GSM/GPRS modem sony ericsson GM29
harpoon
Pridružen-a: Sre 06 Jul 2005 9:23
Prispevkov: 123
Aktiv.: 0.52
Kraj: Domžale
PrispevekObjavljeno: Sre Dec 17, 2008 10:32 pm    Naslov sporočila:  GSM/GPRS modem sony ericsson GM29 Odgovori s citatom
Imam nekaj gsm/gprs modemov sony ericsson GM29, ker jih ne potrebujem več. (modemi so brez antene in konektorjev)
Prodam jih po polovični ceni (to je cca 65eur)
podatki:
• Dual Band EGSM 900/1800 MHz Terminal
• Compliant with 3GPP GSM Phase 2+ (GCF-CC v.3.8.1) standards (Small MS)
• Output power Class 4 (2W) @ 900 MHz) Class 1 (1W) @ 1800 MHz)
• Supply voltage 5-32 VDC
• Standard RS232 9-way serial connection
• Overall dimensions (excluding connectors): 77 x 67 x 26mm
• Operating Temperature: -30ºC to +75ºC
• Weight: < 130g
Interfaces
• Data: RS232 9-way (V.2Cool
• Remote control by AT commands
• Serial baud rate from 1200 to 460,800 bits/s
• Power: 5-32 VDC RJ11 connector
• Audio: 4-wire handset interface RJ9 connector
• Antenna: 50 ohm
• FME male connector
• SIM card reader: 3V/5V SIM interface with SIM detection
Data Features
• CSD asynchronous - non tranparent up to 9.6kbps
• HSCSD (2+1), up to 19.2 kbps
• MS Class B, GPRS Class 8, up to 85.6 kbps*
• P Channel support
• Coding schemes CS1-CS4
• GSM 07.10 Multiplexing Protocol
Short Messaging Service (SMS) Features
<!--[if !supportLineBreakNewLine]-->
<!--[endif]-->
• Text and PDU
• Point to point (MT/MO)
• Cell Broadcast
• Concatenation – up to 6 SMS
Fax Features
• Fax Group 3, Class 1 & 2
Voice Features
<!--[endif]-->
• Telephony
• Emergency calls
• Full Rate, Enhanced Full Rate and Half Rate (FR/EFR/HR)
• Dual Tone Multi Frequency function (DTMF)
TCP/IP
• Intrinsic TCP/IP protocol stack
• AT Command access to TCP/IP stack
GSM Supplementary Services
• Call forwarding
• Call hold, waiting and multiparty
• Calling/called number identification
• Advice of charge
• USSD
• Alternate line service
• Customer service profile
• Preferred networks
• Operator selection
• Network registration
• Call barring
• Call transfer
Other Features
• ME + SIM phone book management – read/write/find, call screening, groups
• SIM Application Toolkit Class 2
• Real Time Clock
• Software upgradeable
• Audio control
• Fixed dialling number
• UCS2 16 bit data supported
• Commercially available accessories
LP Mare
