Tokovna obremenitev DIP stikala
Igor01
Prispevkov: 598
Aktiv.: 2.52
Kraj: KK
PrispevekObjavljeno: Ned Nov 21, 2010 10:47 pm    Naslov sporočila:  Tokovna obremenitev DIP stikala Odgovori s citatom
Živjo
Vprašanje:
Ali bi ta zadeva vzdržala 120mA/20V DC trajne obremenitve po pinu (brez preklopov) ?
http://si.farnell.com/jsp/search/productdetail.jsp?sku=9479066
GRAYHILL - 78B06T - SWITCH, DIL, SLIDE, 6WAY
Switch Type:DIL
Contact Configuration:SPST-CO
Actuator Type:
Pitch Spacing:2.54mm
Contact Current DC Max:4A
SVHC:No SVHC (18-Jun-2010)
Contact Plating:Gold plated brass
Contact Resistance:30mohm
Current Rating:4A
Dielectric Strength VDC:500V
External Depth:9.65mm
External Length / Height:7.49mm
Insulation Resistance:5000Mohm
Lead Length:2.54mm
Lead Spacing:2.54mm
Length:17.3mm
Material:Thermoplastic UL94V0
Mounting Type:Through Hole
No. of Mechanical Operations:20000
No. of Positions:6
No. of Ways:6
Operating Temperature Max:85°C
Pin Configuration:DIL
Row Pitch:7.62mm
Series:78
Switch Operation:SPST
Temperature Operating Min:-40°C
Terminal Type:THT
Sem sicer preverjal po spletu, našel sem tri strani s specifikacijami kot pri Farnellu, na eni pa je bila vrednost 25mA.
Mnenja dobrodošla ...
Dip 6 4A 9479066.pdf
 Ime datoteke:  Dip 6 4A 9479066.pdf
 Velikost datoteke:  29.65 KB
 Downloadano:  8 krat
