frenki Moderator
Objavljeno: Čet Avg 30, 2007 12:16 am Naslov sporočila: Uporabniki poštnega strežnika uni-mb.si |
Opažam, da poštni strežnik uni-mb.si zavrača pošto, generirano na tem forumu z naslednjim obvestilom:
Undeliverable mail, invalid header: unencoded 8-bit character |
Ker je trenutno to edini strežnik ki mu format poslanih sporočil ne odgovarja "napake" zaenkrat kljub povratnemu obvestilu:
This nondelivery report was generated by the program amavisd-new at host
goban.uni-mb.si.
WHAT IS AN INVALID CHARACTER IN MAIL HEADER?
The RFC 2822 standard specifies rules for forming internet messages.
It does not allow the use of characters with codes above 127 to be
used directly (non-encoded) in mail header.
If such characters (e.g. with diacritics) from ISO Latin or other
alphabets need to be included in the header, these characters need
to be properly encoded according to RFC 2047. This encoding is often
done transparently by mail reader (MUA), but if automatic encoding is
not available (e.g. by some older MUA) it is the user's responsibility
to avoid the use of such characters in mail header, or to encode them
manually. Typically the offending header fields in this category are
'Subject', 'Organization', and comment fields in e-mail addresses of
the 'From', 'To' and 'Cc'.
Sometimes such invalid header fields are inserted automatically
by some MUA, MTA, content checker, or other mail handling service.
If this is the case, that service needs to be fixed or properly
configured. Typically the offending header fields in this category
are 'Date', 'Received', 'X-Mailer', 'X-Priority', 'X-Scanned', etc.
If you don't know how to fix or avoid the problem, please report it
to _your_ postmaster or system manager. |
ne bom popravljal. Uporabnikom strežnika predlagam, da v svojih profilih navedete kak drug poštni strežnik, ki ga format poslanih sporočil ne moti.
Posebno opozorilo velja v primeru novih registracij, saj aktivacijska koda poslana na omenjeni strežnik naslovnika ne bo dosegla. Predlagam uporabo drugih strežnikov.
Lp, Frenki |
Objavljeno: Čet Avg 30, 2007 12:31 am Naslov sporočila: |
uni-mb zavrača pošto tudi od drugod. Kasneje se izkaže, da je pošta kljub temu prišla. _________________ Dokler bodo ljudje mislili, da živali ne čutijo, bodo živali čutile, da ljudje ne mislijo. |
