ASM
ro-bi
Prispevkov: 3580
Aktiv.: 15.99
PrispevekObjavljeno: Sre Dec 09, 2009 7:45 am    Naslov sporočila:  ASM Odgovori s citatom
V .asm bi rad spremenil nekaj vrednosti. Za izračun imam XLS z vsemi formulami.
Zanima me, koliko "cifer" lahko vpišem v eno vrstico? Na danem primeru ne najdem logike, kjer se vrstica zamenja.
Prilagam kopijo tega dela kode:
LUT1:
DB 139,138,138,137,137,136,136,135,134,134,133,133,132,131,131,130,130,129,129,128
DB 127,127,126,126,125,125,124,123,123,122,122,121,121,120,119,119,118,118,117,116
DB 116,115,115,114,114,113,112,112,111,111,110,110,109,108,108,107,107,106,105,105
DB 104,104,103,103,102,101,101,100,100,99,99,98,97,97,96,96,95,95,94,93
DB 93,92,92,91,90,90,89,89,88,88,87,86,86,85,85,84,84,83,82,82
DB 81,81,80,79,79,78,78,77,77,76,75,75,74,74,73,73,72,71,71,70
DB 70,69,69,68,67,67,66,66,65,64,64,63,63,62,62,61,60,60,59,59
DB 58,58,57,56,56,55,55,54,53,53,52,52,51,51,50,49,49,48,48,47
DB 47,46,45,45,44,44,43,43,42,41,41,40,40,39,38,38,37,37,36,36
DB 35,34,34,33,33,32,32,31,30,30,29,29,28,27,27,26,26,25,25,24
DB 23,23,22,22,21,21,20,19,19,18,18,17,17,16,15,15,14,14,13,12
DB 12,11,11,10,10,9,8,8,7,7,6,6,5,4,4,3,3,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2
3 x 3 = 9
Aktiv.: 61.93
PrispevekObjavljeno: Sre Dec 09, 2009 11:35 am    Naslov sporočila:   Odgovori s citatom
Vprašanja sicer ne razumem najbolj. Tole je tabela. Načeloma se lahko razsteza čez cel pomnilnik. Procedura za branje mora seveda biti izvedena tako, da zazna kdaj se stran "prelomi" torej ko ZL prekorači. Prevajalnik pa bo razumel znak "\" razumel, da se koda nadaljuje v naslednji vrstici.
Recimo:
Koda:
LUT1:
DB 139,138,138,137,137,136,136,135,134,134,133,133,132,131,131,130,130,129,129,128,\
127,127,126,126,125,125,124,123,123,122,122,121,121,120,119,119,118,118,117,116,\
ro-bi
Prispevkov: 3580
Aktiv.: 15.99
PrispevekObjavljeno: Sre Dec 09, 2009 5:08 pm    Naslov sporočila:   Odgovori s citatom
Tisto sem skopiral iz delujočega programa. Ni mi problem na vsak skrajni levi začetek napisat tisti DB. Le tega ne vem, koliko cifer lahko zapišem v eno vrstico, preden spet začnem na levi z DB
3 x 3 = 9
Aktiv.: 61.93
PrispevekObjavljeno: Sre Dec 09, 2009 11:52 pm    Naslov sporočila:   Odgovori s citatom
ro-bi je napisal/a:
Robi,
Kot sem zgoraj napisal - tabela se lahko načeloma razteza čez cel pomnilnik mikrokontrolerja. Kake pa so omejitve pa zavisi od procedure, ki bere tabelo.
Glej recimo primer ene moje tabele - tista "pupa" katero sem risal na grafični displej.
Tabela izgleda takole:
Zadevo sem si zamislil takole:
Tabelo začnem brati na začetku. Na displej pošljem vse na kar "naletim" - razen "0". Ko naletim na "0" Preberem naslednjo vrednost - ta pove koliko "0" naj pošljem. Tablela je zaključena z dvema "0" po tem vem, da je tabele konec.
Koda:
Pupa:
.db 0,24,128,255,3,0,17,240,255,31,0,17,248,255,255,0,17,255,255,255,3,0,15,192,255,255,255,7,0,15,224,253,255,255,15,\
0,15,48,222,255,255,63,0,15,16,199,115,255,127,0,15,28,227,49,223,255,0,15,198,208,17,217,255,0,15,99,252,11,217,239,\
1,0,14,1,244,1,25,235,3,0,13,128,49,211,129,97,99,2,0,13,192,184,72,193,97,194,6,0,13,96,238,76,195,113,\
0,1,4,0,13,96,98,70,227,121,0,1,4,0,13,112,34,66,178,255,0,1,6,0,13,112,34,66,158,223,16,6,0,13,248,3,0,1,158,\
89,24,2,0,13,248,227,3,206,77,8,2,0,13,252,177,7,4,228,12,3,0,13,254,217,7,132,224,156,3,0,13,254,201,\
3,192,227,159,1,0,13,254,177,3,224,242,223,1,0,13,255,193,0,1,240,244,255,1,0,13,247,1,0,1,240,247,253,1,0,13,245,\
3,40,224,251,125,1,0,12,128,245,7,0,1,192,253,126,1,0,12,128,240,6,0,2,126,191,0,13,128,240,14,66,0,1,62,159,\
0,13,128,224,30,60,0,1,159,207,0,13,128,192,122,0,1,128,207,71,0,14,192,250,1,128,239,97,0,14,128,180,14,252,231,32,\
0,14,128,180,224,161,227,16,0,15,32,2,144,97,12,0,14,192,247,1,240,52,7,0,14,16,0,2,192,160,0,15,8,124,0,1,64,\
32,0,15,196,35,0,3,1,0,14,82,28,0,3,1,0,14,6,124,0,3,1,0,13,128,0,1,128,1,0,2,1,0,13,96,0,1,120,7,0,2,1,\
0,13,32,0,1,150,29,4,0,1,1,0,13,32,190,85,3,4,0,1,1,0,13,16,65,152,0,1,4,0,1,1,0,13,80,16,224,0,2,128,\
0,14,48,6,0,2,2,64,0,14,144,1,0,2,2,32,0,14,64,0,3,1,16,0,14,48,0,3,1,8,0,14,12,0,1,2,128,0,1,8,0,16,2,\
64,0,1,4,0,14,1,0,1,1,64,0,1,2,0,13,192,0,1,128,0,1,32,0,1,1,0,13,192,0,1,64,0,1,32,0,1,1,0,13,240,0,1,32,\
0,1,16,128,0,14,240,0,1,16,60,8,64,0,14,192,0,1,16,90,8,64,0,14,128,0,1,16,74,4,32,0,14,128,0,1,16,38,2,\
16,0,15,3,32,24,2,8,0,15,4,32,0,1,2,40,0,15,40,60,0,1,3,20,0,15,128,67,0,1,1,2,0,15,64,128,131,0,1,10,\
0,15,64,0,1,252,0,1,10,0,15,32,0,1,64,0,1,10,0,15,32,0,1,64,0,1,5,0,15,32,0,1,32,128,5,0,15,32,0,1,32,64,1,\
0,15,32,0,1,32,64,5,0,15,64,0,1,16,32,5,0,15,64,0,1,16,144,4,0,15,128,0,1,16,144,8,0,17,8,72,8,0,15,128,\
0,1,8,64,48,0,15,128,0,2,64,64,0,0
