Cenik HTE
Pojdi na stran Prejšnja  1, 2
dkone
Prispevkov: 2116
Aktiv.: 9.48
Kraj: Krško
PrispevekObjavljeno: Pet Nov 23, 2007 4:46 pm    Naslov sporočila:   Odgovori s citatom
mi747 je napisal/a:
meni deluje na Win XP sp2 slovenska verzija.
So pa v HTE res henčki, da ne zanjo vzpostaviti ene resne internetne trgovine.
Za vzgled si alhko vzamejo tole
http://www.ges.cz/
Meni ne dela, pa imam tudi SP2. Pojavi se pa ime tole sporočilo:
 Velikost datoteke:  10.28 KB
 Pogledana:  2824 krat
 Velikost datoteke:  26.84 KB
Denis
tonko
Pridružen-a: Sob 25 Jun 2005 13:45
Prispevkov: 541
Aktiv.: 2.28
Kraj: Črnomelj
PrispevekObjavljeno: Pet Nov 23, 2007 7:27 pm    Naslov sporočila:   Odgovori s citatom
Standalone exe file for Borland C++ builder
Another thing you should do
if you want a truly standalone exe is go to the linker section of "project->options" and
uncheck "use dynamic RTL" - that uses a file RTL.dll - once again, your exe won't work
without it unless you uncheck. Just a note, if you hadn't figured, your exes grow hugely
if you uncheck these boxes because the relevant content from each library is included into
your exe. If you're distributing multiple programs to users then just use the installshield
to send them the .bpl files etc. Hope that helps Smile Al
Kako narediti standalone exe :
1. Project->Options-->Packages "build with runtime packages" NE SME BITI OBKLJUKANO
2. Project->Options-->Linker "use dynamic RTL" NE SME BITI OBKLJUKANO
3. Project->Options-->Directories/Conditionals -> library path
npr: "C:\Program Files\Borland\CBuilder6\Source\cport264\Sources"
in: "C:\Program Files\Borland\CBuilder6\Source\IoComp302"
4. Project->Options-->Directories/Conditionals -> Include path ??
npr: "C:\Program Files\Borland\CBuilder6\Source\cport264\Sources" ??
in: "C:\Program Files\Borland\CBuilder6\Source\IoComp302" ??
5. project -> Build All
Tako izdelaš samostojen exe z vključenimi dll-ji pri BCB-ju.
Poizkusi mogoče dela tudi na Delphi-ju
Prispevkov: 14677
Aktiv.: 61.80
PrispevekObjavljeno: Sob Nov 24, 2007 9:04 pm    Naslov sporočila:   Odgovori s citatom
Naletel sem na zelo "čudnega" hrošča v ceniku. Opisal sem ga tukaj. Če imamo poinstaliran omrežni tiskalnik, ki je definiran kot prevzet in ta tiskalnik ni dostopen, se program sesuje. V tem primeru na računalniku definiramo prevzet tiskalnik recimo "Image Writer".
GregorN
Prispevkov: 1162
Aktiv.: 5.42
PrispevekObjavljeno: Ned Nov 25, 2007 1:12 am    Naslov sporočila:   Odgovori s citatom
Meni se je zgodilo le to, kot sta zgoraj slikici: Prvo ERROR, nato pa če pošlje obvestilo o napaki, in ko sem kliknil, da naj NE pošlje mi je cenik normalno odprlo. Very Happy
LP! Gregor
Prispevkov: 14677
Aktiv.: 61.80
PrispevekObjavljeno: Pet Dec 07, 2007 12:11 pm    Naslov sporočila:   Odgovori s citatom
Sveža baza v prilogi.
baza.zip
 Ime datoteke:  baza.zip
 Velikost datoteke:  212.56 KB
 Downloadano:  29 krat
HunterMan
Pridružen-a: Pon 17 Dec 2007 2:35
Prispevkov: 2
Aktiv.: 0.01
PrispevekObjavljeno: Pon Dec 17, 2007 9:34 pm    Naslov sporočila:   Odgovori s citatom
Končno bom lahko kaj najdu, moji lasi ti bodo hvaležni Laughing
Stran 2 od 2
