Pridružen-a: Ned 19 Sep 2004 22:04 Prispevkov: 16777193 Aktiv.: 70614.51
Objavljeno: Sre Jan 02, 2008 11:17 am Naslov sporočila: |
[g0ran24] Član
Pridružen-a: Pon 15 Avg 2005 11:27 Prispevkov: 503 Aktiv.: 2.12 Kraj: Brežice
Glitch Član
Pridružen-a: Pet 07 Apr 2006 11:40 Prispevkov: 1477 Aktiv.: 6.30
Objavljeno: Sre Jan 02, 2008 12:51 pm Naslov sporočila: |
Mislim, da nihče ne bo preverjal ali je bil SW, ki je pravilno licenciran napisan z licenčnim SW. Mogoče bi zoprnijo zganjal kakšen konkurent, ki ve, da uporabljaš nelegalen razvojni SW za razvoj in prodajo SW in mu s tem hodiš v zelje.
Sicer pa obstajajo brezplačna orodja za razvoj SW. Mogoče nimajo vseh bonbončkov imaš pa zato miren spanec.
Dodatek, to sem nasel na lazarus strani. Verjetno najbolj pomemna zadeva.
Can I create commercial products with this?
Yes. The code for the Free Pascal compiler is licensed under the GPL. This means that it is open source, free, whatever name you want to stick to it. You can modify the code if you wish but you MUST distribute those changes or make them available to others if they wish to use it.
The FCL (Free Pascal Component Libraries) and the LCL (which will eventually become part of the FCL) are licensed under a modified LGPL. In a nut shell this means that you can write your own proprietary software that just links to these libraries. You can sell your application without the need to supply or make available your code. However, as with the compiler if you make modifications to the FCL or LCL you must make those changes available to the general public and the world.
Objavljeno: Sre Jan 02, 2008 1:18 pm Naslov sporočila: |
Pridružen-a: Pon 24 Feb 2003 17:09 Prispevkov: 14679 Aktiv.: 61.78
Objavljeno: Sre Jan 02, 2008 1:33 pm Naslov sporočila: |
VolkD je napisal/a: |
Če prav razumem si napisal nek program v Delphi za katerega nimaš licence.
Zdaj bi pa ta program rad prodal neki firmi.
Mirne duše lahko, če pride do tovrstnih težav bo prišlo tako in tako pri tebi in ne pri firmi. In še v tem primeru lahko stvar rešiš tako, da program prevedeš na mojem Delphi, ki je licenčni. Prevajanje in razvoj seveda plaćaš. Koliko je pa seveda moja in tvoja stvar. In to osebna stvar. |
Niste me razumeli. Recimo program je napisan z licenčno opremo, ter je dan za free rabo v podjetje. Podjetje za za orodje s katerim je bil program napisan nima licence. _________________ lp
Objavljeno: Sre Jan 02, 2008 1:45 pm Naslov sporočila: |
Objavljeno: Sre Jan 02, 2008 1:57 pm Naslov sporočila: |
borisz je napisal/a: |
Potem je vse v redu. Tudi jaz nimam licence za program s katerim je napisan Windows. |
Tukaj je še vedno nekaj nejasnosti. Pa potrebuje podjetje za freeware kako potrdilo od avtorja - če je znan? _________________ lp
Objavljeno: Sre Jan 02, 2008 2:16 pm Naslov sporočila: |
BluPhenix Član
Pridružen-a: Pet 05 Mar 2004 12:54 Prispevkov: 1018 Aktiv.: 4.28 Kraj: Sežana
Objavljeno: Sre Jan 02, 2008 11:43 pm Naslov sporočila: |
Tudi moje mnenje je to, da v kolikor napišeš da je program free v about ni nobenega problema.
Pa tudi drugače. Tudi če nebi bil programček free, gre za stvar med tabo, ki si avtor programa in podjetja, kjer se uporablja. Dokler ti podjetja, v primeru da ti ne plača, ne tožiš zaradi kršenja uporabe intelekturalne lastnine se ne zgodi prav nič. |
Objavljeno: Sre Jan 02, 2008 11:48 pm Naslov sporočila: |
Tihi Član
Pridružen-a: Čet 27 Nov 2003 14:15 Prispevkov: 281 Aktiv.: 1.18 Kraj: Ljubljana
Objavljeno: Čet Jan 03, 2008 11:24 am Naslov sporočila: |
Glede patentov, je treba žal za vsako državo posebaj patentirat, kjer bi umotvor rad tržil. S tem, da imajo Kitajci, indija, afrika in podobno vsak svoje fore. Že v EU ima vsaka država svoje tarife, čeprav naj bi obstajala možnost patentiranja za celotno EU, ki pa ni poceni in te prepričujejo da to ni nikakor smiselno
Je pa tako, da plagiat že lahko izdelajo kjerkoli drugje, ne da bi bili kaznovani, samo tržit ga ne smejo tam kjer si to ti prvi patentiral. |
Glitch Član
Objavljeno: Čet Jan 03, 2008 12:11 pm Naslov sporočila: |
Aja, pa še nekaj okoli freeware programov. Lahko, da piše da je freeware, razen v določenih primerih. Sem že naletel na določen freeware, ki je bil to le, če sem ga uporabljal doma na domačem računalniku. Licencing information je najbolj pomemben, ponavadi je celoten napisan takoj na začetku pri inštalaciji. |
Uptime: 10 dni
