obi Član
Pridružen-a: Tor 12 Apr 2011 7:28 Prispevkov: 90 Aktiv.: 0.52
Objavljeno: Čet Apr 14, 2011 4:44 pm Naslov sporočila: Dolžina kablov |
Lep pozdrav
Da preidem k bistvu, zaima me koliko so maksinalne dolžine kablov (računalnik - kabel - preiferna naprava), da naprava na drugi strani še normalno deluje.
-USB - 5m baje da deluje tudi na 7m ampak se da zadeva rešiti z USB repetitorjem(tega vem ostali so mi neznanka)
-LPT
-RS232
-VGA
-PS2 - stara priklopa za tipkovnico oz. miško (ne Playstation 2)
Hvala za odgovore. |
mucek Član
Pridružen-a: Tor 01 Avg 2006 10:47 Prispevkov: 5528 Aktiv.: 24.06 Kraj: Domzale
Objavljeno: Čet Apr 14, 2011 4:47 pm Naslov sporočila: |
Točnih podatkov ne morem reči, na podlagi izkušenj pa lahko rečem za naslednje:
VGA: 20 m
RS232: 50 m (preko UTP kabla, uporabil sem 2 parici: TX+GND in RX+GND)
LP, Grega _________________ ...lahko pa se tudi motim ... |
Pyr0Beast Član
Pridružen-a: Pon 16 Jun 2008 14:11 Prispevkov: 4969 Aktiv.: 24.01
USB 1.1 gre BP do 20m |
obi Član
Objavljeno: Čet Apr 14, 2011 4:54 pm Naslov sporočila: |
Ok za usb 1.1 še nisem testiral vendar sem po netu bral da je citiram iz wikipedie
Conductor Configuration
The data cables for USB 1.x and USB 2.x use a twisted pair to reduce noise and crosstalk. They are arranged much as in the diagram below. USB 3.0 cables are more complex and employ shielding for some of the added data lines (2 pairs); a shield is added around the pair sketched.
Maximum Cable Length
The maximum length of a standard USB cable (for USB 2.0 or earlier) is 5 metres (16.4 ft).[34] The primary reason for this limit is the maximum allowed round-trip delay of about 1,500 ns. If USB host commands are unanswered by the USB device within the allowed time, the host considers the command lost. When adding USB device response time, delays from the maximum number of hubs added to the delays from connecting cables, the maximum acceptable delay per cable amounts to 26 ns.[34] The USB 2.0 specification requires cable delay to be less than 5.2 ns per meter (192,000 km/s, which is close to the maximum achievable transmission speed for standard copper cable).[35] This allows for a five meter cable. The USB 3.0 standard does not directly specify a maximum cable length, requiring only that all cables meet an electrical specification. For copper wire cabling, some calculations have suggested a maximum length of perhaps 3 m.
Še kdo ve za ostale kable |
zrij Član
Pridružen-a: Sre 21 Jan 2004 14:40 Prispevkov: 157 Aktiv.: 0.66 Kraj: Ajdovščina
RS232 sem spravil že preko 150 metrov na telefonskem kablu.
Uporabil sem samo RX, TX in GND. Hitrost 9600.
lp |
Spajky Član
Pridružen-a: Ned 27 Jun 2010 0:05 Prispevkov: 1095 Aktiv.: 6.01 Kraj: Obala
Objavljeno: Čet Apr 14, 2011 5:20 pm Naslov sporočila: |
Pyr0Beast je napisal/a: |
Če nimaš na koncu požeruha toka ala wifi ključek, da ne pade napajanje (če je preko Usb) pod 4,5V, ker potem ne dela ... |
Bizgec65 Član
Pridružen-a: Sre 10 Mar 2010 11:46 Prispevkov: 2099 Aktiv.: 11.29 Kraj: Trebnje
Objavljeno: Čet Apr 14, 2011 5:52 pm Naslov sporočila: |
Meni webcam dela na 10m. |
BluPhenix Član
Pridružen-a: Pet 05 Mar 2004 12:54 Prispevkov: 1018 Aktiv.: 4.30 Kraj: Sežana
Objavljeno: Čet Apr 14, 2011 6:05 pm Naslov sporočila: |
VGA gre tudi na 50 in mogoče čez. Odvisno os uporabljenega kabla in izvora (računalnika), je pa res, da se slika degradira (izgublja ostrino) in tudi do kakšnih čudnih senc lahko prihaja. _________________
Pravilo št. 1: Pišite slovensko, velja za vse.
TA SUHI ŠKAFEC PUŠČA. Saj ni tako težko, no! |
matejl Član
Pridružen-a: Tor 03 Nov 2009 22:12 Prispevkov: 121 Aktiv.: 0.64 Kraj: Škofja Loka
Objavljeno: Čet Apr 14, 2011 7:28 pm Naslov sporočila: |
WLAN ključek na dolžini cca 15m brez problema |
obi Član
Objavljeno: Pet Apr 15, 2011 3:04 pm Naslov sporočila: |
torej nam še ostane PS/2 in pa LPT (zakaterega sem slišal da gre do max dolžine 8m) mi lahko kdo kaj uporabnega pove na to. |
S56RGA Član
Pridružen-a: Čet 11 Sep 2008 13:33 Prispevkov: 325 Aktiv.: 1.59 Kraj: Koper
Objavljeno: Pet Apr 15, 2011 3:18 pm Naslov sporočila: |
LPT- tudi 12m je še delalo. _________________ Agar |
obi Član
Objavljeno: Sob Apr 16, 2011 9:50 pm Naslov sporočila: |
Ok hvala, izgleda da bom mogu pa za PS/2 pa probat
hvala za odg. |
bostjang Član
Pridružen-a: Tor 03 Jan 2006 15:29 Prispevkov: 3468 Aktiv.: 14.65 Kraj: Postojna
Objavljeno: Pon Apr 18, 2011 8:52 am Naslov sporočila: |
Za PS/2, VGA in USB obstajajo adapterji (KVM extender), ki zadevo prenašajo preko UTP (PS/2 in VGA preko enega UTP) na večje razdalje. |
Pyr0Beast Član
Objavljeno: Pon Apr 18, 2011 3:00 pm Naslov sporočila: |
Spajky je napisal/a: |
wifi ključek dela vseeno. Je še nekaj več ko 20m, 21 ali nekaj takega.
Seseda se napetost le do 4.7V
Dodaš še kakšen 10.000uF kondlc na koncu, ker Wifi ključeraj vleče le v pulzih pa je stvar rešena |
