Utripajoče LED za modele
Slemi
Pridružen-a: Pet 29 Okt 2004 13:29
Prispevkov: 386
Aktiv.: 1.62
Kraj: Hrastnik
PrispevekObjavljeno: Pon Avg 17, 2009 3:55 pm    Naslov sporočila:   Odgovori s citatom
Tole je približno to. Program in datoteke. Program je bolj na hitro napisan tako da ni čisto lepo urejen. Napisan je s kombinacijo AVRStudio + WinAVR. Vezje pa je od projekta za krmiljene RGB ledic, vendar "paše" tudi za ta projekt. SCH in PCB sta risana v P-CAD-u 2006.
Koda:
#include <io.h>
#include <interrupt.h>
void set_red(unsigned char value);
void set_green(unsigned char value);
void set_blue(unsigned char value);
//void set_rgb(unsigned char red, unsigned char green, unsigned char blue);
unsigned char barva, color_red, color_green, color_blue;
int main(void)
   unsigned int a, b;
   unsigned char re, gr, [slovenščina je zame španska vas];//, pon;
   unsigned char svetilnost = 0;//za dolge - kratke
   unsigned char repeat;//za rdeče - modre
   re = 0;
   gr = 0;
   [slovenščina je zame španska vas] = 0;
   DDRB = 0xFF;
   DDRC = 0xFF;
   DDRD = 0x0F;
   PORTB = 0x00;
   PORTC = 0x00;
   //OC1A & OC1B ->
   TCCR1A =  (1<<COM1A1) | (1<<COM1A0);
   TCCR1A |= (1<<COM1B1) | (1<<COM1B0);
   TCCR1A |= (1<<WGM11);
   TCCR1B = (1<<WGM12) | (1<<WGM13);
   ICR1H = 0x00;
   ICR1L = 0xFF;
   TCCR1B |= (1<<CS10);
   OCR1AH = 0x00;
   OCR1AL = 0x00;
   OCR1BH = 0x00;
   OCR1BL = 0x00;
   //-> OC1A & OC1B
   //OC2 ->
   TCCR2 = (1<<WGM20) | (1<<WGM21);
   TCCR2 |= (1<<COM21) | (1<<COM20);
   TCCR2 |= (1<<CS20);
   OCR2 = 0x00;
   //-> OC2
   //ICR1H = 0x00;
   //set_rgb(0, 0, 0);
   set_red(0);
   set_green(0);
   set_blue(0);
   while(1)
      for(repeat = 0; repeat < 5; repeat++)//modra
         set_red(255);
         for(a = 0; a < 70; a++)
            for(b = 0; b < 500; b++)
               asm("nop");
         set_red(0);
               asm("nop");
      for(a = 0; a < 300; a++)//kratke -> dolge
            asm("nop");
            if(svetilnost < 253)
               svetilnost+=2;
            set_green(svetilnost);
      for(repeat = 0; repeat < 5; repeat++)//rdeča
         set_blue(255);
               asm("nop");
         set_blue(0);
               asm("nop");
      for(a = 0; a < 300; a++)//dolge -> kratke
            asm("nop");
         if(svetilnost > 40)
            svetilnost--;
   return (1);
   OCR1AH = 0x00;
   OCR1AL = 0xFF - value;
   OCR1BH = 0x00;
   OCR1BL = 0xFF - value;
   OCR2 = 0xFF - value;
   set_red(blue);
   set_green(green);
   set_blue(red);
Vezje in program je dovoljeno uporabljati in spreminjati le za lastne, nekomercialne namene.
Tule si je možno sneti PCAD viewer.
Gregor
RGB Proto V1.0 21072009.rar
 Ime datoteke:  RGB Proto V1.0 21072009.rar
 Velikost datoteke:  52.25 KB
 Downloadano:  40 krat
Nazadnje urejal/a Slemi Sob Avg 22, 2009 12:19 pm; skupaj popravljeno 2 krat
Odsoten Poglej uporabnikov profil Pošlji zasebno sporočilo AIM - AOL Instant - naslov MSN Messenger - naslov
Slemi
Prispevkov: 386
Aktiv.: 1.62
Kraj: Hrastnik
PrispevekObjavljeno: Čet Avg 20, 2009 1:00 pm    Naslov sporočila:   Odgovori s citatom
Takole pa izgleda zadeva v živo.
rok
Pridružen-a: Pet 13 Mar 2009 16:31
Prispevkov: 365
Aktiv.: 1.84
Kraj: Dravograd
PrispevekObjavljeno: Čet Avg 20, 2009 1:13 pm    Naslov sporočila:   Odgovori s citatom
Lepo! Applause Applause Very Happy
S čim si pa tiste SMD nalotal?
Izgleda lepo!
Slemi
Prispevkov: 386
Aktiv.: 1.62
Kraj: Hrastnik
PrispevekObjavljeno: Čet Avg 20, 2009 1:21 pm    Naslov sporočila:   Odgovori s citatom
Vse je zlotano z Wellerjevim spajkalnikom WS80 in originalno (okrog 3mm) konico.
mkosmac
Pridružen-a: Čet 26 Mar 2009 22:18
Prispevkov: 301
Aktiv.: 1.52
Kraj: Limbarska Gora
PrispevekObjavljeno: Čet Avg 20, 2009 8:13 pm    Naslov sporočila:   Odgovori s citatom
misliš da bi lahko dodal kondenzator ,da preklop sprednjih luči med dolgo kratko nebi bil tako viden.
Če je kam?
Drugače pa Applause Applause pohvale čeprav zaenrat še ne vem kako bom tole naredil Mr. Green
Aktiv.: 39.59
PrispevekObjavljeno: Čet Avg 20, 2009 9:23 pm    Naslov sporočila:   Odgovori s citatom
na shemi si napisal:
MANJKA UPOR IN KONDENZATOR NA RESETU!!!
Zakaj pa? saj Mega8 ima vgrajen power-on reset in ne rabi RC člena za reset Eh?
Tole bi lahko še malce bolj uredil in dal v zbirko projektov.
Slemi
Prispevkov: 386
Aktiv.: 1.62
Kraj: Hrastnik
PrispevekObjavljeno: Čet Avg 20, 2009 9:34 pm    Naslov sporočila:   Odgovori s citatom
mkosmac je napisal/a:
Daj razloži kaj te moti? V programu se da enostavno popraviti kako močno sveti kratka/dolga in kako hiter je prehod. S kondenzatorjem pa ne boš mogel tega rešiti.
aly je napisal/a:
Kaj pa vem. Moč navade.
aly je napisal/a:
Tudi to lahko. Vendar šele ko bo vezje prerisano v KiCAD. Rad bi da je res vse FREE.
P.S.: Se kdo javi da preriše vezje v KiCAD?
jjakob
Prispevkov: 1348
Aktiv.: 5.67
PrispevekObjavljeno: Čet Avg 20, 2009 10:40 pm    Naslov sporočila:   Odgovori s citatom
Slemi je napisal/a:
Mislim, da ga moti to, da je v realnosti prehod med dolgo in kratko lučjo bolj počasen zaradi velikega izklopnega in vklopnega časa halogenk. V softveru bi bilo to treba reševati z PWMjem, lahko pa to enostavno rešiš z elektrolitom direktno na LED. Predupor bo v tem primeru poskrbel za časovni zamik.
mkosmac
Prispevkov: 301
Aktiv.: 1.52
PrispevekObjavljeno: Pet Avg 21, 2009 8:22 pm    Naslov sporočila:   Odgovori s citatom
Slemi. Mislil sem če bi dodal elektrolitski kondenztor ne pa navaden kondenzator
Nič me ne moti, vesel sem da ste to tukaj objavili. Zanimalo me je zato ,ker bi se rad čimbolj približal utripanju rešilca
MMG:
Ali obstajajo LED diode debeline 1 ali 2mm?
Slemi
Prispevkov: 386
Aktiv.: 1.62
Kraj: Hrastnik
PrispevekObjavljeno: Pet Avg 21, 2009 8:28 pm    Naslov sporočila:   Odgovori s citatom
Okroglih LED mislim da ne boš dobil tako majhnih. Drugače pa bi verjetno bile prave SMD velikosti 0603 ali pa mogoče v skrajnem primeru 0805.
Varianta je da v vozilo (na maketi) montiraš LED diodo in od nje potegneš spredaj na vozilo optično vlakno. Takšno, ki ga dobiš na oni UFO svetilki iz Baumaxa. Nekaj podobnega temu.
Kondenzator pa vem da si mislil elektrolitski.
Slemi
Prispevkov: 386
Aktiv.: 1.62
Kraj: Hrastnik
PrispevekObjavljeno: Sre Sep 02, 2009 12:35 am    Naslov sporočila:   Odgovori s citatom
Evo še par slikic. V KiCAD-u je že, samo povezati še moram.
 Velikost datoteke:  29.82 KB
 Pogledana:  23 krat
 Velikost datoteke:  33.26 KB
 Pogledana:  17 krat
powr
Prispevkov: 668
Aktiv.: 3.13
PrispevekObjavljeno: Sob Dec 05, 2009 3:44 am    Naslov sporočila:   Odgovori s citatom
crtx je napisal/a:
ja
Prijavil si se na forum samo tato da napišeš "ja"? Very Happy
Moderatorji na delo Very Happy
mkosmac
Prispevkov: 301
Aktiv.: 1.52
PrispevekObjavljeno: Pet Dec 11, 2009 8:59 pm    Naslov sporočila:   Odgovori s citatom
Povezava ne deluje več.
Mogoče še kje drugje?
Slemi
Prispevkov: 386
Aktiv.: 1.62
Kraj: Hrastnik
PrispevekObjavljeno: Pet Dec 11, 2009 9:50 pm    Naslov sporočila:   Odgovori s citatom
Tule so datoteke v KiCAD-u. Sem že pred časom narisal vezje in ga pozabil tu prilepit. Shame on you
PWMakete001.rar
KiCAD projekt za lučke
 Ime datoteke:  PWMakete001.rar
 Velikost datoteke:  167.14 KB
 Downloadano:  12 krat
mkosmac
Prispevkov: 301
Aktiv.: 1.52
PrispevekObjavljeno: Čet Dec 17, 2009 8:47 pm    Naslov sporočila:   Odgovori s citatom
Prosim če lahko tole kodo kdo spravi v datoteko , ker so v njej neželene vsebine:
...unsigned char re, gr, [slovenščina je zame španska vas];//, pon; ...
Ko je bilo to objavljeno se nisem kaj dosti zanimal za progamiranje zdaj pa se nekako zelo počasi ˝učim˝ prek youtuba in googla
hvala Mr. Green
Stran 2 od 3
Uptime: 11 dni
