CCS problem s stringi
gumby
Prispevkov: 4066
Aktiv.: 18.41
PrispevekObjavljeno: Sob Mar 08, 2008 11:07 pm    Naslov sporočila:  CCS problem s stringi Odgovori s citatom
Tole je direkt iz help-a:
Koda:
The compiler allows a non-standard C feature to implement a constant array of variable length strings.
The syntax is:
const char id[n] [*] = { "string", "string" ...};
Where n is optional and id is the table identifier.
For example:
const char colors[] [*] = {"Red", "Green", "Blue"};
Prevajalnik tega ne prebavi, javi en kup napak #27 (Expression must evaluate to a constant) in #43 (Expecting a declaration).
*colors[] tudi ne deluje, čeprav ne javi napake v tem primeru.
colors[3][6] deluje, ampak to ni to...
Tule nisem več aktiven.
chaos
Prispevkov: 1063
Aktiv.: 4.66
Kraj: Zagorje ob Savi
PrispevekObjavljeno: Ned Mar 09, 2008 3:29 am    Naslov sporočila:   Odgovori s citatom
char ** ne deluje? To je čisto standardna zadeva ...
LP!
gumby
Prispevkov: 4066
Aktiv.: 18.41
PrispevekObjavljeno: Ned Mar 09, 2008 10:18 am    Naslov sporočila:   Odgovori s citatom
** ne deluje.
Prevajalnik javi tole:
Koda:
--- Info 300 "test.c" Line 0(0,0): More info:   First Declaration of ??0
*** Error 31 "test.c" Line 42(13,14): Identifier is already used in this scope
*** Error 43 "test.c" Line 42(23,24): Expecting a declaration
chaos
Prispevkov: 1063
Aktiv.: 4.66
PrispevekObjavljeno: Ned Mar 09, 2008 11:46 am    Naslov sporočila:   Odgovori s citatom
A lahko pripneš svojo kodo, tam kjer deklariraš in tam kjer uporabiš to spremenljivko?
LP!
gumby
Prispevkov: 4066
Aktiv.: 18.41
PrispevekObjavljeno: Ned Mar 09, 2008 12:30 pm    Naslov sporočila:   Odgovori s citatom
Koda:
#device PIC16F628A
const char **test = {"ena", "tristoosem", "666"};
void main()
Koda:
*** Error 27 "test.c" Line 3(23,24): Expression must evaluate to a constant
*** Error 43 "test.c" Line 3(25,26): Expecting a declaration
*** Error 43 "test.c" Line 3(27,28): Expecting a declaration
*** Error 43 "test.c" Line 3(33,34): Expecting a declaration
*** Error 43 "test.c" Line 3(42,43): Expecting a declaration
*** Error 43 "test.c" Line 3(50,51): Expecting a declaration
*** Error 43 "test.c" Line 3(51,52): Expecting a declaration
*** Error 31 "test.c" Line 4(13,14): Identifier is already used in this scope
*** Error 43 "test.c" Line 4(19,20): Expecting a declaration
*** Error 43 "test.c" Line 4(21,22): Expecting a declaration
*** Error 43 "test.c" Line 4(27,28): Expecting a declaration
*** Error 43 "test.c" Line 4(41,42): Expecting a declaration
*** Error 43 "test.c" Line 4(48,49): Expecting a declaration
*** Error 43 "test.c" Line 4(49,50): Expecting a declaration
      20 Errors,  0 Warnings.
Enako je, če dam deklaracije znotraj main().
chaos
Prispevkov: 1063
Aktiv.: 4.66
PrispevekObjavljeno: Ned Mar 09, 2008 12:43 pm    Naslov sporočila:   Odgovori s citatom
Pri deklaraciji bi moralo tole delovati:
const char *test[] = {"ena", "tristoosem", "666"};
**neki je pa pointer na takšen array pointer-jev.
LP!
gumby
Prispevkov: 4066
Aktiv.: 18.41
PrispevekObjavljeno: Ned Mar 09, 2008 1:20 pm    Naslov sporočila:   Odgovori s citatom
Moralo bi, ja... pojma nimam, kaj je tule narobe.
Osnove C (kazalci, polja, reference, ...) so mi jasne, zato mi je vse skup še bolj čudno
chaos
Prispevkov: 1063
Aktiv.: 4.66
PrispevekObjavljeno: Ned Mar 09, 2008 1:42 pm    Naslov sporočila:   Odgovori s citatom
Na hitro sem preizkusil takšen program (v treh različnih prevajalnikih):
Koda:
#include <stdio.h>
#include <stdlib.h>
int main (void)
  const char *str[] = {"ena", "tristoosem", "666"};
  const char **str_ptr;
  int i;
  str_ptr = str;
  // spodnje oboje deluje:
  for(i=0; i<3; i++) printf("%s\n", str[i]);
  for(i=0; i<3; i++) printf("%s\n", *str_ptr++);
  getch();
  exit(EXIT_SUCCESS);
Deluje b.p. Se pravi v kodi ni problem, mogoče pa ima tvoj prevajalnik kakšne svoje 'težave'.
V vsakem primeru bi to moralo delovati, razen če kje spreminjaš te nize (zaradi const). Potem ti bo verjetno procesor zablokiral ...
LP!
gumby
Prispevkov: 4066
Aktiv.: 18.41
PrispevekObjavljeno: Ned Mar 09, 2008 1:44 pm    Naslov sporočila:   Odgovori s citatom
Koda:
#include <16F628A.h>
void main ()
   char s[16]="test";
   char x[]="blabla";
   int i;
   for(i=0;i<3;i++)
      sprintf(s,"%s",test[i]);
      sprintf(s,"%s",x);
Tole prevajalnik prebavi, vendar prvi sprintf() ne naredi nič.
Če pri deklaraciji odstranim "const" dobim napako:
*** Error 74 "test.c" Line 17(0,1): Not enough RAM for all variables
**test javi napako, kot sem že napisal.
Tole pa deluje pravilno, z in brez "const":
Koda:
const char test[3][16] = {"ena", "tristoosem", "666"};
void main ()
   char s[16]="test";
   char x[]="blabla";
   int i;
   for(i=0;i<3;i++)
      sprintf(s,"%s",x);
Kot pika na i se MPLAB sesuje, ko je v primeru *test[] delkaracije ta vključena v watch okno. Confused
chaos
Prispevkov: 1063
Aktiv.: 4.66
PrispevekObjavljeno: Ned Mar 09, 2008 2:04 pm    Naslov sporočila:   Odgovori s citatom
Sem poizkusil tvoj zadnji primer, pa pri meni deluje normalno. Zdaj ali ima tvoj prevajalnik probleme, ali je pa stvar v arhitekturi (const string je verjetno v code sekciji, kar je mogoče 'predaleč' za pointer ...).
Treba bi bilo pogledati kodo v assemblerju, da bi se videlo, kaj se dogaja. Tukaj ti pa ne morem pomagati, ker ne poznam assemblerja oz. ukazov za pic-e ...
LP!
p.s.: podobna stvar (const char ....) deluje normalno na 8051 ...
gumby
Prispevkov: 4066
Aktiv.: 18.41
PrispevekObjavljeno: Ned Mar 09, 2008 7:33 pm    Naslov sporočila:   Odgovori s citatom
Očitno ima prevajalnik prebavne motnje
NeoTO
Prispevkov: 2752
Aktiv.: 11.62
Kraj: Trzic
PrispevekObjavljeno: Ned Mar 09, 2008 8:58 pm    Naslov sporočila:   Odgovori s citatom
Nič novega za CCS... Porihtajo eno stvar in druga banalna stvar ne dela več...
Lp,
Matevž
Uptime: 493 dni
