senzor SHT in CRC
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Periferija
SimonS
Prispevkov: 4766
Aktiv.: 20.14
Kraj: Kobarid
PrispevekObjavljeno: Tor Apr 15, 2008 1:22 pm    Naslov sporočila:  senzor SHT in CRC Odgovori s citatom
Pozdrav
Je komu uspelo racunati CRC za omenjeni senzor? Meni mi vedno vraca napako Moj programcek izgeda a tako:
Koda:
void SHT_crc(unsigned char ukaz,unsigned char msb,unsigned char lsb,unsigned char crc)
// izracun CRCja
   unsigned char a=0;
   a= a^ukaz;
   a= CRC_tab[a];
   a= a^msb;
   a= CRC_tab[a];
   a= a^lsb;
   a= CRC_tab[a];
   if (!(a == crc)) sht.napaka =1;      //vrne napako ob napacnem CRCju
in se tabela:
Koda:
static const char CRC_tab[256]={
   0, 49, 98, 83, 196, 245,166, 151,185, 136,219, 234,125, 76, 31, 46, 67, 114,33, 16,
   135, 182,229, 212,250, 203,152, 169,62, 15, 92, 109,134, 183,228, 213,66, 115,32, 17,
   63, 14, 93, 108,251, 202,153, 168,197, 244,167, 150,1, 48, 99, 82, 124, 77, 30, 47,
   184, 137,218, 235,61, 12, 95, 110,249, 200,155, 170,132, 181,230, 215,64, 113,34, 19,
   126, 79, 28, 45, 186, 139,216, 233,199, 246,165, 148,3, 50, 97, 80, 187, 138,217, 232,
   127, 78, 29, 44, 2, 51, 96, 81, 198, 247,164, 149,248, 201,154, 171,60, 13, 94, 111,
   65, 112,35, 18, 133, 180,231, 214,122, 75, 24, 41, 190, 143,220, 237,195, 242,161, 144,
   7, 54, 101, 84, 57, 8, 91, 106,253, 204,159, 174,128, 177,226, 211,68, 117,38, 23,
   252, 205,158, 175,56, 9, 90, 107,69, 116,39, 22, 129, 176,227, 210,191, 142,221, 236,
   123, 74, 25, 40, 6, 55, 100, 85, 194, 243,160, 145,71, 118,37, 20, 131, 178,225, 208,
   254, 207,156, 173,58, 11, 88, 105,4, 53, 102, 87, 192, 241,162, 147,189, 140,223, 238,
   121, 72, 27, 42, 193, 240,163, 146,5, 52, 103, 86, 120, 73, 26, 43, 188, 141,222, 239,
   130, 179,224, 209,70, 119,36, 21, 59, 10, 89, 104,255, 206,157, 172 };
Program za branje je sledec:
Koda:
        s_start();                         //posljemo start
         sp_byte(M_TEM);
         for (i=0;i<0x5fffff;i++) if (!(IOPIN0 & DATA)) break;    //pocakaj, da senzor opravi meritev
        if (IOPIN0 & DATA) sht.napaka = 1;                      //... ali prekinitev cez ~2 sec in sporocimo napako
         msb  = sb_byte(ACK);                            //beri prvi bajt (MSB)
      rezultat = msb;
      rezultat <<= 8;
         lsb  = sb_byte(ACK);                            //beri drugi bajt (LSB)
      rezultat  |= lsb;
        crc =sb_byte(noACK);                             //beri checksum
      vrni = sp_temp(rezultat);
       for (i=0;i<0x60ffff;i++);                        // 0.8sec, da se nam senzor ne ugreje prevec!
      SHT_crc(M_TEM, msb, lsb, crc);                        // racunamo CRC za temperaturo
Prilagam se dokumentacijo:
p.s. primer iz dokumentacije pravilno izracuna:
CRC_Calculation_SHTxx_v1.03.pdf
 Ime datoteke:  CRC_Calculation_SHTxx_v1.03.pdf
 Velikost datoteke:  123.46 KB
 Downloadano:  3 krat
Lep dan
Simon
SimonS
Prispevkov: 4766
Aktiv.: 20.14
Kraj: Kobarid
PrispevekObjavljeno: Tor Apr 15, 2008 3:24 pm    Naslov sporočila:   Odgovori s citatom
Uh, sem spregledal. V PDFju pise, da je treba obrniti rezultat, preden primirjamo z tabelo (hecno, zakaj jim je bilo tega treba Evil or Very Mad )
Delujoca koda zgleda tako:
Koda:
   unsigned char c,b,a=0;
   a= a^ukaz;
   a= CRC_tab[a];
   a= a^msb;
   a= CRC_tab[a];
   a= a^lsb;
   a= CRC_tab[a];
    for(b = c = 0; c < 8; c++)       //obrnemo vrednost rezultata bit7=bit0, bit6=bit1,...
        b = (b << 1) + (a & 1);
        a >>= 1;
   if (!(b == crc)) sht.napaka =1;      //vrne napako ob napacnem CRCju
Lep dan
Simon
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Periferija Časovni pas GMT + 2 uri, srednjeevropski - poletni čas
Uptime: 485 dni
