PIC UART TEST - port iz 628 na 627 - pomoč?
TRIROG
Pridružen-a: Čet 30 Avg 2007 12:23
Prispevkov: 84
Aktiv.: 0.39
PrispevekObjavljeno: Čet Dec 09, 2010 9:34 am    Naslov sporočila:  PIC UART TEST - port iz 628 na 627 - pomoč? Odgovori s citatom
Dobro jutro!
Včeraj sem se malo igral s spodnjim programčkom, ki naj bi ob zagonu izpisal 16627 Alive potem pa vračal vse vnešene znake ( pic je preko MAX 232 priklopljen na PC)
Težava je v tem, da je program v originalu pisan za 628ko.
Ob priklopu se mi sicer v terminalu izpišejo neki znakci, vendar niti približno ne gre za napis ki bi naj bil poslan?
Lahko kdo prosim preveri ali je koda sploh ustrezna?
Hvala!
Koda:
; Function:  Sends alive message, then echoes characters at 9600 bps
; Processor: PIC16F628 at 4 MHz using internal RC oscillator
; Hardware:  Testboard K4
; Filename:  628uart.asm
; Author:    Lars Petersen, oz1bxm@pobox.com
; Website:   www.qsl.net/oz1bxm/PIC/pic.htm
; Credit:    Tony Nixon's test program at
;            www.piclist.com/techref/microchip/16f877/setup.htm
        LIST P=16F627, R=DEC    ; Use the PIC16F628 and decimal system
        #include "P16F627.INC"  ; Include header file
        __config  _INTRC_OSC_NOCLKOUT & _LVP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_ON
        CBLOCK 0x20             ; Declare variable addresses starting at 0x20
          dataL
        ENDC
        ORG    0x000            ; Program starts at 0x000
; SET ANALOG/DIGITAL INPUTS PORT A
        movlw 7
        movwf CMCON             ; CMCON=7 set comperators off
; INITIALIZE PORTS
        movlw b'00000000'       ; set up portA
        movwf PORTA
        movlw b'00000100'       ; RB2(TX)=1 others are 0
        movwf PORTB
        bsf STATUS,RP0          ; RAM PAGE 1
        movlw 0xFF
        movwf TRISA             ; portA all pins input
        movlw b'11110010'       ; RB7-RB4 and RB1(RX)=input, others output
        movwf TRISB
; SET BAUD RATE TO COMMUNICATE WITH PC
; Boot Baud Rate = 9600, No Parity, 1 Stop Bit
        movlw 0x19              ; 0x19=9600 bps (0x0C=19200 bps)
        movwf SPBRG
        movlw b'00100100'       ; brgh = high (2)
        movwf TXSTA             ; enable Async Transmission, set brgh
        bcf STATUS,RP0          ; RAM PAGE 0
        movlw b'10010000'       ; enable Async Reception
        movwf RCSTA
; PROVIDE A SETTLING TIME FOR START UP
        clrf dataL
settle  decfsz dataL,F
        goto settle
        movf RCREG,W
        movf RCREG,W
        movf RCREG,W            ; flush receive buffer
; MAIN LOOP
        call message            ; send "16F628 alive"
loop    call receive            ; wait for a char
        call send               ; send the char
        goto loop
; RECEIVE CHARACTER FROM RS232 AND STORE IN W
; This routine does not return until a character is received.
receive btfss PIR1,RCIF         ; (5) check for received data
        goto receive
        movf RCREG,W            ; save received data in W
        return
; SEND CHARACTER IN W VIA RS232 AND WAIT UNTIL FINISHED SENDING
send    movwf TXREG             ; send data in W
TransWt bsf STATUS,RP0          ; RAM PAGE 1
WtHere  btfss TXSTA,TRMT        ; (1) transmission is complete if hi
        goto WtHere
        return
; MESSAGE
message movlw  '1'
        call send
        movlw  '6'
        call send
        movlw  'F'
        call send
        movlw  '6'
        call send
        movlw  '2'
        call send
        movlw  '7'
        call send
        movlw  ' '
        call send
        movlw  'a'
        call send
        movlw  'l'
        call send
        movlw  'i'
        call send
        movlw  'v'
        call send
        movlw  'e'
        call send
        movlw  0x0D ; CR
        call send
        movlw  0x0A ; LF
        call send
        return
        END
bferlic
Pridružen-a: Tor 09 Dec 2003 17:28
Prispevkov: 99
Aktiv.: 0.42
Kraj: Brezula, Rače
PrispevekObjavljeno: Čet Dec 09, 2010 10:42 am    Naslov sporočila:   Odgovori s citatom
Nisem gledal vsega, ampak za delovanje USART-a morata biti postavljena TRISB<2:1> oba na 1, kljub temu, da je en pin izhod.
LP Boštjan
TRIROG
Prispevkov: 84
Aktiv.: 0.39
PrispevekObjavljeno: Pet Dec 10, 2010 10:19 am    Naslov sporočila:   Odgovori s citatom
Sem rešil... zadeva dela ... hvala!
TRIROG
Prispevkov: 84
Aktiv.: 0.39
PrispevekObjavljeno: Pet Dec 10, 2010 10:59 am    Naslov sporočila:   Odgovori s citatom
bferlic je napisal/a:
LP Boštjan
Lahko razložiš kaj pomeni TRISB<2:1>?
Hvala!
bferlic
Prispevkov: 99
Aktiv.: 0.42
Kraj: Brezula, Rače
PrispevekObjavljeno: Pet Dec 10, 2010 3:33 pm    Naslov sporočila:   Odgovori s citatom
Zdravo
Mišljeni so TRISB biti "od 2 do 1", v tem primeru sta samo 2 in 1, biti pa se označujejo 0-7. Very Happy
V zgornjem primeru si v TRISB shranil b'11110010', torej je TRISB<2> 0, kar pa glede na datasheet pomeni, da je USART izklopljen. Zdaj če si pa kaj drugega popravil, to pa ne, in ti vseeno dela, sem pa mogoče še kaj spregledal Cool
TRIROG
Prispevkov: 84
Aktiv.: 0.39
PrispevekObjavljeno: Sob Dec 11, 2010 12:01 am    Naslov sporočila:   Odgovori s citatom
Hoj, hvala oznaka mi ni bila poznana...rookie pač...
nekje sem prebral, da je v takšnem modeu ne glede na to ali ga določiš kot vhhodnega ali ne vhoden...
