I2C
Prispevkov: 16777193
Aktiv.: 70630.01
PrispevekObjavljeno: Tor Okt 26, 2004 9:21 pm    Naslov sporočila:  I2C Odgovori s citatom
Prispevkov: 14678
Aktiv.: 61.79
PrispevekObjavljeno: Tor Okt 26, 2004 9:42 pm    Naslov sporočila:   Odgovori s citatom
Sama izvedba z mikrokontrolerjem ne bi smela predstavljati večjega problema. Ko bom naredil adapter RS232 za testno ploščo bom spisal en tak programček. Za komunikacijo z mikrokontrolerjem pa bi uporabil kar "hyper terminal"
Sicer poskusi z Googlom "Serial to i2c converter"
Eden iz med mnogih zanimivih zadetkov
Aktiv.: 70630.01
PrispevekObjavljeno: Sre Okt 27, 2004 8:08 am    Naslov sporočila:   Odgovori s citatom
Prispevkov: 14678
Aktiv.: 61.79
PrispevekObjavljeno: Sre Okt 27, 2004 1:34 pm    Naslov sporočila:   Odgovori s citatom
Preden se zadeve lotim poskusi program z gornje povezave. Uporabljen je 12F675 . Dodaš še en max232 pa bi stvar morala delati s treminalskim programom.
Opis programa
Koda:
; The purpose of this converter is to to control an i2c bus (100kHz)
; from an asynchronous serial interface (1200..9600bps, 8bit, no parity).
; write:  1010nnnn aaaaaaa0 data..     response: 00000000
; read:   1010nnnn aaaaaaa1            response: 0000nnnn data..
; The first byte to the serial port must start with the 1010 bit pattern.
; (other bytes are ignored to lock to commands if the track was lost)
; nnnn is the number of i2c data bytes (0001 = 1 .. 1111 = 15, 0000 = 16).
; The second byte is the i2c control code containing the device address
; aaaaaaa and bit0 cleared for write or set for read.
; Example 1: initialising a PCF8591 (DAC to 123)
; transmit: 0xA2 0x90 0x44 0x7B  reponse: 0x00 (or 0xFF on error)
; Example 2: reading the four PCF8591 ADC values
; transmit: 0xA4 0x91  reponse: 0x04 ?? ?? ?? ?? (or 0xFF on error)
; The error code 0xFF is returned if the addressed device did not repond.
; Connections:
;      +5V    VCC **  1                8 ** GND    GND
;      BD1    GP5 **  2                7 ** GP0    BD0
;      TXD    GP4 **  3                6 ** GP1    SCL
;      RXD    GP3 **  4                5 ** GP2    SDA
;                  *      PIC12F675      *
; RXD (receive data) and TXD (transmit data) are the serial I/Os.
; BD1 and BD0 select the baudrate and have internal pullups:
;            BD1    |   BD0    |   bits per second
;            open   |   open   |        9600
;            open   |   GND    |        4800
;            GND    |   open   |        2400
;            GND    |   GND    |        1200
; The i2c signals SCL and SDA have internal weak pullups enabled.
; This works if a single i2c device is connected width short wires
; but for a larger bus capacity external pullups are recommended.
; Since the PIC fakes open collector outputs with tristate pins
; i2c peripherals should share the same supply voltage.
; The PIC12F675 ADC is not used: a PIC12F629 may be used a well.
; No timers or interrupts used: code may be adapted to any PIC12xxx.
s2i.zip
 Ime datoteke:  s2i.zip
 Velikost datoteke:  3.94 KB
 Downloadano:  9 krat
Aktiv.: 70630.01
PrispevekObjavljeno: Sre Okt 27, 2004 1:57 pm    Naslov sporočila:   Odgovori s citatom
Prispevkov: 14678
Aktiv.: 61.79
PrispevekObjavljeno: Sre Okt 27, 2004 1:59 pm    Naslov sporočila:   Odgovori s citatom
Najenostavnejša varianta JDM (zadnja verzija, ki podpira tudi 12Fxx) - mislim, da je načrt ter TIV nekje na forumu.
