galex4 Član
Pridružen-a: Tor 01 Apr 2008 18:27 Prispevkov: 459 Aktiv.: 2.18
Objavljeno: Tor Nov 10, 2009 8:56 pm Naslov sporočila: |
kako pa dodat še več tipk?
program button1
dim Button_Pin as sbit at P3_2_bit
oldstate, oldstate1 as bit
Button1_Pin as sbit at p3_3_bit
main:
P1 = 255
oldstate = 0
oldstate1 = 0
while TRUE
if (Button(1, 0) <> 0) then ' detect logical one
oldstate = 1 ' update flag
end if
if (oldstate and Button(1, 1)) then ' detect one-to-zero transition
P1 = not P1 ' invert PORT2
oldstate = 0 ' update flag
end if
oldstate1 = 1
end if
if (oldstate1 and Button(1, 1)) then
P3.5 = 0
delay_ms (500)
oldstate1 = 0
end if
wend
end.
prevede brez problema, samo kako se ve kdaj je pritisnjena ena tipka in kdaj druga če je Button(1,1) v obeh primerih enak?
program ne deluje prav razen če zbrišem ta del:
oldstate1 = 1
end if
P3.5 = 0
delay_ms (500)
oldstate1 = 0
end if |
Uptime: 11 dni
