lucca brassi Član
Objavljeno: Sre Apr 29, 2009 12:10 pm Naslov sporočila: THE SEX LIFE OF AN ELECTRON (with unhappy ending) |
One night when his charge was at full capacity, Micro Farad decided to
get a cute little coil to discharge him. He picked up Millie Amp and
took her for a ride on his megacycle. They rode across the wheat stone
bridge, around the sine wave, and into the magnetic field next to the
flowing current.
Micro Farad, attracted by Millie's characteristic curve, soon had her
field fully excited. He laid her on the ground potential, raised her
frequency, lowered her resistance, and pulled out his high voltage
probe. He inserted it in parallel and began to short circuit her shunt.
Fully excited, Millie cried out, "ohm, ohm, give me mho". With his tube
at maximum output and her coil vibrating from the current flow, her
shunt soon reached maximum heat. The excessive current had shorted her
shunt, and Micro's capacity was rapidly discharged, and every electron
was drained off. They fluxed all night, tried various connections and
hookings until his bar magnet had lost all of its strength, and he could
no longer generate enough voltage to sustain his collapsing field. With
his battery fully discharged, Micro was unable to excite his tickler, so
they ended up reversing polarity and blowing each other's fuses. _________________ Moments before detonation ,....... TT |
