fpga - 7 segmentni prikaz
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> FPGA in CPLD programabilna vezja
trot
Prispevkov: 1312
Aktiv.: 5.60
Kraj: glej fogl
PrispevekObjavljeno: Pon Jan 14, 2008 7:25 pm    Naslov sporočila:  fpga - 7 segmentni prikaz Odgovori s citatom
Rad bi preizkusil 7 segmentni prikaz na x bordu. Spisal sem tole:
main.vhd
Koda:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity main is
   port (    clock : in  STD_LOGIC;
            tipka : in  STD_LOGIC;
            ledica1 : out  STD_LOGIC;
            ledica2 : out  STD_LOGIC;
            prvi_disp_7seg_led_out : out std_logic_vector (7 downto 1)
end main;
architecture Behavioral of main is
   signal clk_div : std_logic_vector (20 downto 0);
   signal clk_disp_7seg : std_logic_vector (3 downto 0);
   component disp_7seg
      port (     seg_hex:   in    STD_LOGIC_VECTOR (3 downto 0);
               seg_led:   out   STD_LOGIC_VECTOR (6 downto 0));
   end component;
begin
   process (clock)
   begin
      if rising_edge(clock) then
         clk_div <= clk_div + 1;
      end if;
   end process;
   process (clk_div(15))
   begin
      if rising_edge(clk_div(15)) then
         clk_disp_7seg <= clk_disp_7seg + 1;
      end if;
   end process;
   prvi_disp_7seg : disp_7seg port map(seg_hex => clk_disp_7seg, seg_led => prvi_disp_7seg_led_out);
   ledica1 <= clk_div(14);
   ledica2 <= clk_disp_7seg(1);
end Behavioral;
7seg.vhd
Koda:
library IEEE;
--library UNISIM;
entity disp_7seg is
   Port (     seg_hex:   in    STD_LOGIC_VECTOR (3 downto 0);
end disp_7seg;
architecture Behavioral of seg is
begin
-- segment encoinputg
--      0
--  5 |   | 1
--     ---   <- 6
--  4 |   | 2
--      3
   with seg_hex SELect
   seg_led   <= "1111001" when "0001",   --1
            "0100100" when "0010",   --2
            "0110000" when "0011",   --3
            "0011001" when "0100",   --4
            "0010010" when "0101",   --5
            "0000010" when "0110",   --6
            "1111000" when "0111",   --7
            "0000000" when "1000",   --8
            "0010000" when "1001",   --9
            "0001000" when "1010",   --A
            "0000011" when "1011",   --b
            "1000110" when "1100",   --C
            "0100001" when "1101",   --d
            "0000110" when "1110",   --E
            "0001110" when "1111",   --F
            "1000000" when others;   --0
end Behavioral;
Javi mi napako:
ERROR:NgdBuild:604 - logical block 'prvi_disp_7seg' with type 'disp_7seg' could
not be resolved. A pin name misspelling can cause this, a missing edif or ngc
file, or the misspelling of a type name. Symbol 'disp_7seg' is not supported
in target 'xbr'.
Mogoče kdo ve, kaj bi bilo narobe. Kakšen misspelling, jaz ne vidim nobene napake.
icek
Pridružen-a: Ned 15 Maj 2005 22:31
Prispevkov: 105
Aktiv.: 0.42
Kraj: Ruše
PrispevekObjavljeno: Tor Jan 15, 2008 8:33 am    Naslov sporočila:   Odgovori s citatom
Narediti moraš še port map s katerim boš povezal signale v main.vhd in 7seg.vhd.
trot
Prispevkov: 1312
Aktiv.: 5.60
Kraj: glej fogl
PrispevekObjavljeno: Tor Jan 15, 2008 10:35 am    Naslov sporočila:   Odgovori s citatom
Saj imam, če misliš to:
Koda:
icek
Prispevkov: 105
Aktiv.: 0.42
Kraj: Ruše
PrispevekObjavljeno: Tor Jan 15, 2008 10:55 am    Naslov sporočila:   Odgovori s citatom
Pa res, sem spregledal.
Aktiv.: 38.07
PrispevekObjavljeno: Tor Jan 15, 2008 3:59 pm    Naslov sporočila:   Odgovori s citatom
Si dodal tadrugi fajl (disp_7seg) vmes med source?
Meni tale error diši na to, da ne najde podkomponente.
trot
Prispevkov: 1312
Aktiv.: 5.60
Kraj: glej fogl
PrispevekObjavljeno: Tor Jan 15, 2008 4:04 pm    Naslov sporočila:   Odgovori s citatom
Sem (glej priponko), vsaj tako mislim - dal sem "new sorce", in spisal to kar je v 7seg.vhd.
A je potrebno ta fajl (7seg.vhd) kako vključit v glavni fajl (main.vhd) - tako kot se to dela npr. v c-ju (#include ...).
 Velikost datoteke:  113.13 KB
 Pogledana:  15 krat
trot
Prispevkov: 1312
Aktiv.: 5.60
Kraj: glej fogl
PrispevekObjavljeno: Tor Jan 15, 2008 8:20 pm    Naslov sporočila:   Odgovori s citatom
Sem našel napako, v 7seg.vhd sem pisal enkrat "disp_7seg", dugič pa "seg". Rolling Eyes
Koda:
entity disp_7seg is
end disp_7seg;
Samo ne vem zakaj mi preverjanje sintakse samo za 7seg.vhd ni javilo nobene napake...
Aktiv.: 38.07
PrispevekObjavljeno: Sre Jan 16, 2008 12:38 pm    Naslov sporočila:   Odgovori s citatom
Če gledam tvojo sliko - fajl 7seg se mora postaviti pod Main fajl. Zraven UCF. Sicer ne bo šlo. Ampak očitno si že našel napako.
Pri VHDL-u je potrebno biti pazljiv - marsikdaj se zadeva na videz normalno prevede. In če ne deluje, je potrebno preveriti vse Warning izpise.
Še ena zanimiva funkcija obstaja - izpis mapiranja pinov.
Med projektnimi fajli nadeš eno takšno datoteko: "<ime_top_modula>_pad.csv"
Tam so izpisani vsi pini izbranega čipa.
trot
Prispevkov: 1312
Aktiv.: 5.60
Kraj: glej fogl
PrispevekObjavljeno: Sre Jan 16, 2008 1:10 pm    Naslov sporočila:   Odgovori s citatom
aly je napisal/a:
Sej potem ko naredim en "instance" tega modul (in ko ni napak) se postavi spodaj. Najbrž bo to v redu.
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> FPGA in CPLD programabilna vezja Časovni pas GMT + 2 uri, srednjeevropski - poletni čas
