PC_Master Član
Pridružen-a: Pon 17 Mar 2008 20:10 Prispevkov: 319 Aktiv.: 1.52 Kraj: Domžale , Blizu Ljubljane , Poštna 1230
Objavljeno: Sob Mar 22, 2008 5:26 pm Naslov sporočila: Arduino in vprašanja |
Zivijo , zelo me je pritegnil Arduino in njegov enostaven "C" programski jezik.
Zanima me , ali je možno uporabljati Arduino programski jezik in narediti .HEX dadoteko , nato pa programirati kakšen AVR na poljubnem programerjem?
Hvala. |
Branez Moderator
Objavljeno: Sob Mar 22, 2008 6:22 pm Naslov sporočila: |
Tam (Arduino) imaš forum kjer boš sigurno dobil odgovor.
Arduino Forum je napisal/a: |
Now what we need to do is add a Target so that we can build our app via Hitting the Build button in Xcode.
Right click on Targets and click Add new Target.
Click Shell Script Target
Type Build Hex
Close the window that pops up.
Now hit the little arrow to the right of the Targets. You will now see Build Hex
right click it and now choose New Build Phase - New Run Script Build Phase.
Now in the script dialog box type
Koda: |
Code:make clean
make
echo "BUILD"
exit 0 |
Now you are finished. You can read the Makefile to setup your cpp file for building. After you do that you can now click Build to get a build. If you look in your project directory you will hopefully see a test.hex file. If so then I wrote this tutorial correctly and you followed it correctly. If not post a message and I will try and help you.
Albert Einstein |
PC_Master Član
Objavljeno: Sob Mar 22, 2008 6:56 pm Naslov sporočila: |
Branez je napisal/a: |
Type Build Hex
Koda: |
Code:make clean
make
echo "BUILD"
exit 0 |
Hvala! |
Akul Neznanec
Pridružen-a: Čet 28 Feb 2008 0:57 Prispevkov: 4 Aktiv.: 0.02 Kraj: Ljubljana
Objavljeno: Sob Apr 05, 2008 11:24 pm Naslov sporočila: |
Zdravo,
mesec nazaj sem si kupil Arduino Diecimilo z namenom da se bom skozi prakso naučil čimveč o elektroniki. Čist lepo počasi sem napredovol dokler nisem našel projekta, ki uporablja atmega32. Zdej se mi pa kar naenkrat tako "mudi" da ni časa da bi se o stvari podučil in mi boste morali oprostiti če je vprašanje butasto. Zanima me kako oziroma če je sploh možno programirati atmega32 skozi arduino? |
Branez Moderator
Objavljeno: Ned Apr 06, 2008 6:52 am Naslov sporočila: |
Tam (Arduino) imaš forum kjer boš sigurno dobil odgovor. |
Pa menda FAQ tudi obstaja.  _________________ The true sign of intelligence is not knowledge but imagination.
Albert Einstein |
