Problem z USB programatorjem
PC_Master
Pridružen-a: Pon 17 Mar 2008 20:10
Prispevkov: 319
Aktiv.: 1.52
Kraj: Domžale , Blizu Ljubljane , Poštna 1230
PrispevekObjavljeno: Pon Jun 23, 2008 4:44 pm    Naslov sporočila:  Problem z USB programatorjem Odgovori s citatom
Delam preko WinAvr ( Programemer's Notepad )
Hočem to kodo zloadati v AtMega32
Koda:
#include <avr/io.h>
/// Typedefs //////////
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
/// Defines ///////////
#define forever         117
#define LEDOFF          PORTB |= (1<<4)
#define LEDON           PORTB &= ~(1<<4)
/// Prototypes ////////
void InitPorts (void);
void Delay (u32 count);
int main(void)
    InitPorts();
    while (forever)
        LEDON; Delay(20000);
        LEDOFF; Delay(20000);
void InitPorts(void)
    DDRB |= 1<<DDB4;
void Delay(u32 count)
    while(count--);
Ampak mi napiše ko zaženem "Program"
Koda:
> "make.exe" program
avrdude -p atmega32 -P com3 -c avr910    -U flash:w:blink_1MHz.hex
Found programmer: Id = "AVR ISP"; type = S
    Software Version = 2.5; Hardware Version = 2.0
Programmer supports auto addr increment.
Programmer supports the following devices:
    Device code: 0x01 = (unknown)
    Device code: 0x02 = (unknown)
    Device code: 0x03 = (unknown)
    Device code: 0x04 = (unknown)
    Device code: 0x05 = (unknown)
    Device code: 0x06 = (unknown)
    Device code: 0x07 = (unknown)
    Device code: 0x08 = (unknown)
    Device code: 0x09 = (unknown)
    Device code: 0x0a = (unknown)
    Device code: 0x0b = (unknown)
    Device code: 0x0c = (unknown)
    Device code: 0x0d = (unknown)
    Device code: 0x0e = (unknown)
    Device code: 0x0f = (unknown)
    Device code: 0x10 = (unknown)
    Device code: 0x11 = (unknown)
    Device code: 0x12 = (unknown)
    Device code: 0x13 = AT90S1200
    Device code: 0x14 = (unknown)
    Device code: 0x15 = (unknown)
    Device code: 0x16 = (unknown)
    Device code: 0x17 = (unknown)
    Device code: 0x18 = (unknown)
    Device code: 0x19 = (unknown)
    Device code: 0x1a = (unknown)
    Device code: 0x1b = (unknown)
    Device code: 0x1c = (unknown)
    Device code: 0x1d = (unknown)
    Device code: 0x1e = (unknown)
    Device code: 0x1f = (unknown)
    Device code: 0x20 = ATtiny84
    Device code: 0x21 = (unknown)
    Device code: 0x22 = (unknown)
    Device code: 0x23 = (unknown)
    Device code: 0x24 = (unknown)
    Device code: 0x25 = (unknown)
    Device code: 0x26 = (unknown)
    Device code: 0x27 = (unknown)
    Device code: 0x28 = AT90S4414
    Device code: 0x29 = (unknown)
    Device code: 0x2a = (unknown)
    Device code: 0x2b = (unknown)
    Device code: 0x2c = (unknown)
    Device code: 0x2d = (unknown)
    Device code: 0x2e = (unknown)
    Device code: 0x2f = (unknown)
    Device code: 0x30 = AT90S4433
    Device code: 0x31 = (unknown)
    Device code: 0x32 = (unknown)
    Device code: 0x33 = (unknown)
    Device code: 0x34 = AT90S2333
    Device code: 0x35 = (unknown)
    Device code: 0x36 = (unknown)
    Device code: 0x37 = (unknown)
    Device code: 0x38 = AT90S8515
    Device code: 0x39 = (unknown)
    Device code: 0x3a = ATMEGA8515
    Device code: 0x3b = (unknown)
    Device code: 0x3c = (unknown)
    Device code: 0x3d = (unknown)
    Device code: 0x3e = (unknown)
    Device code: 0x3f = (unknown)
    Device code: 0x40 = (unknown)
    Device code: 0x41 = ATMEGA103
    Device code: 0x42 = (unknown)
    Device code: 0x43 = ATMEGA128
    Device code: 0x44 = (unknown)
    Device code: 0x45 = ATMEGA64
    Device code: 0x46 = (unknown)
    Device code: 0x47 = (unknown)
    Device code: 0x48 = (unknown)
    Device code: 0x49 = (unknown)
    Device code: 0x4a = (unknown)
    Device code: 0x4b = (unknown)
    Device code: 0x4c = AT90S2343
    Device code: 0x4d = (unknown)
    Device code: 0x4e = (unknown)
    Device code: 0x4f = (unknown)
    Device code: 0x50 = (unknown)
    Device code: 0x51 = (unknown)
    Device code: 0x52 = (unknown)
    Device code: 0x53 = (unknown)
    Device code: 0x54 = (unknown)
    Device code: 0x55 = ATtiny12
    Device code: 0x56 = ATtiny15
    Device code: 0x57 = (unknown)
    Device code: 0x58 = (unknown)
    Device code: 0x59 = (unknown)
    Device code: 0x5a = (unknown)
    Device code: 0x5b = (unknown)
    Device code: 0x5c = (unknown)
    Device code: 0x5d = (unknown)
    Device code: 0x5e = ATtiny2313
    Device code: 0x5f = (unknown)
    Device code: 0x60 = ATMEGA161
    Device code: 0x61 = (unknown)
    Device code: 0x62 = (unknown)
    Device code: 0x63 = ATMEGA162
    Device code: 0x64 = ATMEGA163
    Device code: 0x65 = (unknown)
    Device code: 0x66 = (unknown)
    Device code: 0x67 = (unknown)
    Device code: 0x68 = AT90S8535
    Device code: 0x69 = ATMEGA8535
    Device code: 0x6a = (unknown)
    Device code: 0x6b = (unknown)
    Device code: 0x6c = AT90S4434
    Device code: 0x6d = (unknown)
    Device code: 0x6e = (unknown)
    Device code: 0x6f = (unknown)
    Device code: 0x70 = (unknown)
    Device code: 0x71 = (unknown)
    Device code: 0x72 = ATMEGA32
    Device code: 0x73 = (unknown)
    Device code: 0x74 = ATMEGA6450
    Device code: 0x75 = ATMEGA6490
    Device code: 0x76 = ATMEGA8
    Device code: 0x77 = (unknown)
    Device code: 0x78 = ATMEGA169
    Device code: 0x79 = (unknown)
    Device code: 0x7a = (unknown)
    Device code: 0x7b = (unknown)
    Device code: 0x7c = (unknown)
    Device code: 0x7d = (unknown)
    Device code: 0x7e = (unknown)
    Device code: 0x7f = (unknown)
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.06s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
make.exe: *** [program] Error 1
> Process Exit Code: 2
> Time Taken: 00:01
Ima kdo kakšne ideje?
Usb Programer pa je :
mySmartUSB od myAvr Klik!
int47
Prispevkov: 2104
Aktiv.: 8.88
PrispevekObjavljeno: Pon Jun 23, 2008 6:57 pm    Naslov sporočila:   Odgovori s citatom
Koda:
         this check.
Preveri:
-če je napajalna napetost v tolerancah
-če je vse prav povezano,
-če ni kje kakšnega kratkega stika.
-če je frekvenca SCK dovolj nizka glede na izbrani oscilator,
-če je izbran delujoč oscilator,
-da med programiranjem kakšna komponenta ne vsiljuje svojega stanja na MISO, MOSI, SCK ali RESET
Lahko poskusiš predlagano -F opcijo, ki preskoči preverjanje podpisa.
Si kaj spreminjal fuse bite, preden se je uC nehal odzivat, ali še ni oživel?
Kako je izveden RESET ?
PC_Master
Prispevkov: 319
Aktiv.: 1.52
PrispevekObjavljeno: Tor Jun 24, 2008 8:25 am    Naslov sporočila:   Odgovori s citatom
Reset ima tipko na GND in 6kiloomski upor na +5.
Pomoje je napajanje stabilno , saj imam za 400uF kondenzatorjev med + in gnd , pa še napajam iz laboratorijskega vmesnika.
