PC_Master Član
Pridružen-a: Pon 17 Mar 2008 20:10 Prispevkov: 319 Aktiv.: 1.52 Kraj: Domžale , Blizu Ljubljane , Poštna 1230
Objavljeno: Pon Jun 23, 2008 4:44 pm Naslov sporočila: Problem z USB programatorjem |
Delam preko WinAvr ( Programemer's Notepad )
Hočem to kodo zloadati v AtMega32
Koda: |
#include <avr/io.h>
/// Typedefs //////////
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
/// Defines ///////////
#define forever 117
#define LEDOFF PORTB |= (1<<4)
#define LEDON PORTB &= ~(1<<4)
/// Prototypes ////////
void InitPorts (void);
void Delay (u32 count);
int main(void)
InitPorts();
while (forever)
LEDON; Delay(20000);
LEDOFF; Delay(20000);
void InitPorts(void)
DDRB |= 1<<DDB4;
void Delay(u32 count)
while(count--);
Ampak mi napiše ko zaženem "Program"
Koda: |
> "make.exe" program
avrdude -p atmega32 -P com3 -c avr910 -U flash:w:blink_1MHz.hex
Found programmer: Id = "AVR ISP"; type = S
Software Version = 2.5; Hardware Version = 2.0
Programmer supports auto addr increment.
Programmer supports the following devices:
Device code: 0x01 = (unknown)
Device code: 0x02 = (unknown)
Device code: 0x03 = (unknown)
Device code: 0x04 = (unknown)
Device code: 0x05 = (unknown)
Device code: 0x06 = (unknown)
Device code: 0x07 = (unknown)
Device code: 0x08 = (unknown)
Device code: 0x09 = (unknown)
Device code: 0x0a = (unknown)
Device code: 0x0b = (unknown)
Device code: 0x0c = (unknown)
Device code: 0x0d = (unknown)
Device code: 0x0e = (unknown)
Device code: 0x0f = (unknown)
Device code: 0x10 = (unknown)
Device code: 0x11 = (unknown)
Device code: 0x12 = (unknown)
Device code: 0x13 = AT90S1200
Device code: 0x14 = (unknown)
Device code: 0x15 = (unknown)
Device code: 0x16 = (unknown)
Device code: 0x17 = (unknown)
Device code: 0x18 = (unknown)
Device code: 0x19 = (unknown)
Device code: 0x1a = (unknown)
Device code: 0x1b = (unknown)
Device code: 0x1c = (unknown)
Device code: 0x1d = (unknown)
Device code: 0x1e = (unknown)
Device code: 0x1f = (unknown)
Device code: 0x20 = ATtiny84
Device code: 0x21 = (unknown)
Device code: 0x22 = (unknown)
Device code: 0x23 = (unknown)
Device code: 0x24 = (unknown)
Device code: 0x25 = (unknown)
Device code: 0x26 = (unknown)
Device code: 0x27 = (unknown)
Device code: 0x28 = AT90S4414
Device code: 0x29 = (unknown)
Device code: 0x2a = (unknown)
Device code: 0x2b = (unknown)
Device code: 0x2c = (unknown)
Device code: 0x2d = (unknown)
Device code: 0x2e = (unknown)
Device code: 0x2f = (unknown)
Device code: 0x30 = AT90S4433
Device code: 0x31 = (unknown)
Device code: 0x32 = (unknown)
Device code: 0x33 = (unknown)
Device code: 0x34 = AT90S2333
Device code: 0x35 = (unknown)
Device code: 0x36 = (unknown)
Device code: 0x37 = (unknown)
Device code: 0x38 = AT90S8515
Device code: 0x39 = (unknown)
Device code: 0x3a = ATMEGA8515
Device code: 0x3b = (unknown)
Device code: 0x3c = (unknown)
Device code: 0x3d = (unknown)
Device code: 0x3e = (unknown)
Device code: 0x3f = (unknown)
Device code: 0x40 = (unknown)
Device code: 0x41 = ATMEGA103
Device code: 0x42 = (unknown)
Device code: 0x43 = ATMEGA128
Device code: 0x44 = (unknown)
Device code: 0x45 = ATMEGA64
Device code: 0x46 = (unknown)
Device code: 0x47 = (unknown)
Device code: 0x48 = (unknown)
Device code: 0x49 = (unknown)
Device code: 0x4a = (unknown)
Device code: 0x4b = (unknown)
Device code: 0x4c = AT90S2343
Device code: 0x4d = (unknown)
Device code: 0x4e = (unknown)
Device code: 0x4f = (unknown)
Device code: 0x50 = (unknown)
Device code: 0x51 = (unknown)
Device code: 0x52 = (unknown)
Device code: 0x53 = (unknown)
Device code: 0x54 = (unknown)
Device code: 0x55 = ATtiny12
Device code: 0x56 = ATtiny15
Device code: 0x57 = (unknown)
Device code: 0x58 = (unknown)
Device code: 0x59 = (unknown)
Device code: 0x5a = (unknown)
Device code: 0x5b = (unknown)
Device code: 0x5c = (unknown)
Device code: 0x5d = (unknown)
Device code: 0x5e = ATtiny2313
Device code: 0x5f = (unknown)
Device code: 0x60 = ATMEGA161
Device code: 0x61 = (unknown)
Device code: 0x62 = (unknown)
Device code: 0x63 = ATMEGA162
Device code: 0x64 = ATMEGA163
Device code: 0x65 = (unknown)
Device code: 0x66 = (unknown)
Device code: 0x67 = (unknown)
Device code: 0x68 = AT90S8535
Device code: 0x69 = ATMEGA8535
Device code: 0x6a = (unknown)
Device code: 0x6b = (unknown)
Device code: 0x6c = AT90S4434
Device code: 0x6d = (unknown)
Device code: 0x6e = (unknown)
Device code: 0x6f = (unknown)
Device code: 0x70 = (unknown)
Device code: 0x71 = (unknown)
Device code: 0x72 = ATMEGA32
Device code: 0x73 = (unknown)
Device code: 0x74 = ATMEGA6450
Device code: 0x75 = ATMEGA6490
Device code: 0x76 = ATMEGA8
Device code: 0x77 = (unknown)
Device code: 0x78 = ATMEGA169
Device code: 0x79 = (unknown)
Device code: 0x7a = (unknown)
Device code: 0x7b = (unknown)
Device code: 0x7c = (unknown)
Device code: 0x7d = (unknown)
Device code: 0x7e = (unknown)
Device code: 0x7f = (unknown)
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.06s
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
make.exe: *** [program] Error 1
> Process Exit Code: 2
> Time Taken: 00:01
Ima kdo kakšne ideje?
Usb Programer pa je :
mySmartUSB od myAvr Klik! |
int47 Član
Objavljeno: Pon Jun 23, 2008 6:57 pm Naslov sporočila: |
Koda: |
this check.
Preveri:
-če je napajalna napetost v tolerancah
-če je vse prav povezano,
-če ni kje kakšnega kratkega stika.
-če je frekvenca SCK dovolj nizka glede na izbrani oscilator,
-če je izbran delujoč oscilator,
-da med programiranjem kakšna komponenta ne vsiljuje svojega stanja na MISO, MOSI, SCK ali RESET
Lahko poskusiš predlagano -F opcijo, ki preskoči preverjanje podpisa.
Si kaj spreminjal fuse bite, preden se je uC nehal odzivat, ali še ni oživel?
Kako je izveden RESET ? |
PC_Master Član
Objavljeno: Tor Jun 24, 2008 8:25 am Naslov sporočila: |
Reset ima tipko na GND in 6kiloomski upor na +5.
Pomoje je napajanje stabilno , saj imam za 400uF kondenzatorjev med + in gnd , pa še napajam iz laboratorijskega vmesnika. |
Uptime: 493 dni
