Error handle in assembler
ciko
Pridružen-a: Čet 27 Mar 2008 11:41
Prispevkov: 126
Aktiv.: 0.60
Kraj: Novo mesto
PrispevekObjavljeno: Tor Jan 20, 2009 11:44 am    Naslov sporočila:  Error handle in assembler Odgovori s citatom
Živjo!
Iščem in iščem, pa ne najdem. Nekoč sem videl en zelo lep primer, kako manipulirati oz imeti detekcijo glede napake jedra - kdaj se sistem zruši.
Sedaj pa to iščem in ne najdem. Zato sem se lotil kar sam pisanja.
Zanima me, kako funkcijo, ki je napisana v c datoteki kličeš is *.s datoteke.
Zaenrkat sem poizkusil:
Del LPC2300.s kode
Koda:
; Area Definition and Entry Point
;  Startup Code must be linked first at Address at which it expects to run.
                AREA    RESET, CODE, READONLY
                ARM
; Exception Vectors
;  Mapped to Address 0.
;  Absolute addressing mode must be used.
;  Dummy Handlers are implemented as infinite loops which can be modified.
Vectors         LDR     PC, Reset_Addr
                LDR     PC, Undef_Addr
                LDR     PC, SWI_Addr
                LDR     PC, PAbt_Addr
                LDR     PC, DAbt_Addr
                NOP                            ; Reserved Vector
;               LDR     PC, IRQ_Addr
                LDR     PC, [PC, #-0x0120]     ; Vector from VicVectAddr
                LDR     PC, FIQ_Addr
Reset_Addr      DCD     Reset_Handler
Undef_Addr      DCD     Undef_Handler
SWI_Addr        DCD     SWI_Handler
PAbt_Addr       DCD     PAbt_Handler
DAbt_Addr       DCD     DAbt_Handler
                DCD     0                      ; Reserved Address
IRQ_Addr        DCD     IRQ_Handler
FIQ_Addr        DCD     FIQ_Handler
; moje
                IMPORT  __Undef_Handler_my
                IMPORT  __SWI_Handler_my
                IMPORT  __PAbt_Handler_my
                IMPORT  __DAbt_Handler_my
                IMPORT  __IRQ_Handler_my
                IMPORT  __FIQ_Handler_my
Undef_Handler   B       __Undef_Handler_my ; Undef_Handler
SWI_Handler     B       __SWI_Handler_my   ; SWI_Handler
PAbt_Handler    B       __PAbt_Handler_my  ; PAbt_Handler
DAbt_Handler    B       __DAbt_Handler_my  ; DAbt_Handler
IRQ_Handler     B       __IRQ_Handler_my   ; IRQ_Handler
FIQ_Handler     B       __FIQ_Handler_my   ; FIQ_Handler
in še funkicje v main.c datoteki:
Koda:
int Undef_Handler_my (void)
    SEND_TEXT("Undef_Handler_my\n\r");
    while(1);
void SWI_Handler_my  (void)
    SEND_TEXT("SWI_Handler_my\n\r");
    while(1);
void PAbt_Handler_my (void)
    SEND_TEXT("PAbt_Handler_my\n\r");
    while(1);
void DAbt_Handler_my (void)
    SEND_TEXT("DAbt_Handler_my\n\r");
    while(1);
void IRQ_Handler_my  (void)
    SEND_TEXT("IRQ_Handler_my\n\r");
    while(1);
void FIQ_Handler_my  (void)
    SEND_TEXT("FIQ_Handler_my\n\r");
    while(1);
Kako povezati, da se bo lahko iz s datoteke klicalo funkcijo v c datoteki?
Hvala za odgovore
Lep pozdrav
Peter
ciko
Prispevkov: 126
Aktiv.: 0.60
Kraj: Novo mesto
PrispevekObjavljeno: Tor Jan 20, 2009 3:33 pm    Naslov sporočila:   Odgovori s citatom
Težava je bila:
http://www.arm.com/support/faqdev/1242.html
in
vnese se točno taka imena funkcij, kot so definirane, ne pa s "__", kot sem jaz dal.
Pravilno:
Koda:
                PRESERVE8
                ARM
; Exception Vectors
                LDR     PC, Undef_Addr
                LDR     PC, SWI_Addr
                LDR     PC, PAbt_Addr
                LDR     PC, DAbt_Addr
;               LDR     PC, IRQ_Addr
                LDR     PC, FIQ_Addr
; moje
                IMPORT  Undef_Handler_my
                IMPORT  SWI_Handler_my
                IMPORT  PAbt_Handler_my
                IMPORT  DAbt_Handler_my
                IMPORT  FIQ_Handler_my
Undef_Handler   B     Undef_Handler_my ; Undef_Handler  ;
SWI_Handler     B     SWI_Handler_my ; SWI_Handler
PAbt_Handler    B     PAbt_Handler_my ; PAbt_Handler
DAbt_Handler    B     DAbt_Handler_my ; DAbt_Handler
IRQ_Handler     B     IRQ_Handler
FIQ_Handler     B     FIQ_Handler_my ; FIQ_Handler
Upam, da bo komu pomagalo.
Uptime: 6 dni
