Forum o elektrotehniki in raèunalništvu
Sponsored by SiOL
Heatless (cold) Toner Transfer for PCB Making
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Vse kar nima zveze z elektroniko in raèunalništvom
Prispevkov: 5460
Aktiv.: 33.94
PrispevekObjavljeno: Sob Avg 04, 2018 3:03 pm    Naslov sporočila:  Heatless (cold) Toner Transfer for PCB Making Odgovori s citatom
En lepo napisan èlanek na temo prenosa tonerja brez dovajanja toplote.
simpletronic je napisal/a:
Toner transfer method for making PC boards is very practical and economical. The use of heat for the transferring is not. Large boards expand with heat (more than the laser print) and heat is applied to the top of the toner and not to the bottom contacting the copper layer. Too much heat melts and deforms the toner, too little heat and it won't adhere uniformly. In this Instructable I will describe a very simple technique I've been using for over 15 years. It is very fail-proof and involves the use of only 2 common chemicals : Ethyl Alcohol and Acetone. You can replace the Acetone with Toluene or Xylene, but you will have to experiment with the proportions.
Se mi pa ob napisanem pojavlja vprašanje, ali gre pri "odkritju" enega velikega primorskega "znanstvenika" na tem podroèju za èisto navaden plagiat Think
We've developed a novel fast and cheap method of making PCBs at home using just a laser printer and a few chemicals, which we've named "chemotransfer". The chemicals transfer the toner from paper to the copper without using any heat.
 Velikost datoteke:  65.37 KB
brezimenko
Èlan
Èlan
Prispevkov: 85
Aktiv.: 3.91
PrispevekObjavljeno: Ned Avg 05, 2018 9:37 am    Naslov sporočila:   Odgovori s citatom
Jah zakaj bi po tvoje bil plagiat?
Ta na instructabiles ni v svojem èlanku napisal ne kater papir uporablja, ne kater tiskalnik ne kateri toner(original ali nadomestni).
Potem je drug naredil celo znanost in za župcotransfer uporablja drugaèno mešanico, izbran papir iz izbrane tiskarne, pri katerem je že druga serija lahko problematièna saj se procenti snovi že razlikujejo. Z tiskalniki in tonerji je podoben problem saj ni vsak dober. Vse to ima zabeleženo na svojem forumu in spisek še poveèuje.
Izgubil sem raèun pod imenom kobranka
v.j.
Èlan
Èlan
Prispevkov: 535
Aktiv.: 10.73
Kraj: Veldes
PrispevekObjavljeno: Ned Avg 05, 2018 12:24 pm    Naslov sporočila:   Odgovori s citatom
Plagiat? v katero smer ? Rolling Eyes
V glavnem, neponovljivost je tako zelo ogromna, da je meni osebno škoda vsake sekunde èasa za nezanesljiv naèin dela.
No, nekateri so v to preprièani drugaèe, ker jim paè nekako uspeva, seveda po nešteto urah in poskusih.
Osebno sem še vedno preprièan v fotopostopek, ker je to zame najhitrejše, dosegam 100% ponovljivost in 100% uspeh in to brez popravljanja s flomastrom in podobnimi metodami in ja, tudi za en kos se grem fotopostopek, ker naredim hitreje kot s tonertransfer naèinom.
Vsakemu svoje, vsak bo zagovarjal svoj naèin oziroma naèin po katerem mu najbolje uspeva.
Nekoè sem delal s Positiv 20 sprejem, sedaj s P-501 (tudi pozitiv) od Cinkarne, ki ga ne izdelujejo veè, licenco prodali... k sreèi imam še precej zlate zaloge, kot kaže laku èas ne škoduje ker ga pravilno skladišèim. Positiv 20 je še vedno v prodaji, imam še nekaj piksen krepko èez rok in še vedno deluje brez problema.
Obstajajo še svetlobno obèutljive folije, sem naroèil eno rolco za test, moram probat, da vidim kako se obnese, je pa negativ, torej isti filmi za osvetljevanje ne bodo dobri.
Kontakt na e-mail , za veè informacij klikni gumb www , na ZS ne odgovarjam!
Prispevkov: 5460
Aktiv.: 33.94
PrispevekObjavljeno: Ned Avg 05, 2018 1:34 pm    Naslov sporočila:   Odgovori s citatom
Uporabnost sama je tako ali tako vprašljiva v enem ali drugem primeru. Dokler mi kitajci naredijo in dostavijo tiskanine v nekaj dneh vkljuèno z metaliziranimi luknjami, stoplakom in montažnim tiskom po takšni ceni, da se mi niti kemikalij ne splaèa iskat okrog se o smiselnosti takšnega poèetja niti pogovarjat ne splaèa.
Èe pa nek sicer zelo vnet zagovornik avtorskih pravic vzame razvit postopek in ga poskuša implementirat v svoji režiji, potem pa trdi, da ... je razvil novo metodo ..., je za moje pojme to vsaj plagiat, èe že ne kraja moralnih pravic avtorja :bonk:
brezimenko
Èlan
Èlan
Prispevkov: 85
Aktiv.: 3.91
PrispevekObjavljeno: Ned Avg 05, 2018 3:30 pm    Naslov sporočila:   Odgovori s citatom
Ja verjetno, vsaj na pogoje Creative Commons je najverjetneje kje v prekršku. Tu ti dam prav.
Je pa res, da se lahko sam za=beš. Zgornja verzija je 2.0, ki pa ni najnovejš. Najnovejša naj bi bila 4.0 kjer je še nekaj dopolnitev. Tako moraš sam spremljati dogajanje od CC in popravljati vsebino.
Lahko ga vsaj opomneš, da so prisotne napake v èlankih glede na pravila CC, jaz nisem toliko podkovan v tej smeri mi je pa sestra pred èasom razlagala na kaj vse moreš pazit pri diplomski nalogi. Tam je pa preveè detajlov in sem že vse pozabil.
v.j.
Èlan
Èlan
Prispevkov: 535
Aktiv.: 10.73
Kraj: Veldes
PrispevekObjavljeno: Ned Avg 05, 2018 11:24 pm    Naslov sporočila:   Odgovori s citatom
*** moderirano/brisan offtopic ***
Da se vrnemo na bistvo te teme, jah, nekdo je paè pogruntal nek postopek, drugi ga kopirajo, ponavljajo, izpopolnjujejo, dovršujejo, spreminjajo, dosegajo take in drugaène uspehe...
Kaj za vraga, a je res pomembno kdo je avtor, je kdo kaj zašèitil, patent mogoèe? kdo ve, kdo je bil prvi, kdo ve kdo je koga kopiral, kdo ve... je pa zanimivo...
...bilo bi lepo in pravièno, èe bi vsakdo, ki nekaj izboljša, da bi napisal kje je dobil idejo in od koga in kako je vse skupaj izboljšal, ker vedno gre za izboljšave, prilagoditve in ne samo za golo kopiranje, ker to je nemogoèe, ker pogoji niso enaki.
Èlan
Èlan
Prispevkov: 749
Aktiv.: 20.87
PrispevekObjavljeno: Pon Avg 06, 2018 1:39 am    Naslov sporočila:   Odgovori s citatom
Saj pravila so doloèena. Nihèe ne trdi, da je kaj spornega, èe vzameš idejo nekoga drugega, ki je to dovolil pod pogojem, da ga navedeš kot avtorja. Èe pa eno idejo od nekod pobereš in jo propagiraš kot lastno pa ni fer do avtorja, èeprav si vložil veè dela v "raziskave" kot originalni avtor. Tu je èista analogija s patenti. Originalni avtor je navedel "topilo", kasnejši avtor je dodal svoj delež z odkrivanjem mešanice topil in bi bilo prav, da to objavi kot izpeljanko z lastnim prispevkom (podobno je pri patentih, znanstvenih objavah, odprti kodi, in še marsikje v razvitem svetu). Zanimivo je, da imenovani kasnejši avtor potem "šimfa" èez kitajce, da se ne držijo patentnega prava Brick wall
Sicer bi se pa o kvaliteti dalo razpravljat. Za jedkanice je gotovo OK.
Fotografija je izrezek iz fotografije VolkD objavljene na drugem forumu (vir).
 Velikost datoteke:  200.38 KB
 Pogledana:  15 krat
Bzzzzzz
Nazadnje urejal/a mosqito Pon Avg 06, 2018 3:13 pm; skupaj popravljeno 1 krat
sebaseba
Èlan
Èlan
Pridružen-a: Ned 02 Maj 2010 3:26
Prispevkov: 69
Aktiv.: 0.64
Kraj: Piran
PrispevekObjavljeno: Pon Avg 06, 2018 2:51 am    Naslov sporočila:   Odgovori s citatom
https://s5tech.net/viewtopic.php?p=63584#p63584
v.j.
Èlan
Èlan
Prispevkov: 535
Aktiv.: 10.73
Kraj: Veldes
PrispevekObjavljeno: Pon Avg 06, 2018 8:03 am    Naslov sporočila:   Odgovori s citatom
Takle rezultat, kot je zgoraj na fotografiji, je zame nesprejemljiv. Verjetno tiste packe na bakru niso ostanki tonerja, to se da oèistit... torej je baker nažrt ali požrt. Ko je baker enkrat vsaj nažrt, je okužen, kvaliteta je vprašljiva, ne zgleda in nikoli ne veš kdaj bo izdelek odpovedal, verjetno nikoli, vendar... ta verjetno me moti, mora biti 100%. No, za hobi mogoèe OK, ampak za resno delo tole ni.
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Vse kar nima zveze z elektroniko in raèunalništvom Časovni pas GMT + 2 uri, srednjeevropski - poletni čas
Uptime: 31 dni
