m.matic Član
Pridružen-a: Sre 22 Sep 2004 22:43 Prispevkov: 189 Aktiv.: 0.80
Objavljeno: Čet Mar 10, 2005 8:37 pm Naslov sporočila: slovenska imena za... |
slovenska imena?
glitch trigger
runt trigger
width trigger |
bungee Član
Pridružen-a: Pon 07 Mar 2005 18:49 Prispevkov: 1479 Aktiv.: 6.23 Kraj: Ljubljana
Objavljeno: Čet Mar 10, 2005 8:47 pm Naslov sporočila: |
trigger je v vsakem primeru prožilec oziroma sprožilec.
glitch .... ??
runt .... ?? <--- tole pa še nisem srečal
width .... širinski prožilec
Velja pa prevajati v kontekstu in ne samo po dve besedi. |
m.matic Član
Objavljeno: Čet Mar 10, 2005 9:21 pm Naslov sporočila: |
t A glitch trigger occurs when the trigger source detects a pulse narrower
(or wider) in width than some specified time. lt can trigger on glitches of
either polarity. Or you can set the glitch trigger to reject glitches of either
polarity.
t Arunt trigger occurs when the trigger source detects a short pulse that
crosses one threshold but fails to cross a second threshold before
recrossing the first. You can set the oscilloscope to detect positive or
negative runt pulses.
t Awidth trigger occurs when the trigger source detects a pulse that is
inside or, optionally, outside some specified time range (defined by the
upper limit and lower limit). The oscilloscope can trigger on positive or
negative width pulse |
Pridružen-a: Pon 23 Avg 2004 16:16 Prispevkov: 16777190 Aktiv.: 70623.54
Objavljeno: Pet Mar 11, 2005 8:39 am Naslov sporočila: |
