bascom tiny26 PWM
red_mamba
Prispevkov: 1486
Aktiv.: 6.27
Kraj: Yogyakarta
PrispevekObjavljeno: Pet Maj 23, 2008 10:49 pm    Naslov sporočila:  bascom tiny26 PWM Odgovori s citatom
Je že komu to uspelo spravit v pogon Confused
Koda:
Stop Watchdog
Dim Adc5 As Word
Dim Adc6 As Word
Dim Adc_cnt As Byte
Config Adc = Single , Prescaler = Auto , Reference = Internal
'Config Timer1 = Pwm , Prescale = 1 , Pwm = 8 , Compare A Pwm = Clear Down       ' , Compare B Pwm = Clear Down
Tccr1a = &B01010011
Tccr1b = &B00000001
'Tccr1b = &B00000001
Config Portb = Output
Ocr1c = 0
Ocr1a = 0
Ocr1b = 0
Pllcsr = 0
Start Adc
Start Timer1
Do
   Adc5 = Getadc(5)
   Adc6 = Getadc(6)
   Shift Adc5 , Right , 2
   Shift Adc6 , Right , 2
   Ocr1a= Adc5
   Ocr1b= Adc6
   Waitms 100
Loop
Blog
Peter
Pridružen-a: Sre 30 Jun 2004 12:55
Prispevkov: 375
Aktiv.: 1.58
Kraj: Pod krvavcem nekje
PrispevekObjavljeno: Sob Maj 24, 2008 8:21 pm    Naslov sporočila:   Odgovori s citatom
Koda:
'lcb in adc
$regfile = "at26def.dat"
' default the internal osc runs at 1 MHz
$crystal = 1000000
Dim Utipala As Word , Channel As Byte ,                     'Enice As Word
Dim Oadc As Word , Pomozna As Word ,
'Config Lcd = 16 * 2
'Config Lcdpin = Pin , Db4 = Portb.1 , Db5 = Portb.2 , Db6 = Portb.3 , Db7 = Portb.4 , E = Portb.5 , Rs = Portb.6
'Config Timer2 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 1
Tccr1a = &B01010011                                         'Manuelle Konfiguration von OC1a
Tccr1b = &B10000101                                         'Manuelle Konfiguration von OC1b
Ocr1c = 255                                                 'Top Limmit
Config Pinb.0 = Output                                      'Port b.0 als Ausgang
Config Pinb.1 = Output                                      'Port b.1 als Ausgang
Config Pinb.2 = Output                                      'Port b.2 als Ausgang
Config Pinb.3 = Output                                      'Port b.3 als Ausgang
Ch1 Alias Ocr1a                                             'PWMA Channel
Ch0 Alias Ocr1b
Start Adc
Cls
Channel = 0
'now read A/D value from channel 0
Ch0 = 50                                                    'PWMB Channel
Ch1 = 50
Do
  Waitms 5
  Oadc = Getadc(channel)
  Utipala = Oadc / 11
  Utipala = Utipala + 10
If Ch1 > 220 Then
  Ch0 = 220
  Ch1 = 220
End If
Ch0 = Utipala
Ch1 = Utipala
Pomozna = Utipala
Loop
End
To je meni delovalo
Vse se da pokvarit, le če se dovol časa ukvarjaš z njo!!!
red_mamba
Prispevkov: 1486
Aktiv.: 6.27
Kraj: Yogyakarta
PrispevekObjavljeno: Ned Maj 25, 2008 11:20 am    Naslov sporočila:   Odgovori s citatom
bom preizkusil,
verjetno je problem v start timer1 pri meni, sedaj moram samo praktično preizkusit Very Happy
Blog
red_mamba
Prispevkov: 1486
Aktiv.: 6.27
Kraj: Yogyakarta
PrispevekObjavljeno: Tor Maj 27, 2008 11:23 am    Naslov sporočila:   Odgovori s citatom
no včeraj preizkusil, je bil problem v tem
Start timer1 ubistvu ugasne časovnik1.
Brez tega ukaza dela vse tako kot mora Very Happy
Blog
