ST_CP_PORT PORTC   // Latch pin
#define ST_CP_PIN  0
#define SH_CP_PORT PORTC   // Clock pin
#define SH_CP_PIN  2
//V2
//The pins used to operate the shift register:
#define ShiftPort    PORTC
#define ShiftDDR   DDRC
#define LatchPin   (1 << 0)
#define DataPin      (1 << 1)
#define ClkPin      (1 << 2)
#define DS_low()  DS_PORT&=~_BV(DS_PIN)
#define DS_high() DS_PORT|=_BV(DS_PIN)
#define ST_CP_low()  ST_CP_PORT&=~_BV(ST_CP_PIN)
#define ST_CP_high() ST_CP_PORT|=_BV(ST_CP_PIN)
#define SH_CP_low()  SH_CP_PORT&=~_BV(SH_CP_PIN)
#define SH_CP_high() SH_CP_PORT|=_BV(SH_CP_PIN)
//Define functions
void ioinit(void);
void output_led_state(unsigned long int LED_state);
void Shift_Int(int32_t shiftData);
 int columns=16;  // 24 //32
int main (void)
    DDRC  = 0b00000111; //1 = output, 0 = input
    PORTC = 0b00000000;
   while(1)
     Shift_Int(0b1000110110000101); // 100111011000110110000101  // 10111101100111011000110110000101
void Shift_Int(int32_t shiftData)         //Function used to shift in data
   ShiftPort &= ~(LatchPin | ClkPin | DataPin);     //All pins low: LatchPin low signals a write operation
   for (int i=0; i<columns; i++)
      ShiftPort &= ~ClkPin;            //Set ClkPin low
      if (shiftData & (1<<i)) ShiftPort |= DataPin;      //Set DataPin high if current bit is 1
      else ShiftPort &= ~DataPin;         //Set DataPin low if current bit is 0
      ShiftPort |= ClkPin;            //Set ClkPin high to increment shift register
      ShiftPort &= ~DataPin;            //Set DataPin low to prepare for next write
   ShiftPort |= LatchPin;              //Set LatchPin high to signal end of write operation
   ShiftPort &= ~(ClkPin | DataPin);           //Reset ClkPin and DataPin to low
MitjaN
Pridružen-a: Sre 17 Avg 2011 15:40
Prispevkov: 91
Aktiv.: 0.54
PrispevekObjavljeno: Čet Jul 02, 2015 11:32 am    Naslov sporočila:   Odgovori s citatom
Ali ti prevajalnik poda kakšno opozorilo, ali vsaj obvestilo?
Precej verjetno prevajalnik konstanto 1 v izrazu
"if (shiftData & (1<<i)) ShiftPort |= DataPin; //Set DataPin high if current bit is 1 "
privzeto vzame kot klasičen int. Ne poznam tvojega sistema ampak nekje so int široki 16 bitov. seveda ga potem ne moreš premakniti v levo za več kot 15 bitov.
Poizkusi ga pretvoriti(cast) v 32 bitno konstanto:
"(1<<i)" spremeni v"(((int32_t)1)<<i)"
ali pa:
"(1<<i)" spremeni"(1L<<i)"
jozzze2000
Prispevkov: 167
Aktiv.: 1.01
Kraj: Novo mesto
PrispevekObjavljeno: Čet Jul 02, 2015 12:12 pm    Naslov sporočila:   Odgovori s citatom
Boo hoo! Boo hoo! Boo hoo!
Hvala lepa, deluje Dancing
