DVD/RW NE ZAPISUJE
fizikaby
Pridružen-a: Pon 25 Jan 2010 12:50
Prispevkov: 1
Aktiv.: 0.01
Kraj: MB
PrispevekObjavljeno: Tor Jan 26, 2010 9:05 am    Naslov sporočila: icon_angry DVD/RW NE ZAPISUJE Odgovori s citatom
V računalniku imam dve DVD/RW enoti. Do sedaj nisem imel problema z njima. Naenkrat pa več ne pečeta. Zaznata CD ali DVD plošček,
pisanje poteka, zapiše pa nič. Na koncu se pojavi obvestilo:
"POWER CALIBRATION ERROR" ali pa "POWER CALIBRATION AREA IS FULL".
To se dogaja pri obeh enotah. Zato verjetno obe naenkrat nista pokvarjeni in gre za neko drugo napako.
Ima kdo nasvet?
 Velikost datoteke:  27.57 KB
Hvala in LP
z0r1n
Pridružen-a: Pon 02 Nov 2009 10:13
Prispevkov: 63
Aktiv.: 0.33
Kraj: Prevalje
PrispevekObjavljeno: Tor Jan 26, 2010 12:32 pm    Naslov sporočila:   Odgovori s citatom
Pozdravljen,
Takšnega problema še jaz nisem imel, lahko si pa to stran ogledaš, mogoče ti bo koristilo "Power Calibration Error"
Edit:
No na tej strani ti pa piše kaj pomeni Calibration Area Full Error .
Povzetek:
I get a 'Power calibration error' or 'Calibration area (almost) full' error message. Why?
Power Calibration is controlled by the recorder.
Before any write operation, all recorders must do a 15 step power test to determine the optimum power for writing to the CD; this is called "Optimum Power Calibration"(OPC). During the write, it continues to do this test to get the best write throughout the whole CD; this is called "Running Optimum Power Calibration" (ROPC).
This whole process is controlled by the recorder, though initiated by programs such as Nero. There is an area on the inner part of the CD for the test and test data info to be stored. You can use this area up to 999 times.
If you receive the "Power calibration error" or "Power calibration area is (amost) full" error message, the cause will be either poor media, poor power, or a defective recorder.
Please try the following solutions:
* Update the firmware of your recorder. Please check the manufacturer's website for the latest version.
* Try another brand of CD-R or CD-RW media.
* Try different power connectors, and for recorders, do not share power with other devices. It needs its own power connector. If the error occurs with an external recorder, the power source in the chassis could be the cause. As a test, try to take the recorder out of the external chassis and connect it internal.
* Try different configurations, such as taking the CD-ROM to the primary IDE bus as slave and have only the recorder connected to the secondary IDE bus as master.
* Send the recorder in for service.
LP!
Zoran
James Dean: “Dream as if you'll live forever, live as if you'll die today.”
Modlar
Pridružen-a: Pon 16 Feb 2009 10:59
Prispevkov: 190
Aktiv.: 0.95
Kraj: Koroška
PrispevekObjavljeno: Tor Jan 26, 2010 2:23 pm    Naslov sporočila:   Odgovori s citatom
Zamenjaj Nero
https://slo-tech.com/forum/t267316
LP Mare
Kdor visoko leta - daleč vidi.
Pioneer 3112
Pridružen-a: Ned 24 Jan 2010 17:02
Prispevkov: 21
Aktiv.: 0.11
PrispevekObjavljeno: Tor Jan 26, 2010 4:34 pm    Naslov sporočila:   Odgovori s citatom
Priporočam tudi tale program je zelo enostaven , in vsaj meni deluje tudi ko nero odpove.
http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
qwertz
Prispevkov: 2743
Aktiv.: 13.21
Kraj: Vrhnika
PrispevekObjavljeno: Tor Jan 26, 2010 5:50 pm    Naslov sporočila:   Odgovori s citatom
Jaz uporabljam Infrarecorder, nero me ni prepričal. Kolega je imel podobne probleme, zamenjal sem mu pekač in sedaj je v redu.
jakar
Pridružen-a: Sob 22 Maj 2004 21:34
Prispevkov: 190
Aktiv.: 0.80
Kraj: Primorska
PrispevekObjavljeno: Tor Jan 26, 2010 8:00 pm    Naslov sporočila:   Odgovori s citatom
Poskušaj zamenjati DVD+R za DVD-R ali obratno, pri meni je to pomagalo za isti error.
Prispevkov: 5820
Aktiv.: 24.55
PrispevekObjavljeno: Tor Jan 26, 2010 8:18 pm    Naslov sporočila:   Odgovori s citatom
Z Nerotom do sedaj še nisem imel problemov, pa ga uporabljam od samega začetka.
Probleme lahko povzročajo razno razni programski dodatki (decripterji, virtual CD ipd).
Raje preveri, kaj si v zadnjem času na čarunalniku inštaliral.
Prispevkov: 5820
Aktiv.: 24.55
PrispevekObjavljeno: Tor Jan 26, 2010 8:20 pm    Naslov sporočila:   Odgovori s citatom
Pioneer 3112 je napisal/a:
In kdaj je to?
folc
Pridružen-a: Pon 16 Nov 2009 21:25
Prispevkov: 678
Aktiv.: 3.57
Kraj: Nekje med NG in Tolminom
PrispevekObjavljeno: Pon Sep 27, 2010 7:08 pm    Naslov sporočila:   Odgovori s citatom
meni pa noče zapisati slike (iso)
pa a pečem z nerotm, powerisotm, alcoholom .....
vedno je zapis uspešno zaključen, a ko dam dvd ponovno v računalnik je dvd prazen ... tudi če ga fizično pogledam je nedotaknjen uspelo mi je celo 7 krat zapeči isto sliko na en sam dvd in še vedno pravi da je dvd prazen ... dvd enota pa ni morala iti kajti ostale stvari peče brez problemov
se komu izmed vas sanja kaj bi bilo narobe?
windowsi dvomim da so krivi kajti sem jih formatiral cirka 2 uri nazaj
elektrika je edina baba, k se ne pusti šlatat Very Happy
Folc
jvolk
Pridružen-a: Ned 05 Mar 2006 1:14
Prispevkov: 737
Aktiv.: 3.14
Kraj: okolica Divače
PrispevekObjavljeno: Pon Sep 27, 2010 7:47 pm    Naslov sporočila:   Odgovori s citatom
Kaj če poskusiš z CDjem?
folc
Prispevkov: 678
Aktiv.: 3.57
PrispevekObjavljeno: Pon Sep 27, 2010 7:56 pm    Naslov sporočila:   Odgovori s citatom
nažalost nimam nobenega cd-ja pri roki Sad
bom povprašal cimre .. podomen problem sem imel kake 4 mesece nazaj a se je sam od sebe rešil tako da sem dal samo drugi dvd not ...
sedaj sumim da so dvd-ji pokvarjeni podomače, kajti nanje se nič ne zapeče tudi na 4 različnih prenosnikih :S (17 dvd-jev že šlo po gobe)
Folc
audiox
Pridružen-a: Sob 19 Dec 2009 19:13
Prispevkov: 906
Aktiv.: 4.80
Kraj: Metlika
PrispevekObjavljeno: Pon Sep 27, 2010 8:41 pm    Naslov sporočila:   Odgovori s citatom
Ta napaka pride ko imaš umazano lečo od laserja. Razdri, lečo očisti z alkoholom...
folc
Prispevkov: 678
Aktiv.: 3.57
PrispevekObjavljeno: Pon Sep 27, 2010 9:41 pm    Naslov sporočila:   Odgovori s citatom
ja dobil sem CD in zapekel v prvem poskusu ... očitno so reds DVD-ji za odpis (cirka 120 komadu Sad )
Folc
Aktiv.: 60.02
PrispevekObjavljeno: Pon Sep 27, 2010 10:48 pm    Naslov sporočila:   Odgovori s citatom
Ni nujno. Za zapisovanje na DVD se uporablja drugo lasersko diodo kot na CD.
Azrael
Prispevkov: 4432
Aktiv.: 22.21
Kraj: Gorje
PrispevekObjavljeno: Tor Sep 28, 2010 11:14 am    Naslov sporočila:   Odgovori s citatom
Res je, ampak pravi, da ima enak problem na različnih pekačih v različnih računalnikih, tako da so najbrž problem mediji.
Mogoče veš koliko si ti mediji stari in ali so v "tortici" ali v škatlicah?
Namreč neuporabljeni CD in DVD mediji se zelo hitro starajo, sploh tisti v torticah, saj niso dovolj zaščiteni pred sončno svetlobo.
Neuporabljen CD medij je fuč nekako v 5. do 10 letih, če je shranjen na temnem, ne prevlažne in ne prevročem mestu. Če so pogoji hrambe slabši, je ta čas krajši, lahko tudi manj kot 3 leta. DVD mediji pa so glede staranja še bolj občutljivi.
Ko je medij zapečen, postane nekoliko bolj odporen na te vplive, Zato slučaj, ko medij zapečen pred leti še vedno dela, pravkar zapečen medij iz iste škatle, pa je fuč, ni nič izjemnega.
Uptime: 498 dni
