PIC 18F4550 USB to comm using CDC problem
tpek
Pridružen-a: Tor 28 Okt 2008 3:27
Prispevkov: 1
Aktiv.: 0.00
Kraj: United Kingdom
PrispevekObjavljeno: Tor Okt 28, 2008 3:33 am    Naslov sporočila:  PIC 18F4550 USB to comm using CDC problem Odgovori s citatom
Helo all,
We are currently in a project involving data aquisition to a PC with the PIC 18F4550.
Data is send to the PC via USB port but PC must see a virtual comm port. Microchip offers standard library, CDC for doing so. Standard Windows driver is also used.
A simple program (just periodically send fixed data to the PC) works fine, but in a few seconds (randomly) packets are no more received.
I will apreciate a lot, if someone can provide me information on proper use of CDC or any other virtual comm port generation with USB-PIC; that is sample programs (are no being provided by microchip), known bugs, etc.
Thanks a lot for your time
matjazkariz
Prispevkov: 1026
Aktiv.: 4.15
PrispevekObjavljeno: Tor Nov 04, 2008 2:01 pm    Naslov sporočila:   Odgovori s citatom
Hi,
have you tried using CDC version 1.2 or older one? I have succesfully implemented the code to a PIC18F4550. Some time ago I had the intention to migrate the code to smaller 18F2550 but to no avail.
Anyway check the hardware, build with the last library, program with the right configuration and it should work...
You can also check the two projects below which work fine with me:
http://www.sixca.com/eng/articles/usbdaq/index.html
http://www.sixca.com/eng/articles/usb_cdc/
LP, Matjaž
Uptime: 233 dni
