mzmarez Član
Pridružen-a: Tor 22 Jan 2008 19:03 Prispevkov: 184 Aktiv.: 0.87 Kraj: Ljubljana
Objavljeno: Pon Okt 26, 2009 9:18 am Naslov sporočila: PIC & Atmel usb programator |
Na spletu sem zasledil usb programator, ki podpira precej Picev in tudi nekaj Atmelov (italjanski avtor). Zdi se mi sorazmerno enostaven. Prednost se mi zdi , da podpira USB . Dela v Linuxu in Windosih.
10F200, 10F202, 10F204, 10F206, 10F220, 10F222,
12F508, 12F509, 12F510, 12F519, 12F609, 12F615, 12F629, 12F635, 12F675, 12F683,
16F505, 16F506, 16F526, 16F54, 16F610, 16F616, 16F627, 16F627A, 16F628, 16F628A, 16F630, 16F631, 16F636, 16F639, 16F648A, 16F676, 16F677, 16F684, 16F685, 16F687, 16F688, 16F689, 16F690, 16F716, 16F73, 16F737, 16F74, 16F747, 16F76, 16F767, 16F77, 16F777, 16F785, 16F818, 16F819, 16F83, 16F83A, 16C83, 16C83A, 16F84, 16C84, 16F84A, 16C84A, 16F87, 16F870, 16F871, 16F872, 16F873, 16F873A, 16F874, 16F874A, 16F876, 16F876A, 16F877, 16F877A, 16F88, 16F882, 16F883, 16F884, 16F886, 16F887, 16F913, 16F914, 16F916, 16F917, 16F946,
18F242, 18F248, 18F252, 18F258, 18F442, 18F448, 18F452, 18F458, 18F1220, 18F1230, 18F1320, 18F1330, 18F2220, 18F2221, 18F2320, 18F2321, 18F2331, 18F2410, 18F2420, 18F2423, 18F2431, 18F2439, 18F2450, 18F2455, 18F2458, 18F2480, 18F2510, 18F2515, 18F2520, 18F2523, 18F2525, 18F2539, 18F2550, 18F2553, 18F2580, 18F2585, 18F2610, 18F2620, 18F2680, 18F2682, 18F2685, 18F4220, 18F4221, 18F4320, 18F4321, 18F4331, 18F4410, 18F4420, 18F4423, 18F4431, 18F4439, 18F4450, 18F4455, 18F4458, 18F4480, 18F4510, 18F4515, 18F4520, 18F4523, 18F4525, 18F4539, 18F4550, 18F4553, 18F4580, 18F4585, 18F4610, 18F4620, 18F4680, 18F4682, 18F4685,
2400, 2401, 2402, 2404, 2408, 2416, 2432, 2464, 24128, 24256, 24512, 241025,
93C46C, 93C56C, 93C66C, 93S46, 93S56, 93S66
AT90S1200, AT90S8515, AT90S8535, ATmega8, ATmega8A, ATmega8515, ATmega8535, ATmega16, ATmega16A, ATmega32, ATmega32A
devices supported for read only:
12C508, 12C508A, 12C509, 12C509A, 12C671, 12C672, 12CE673, 12CE674
http://openprog.altervista.org/
stromar Član
Pridružen-a: Pon 01 Dec 2008 18:52 Prispevkov: 31 Aktiv.: 0.15 Kraj: Šentjur
Objavljeno: Čet Nov 05, 2009 9:55 pm Naslov sporočila: |
Zanimiva izvedba programatorja. Je že kdo preiskusil, če deluje?
ljudsko Član
Pridružen-a: Pon 31 Mar 2008 8:19 Prispevkov: 1184 Aktiv.: 5.65 Kraj: Koroška-Mežica
Objavljeno: Sob Nov 07, 2009 2:19 pm Naslov sporočila: |
Tudi mene to zanima, ker si ga bom izdelal.
_________________ return;
brake; |
powr Član
Pridružen-a: Tor 18 Dec 2007 13:20 Prispevkov: 668 Aktiv.: 3.14 Kraj: Postojna
Objavljeno: Sob Nov 07, 2009 7:34 pm Naslov sporočila: |
Pa je to kompatibilno z mplabom in avrstudijem? Ker kolkor sem na hitro pogledal ni
ljudsko Član
Objavljeno: Ned Nov 08, 2009 3:12 pm Naslov sporočila: |
Sprogramiraš v Mplabu ali VisualStudio in narediš .hex datoteko, program v mikrokrmilnik preneseš s tem
brake; |
ljudsko Član
Objavljeno: Sre Nov 25, 2009 7:03 pm Naslov sporočila: |
Ko izdelujem kako vezje, vedno pošljem mami v službo predlogo, da mi natisne, ker doma nimam laserskega printerja, oz. nekaj zafrkava (izdelujem s postopkom "laminator"). Danes mi je prinesla natisnjeno predlogo za tale programator. Poslal pa sem ji pdf, ki je v paketu na spletni strani. No, zadeva je prevelika, ker sem poizkusil na papirju in se ne ujema s podnožji. Zato sem v Linuxih odprl originalno PCB datoteko in jo izvozil kot .ps datoteko. To sem prenesel v windows in sconvertal v pdf. Nato sem pobrisal ostalo šaro iz datoteke, da sem dobil samo to predlogo. Doma sem jo sprintal z brizgalnikom in sedaj je mera prava. Podnožje štima. Prilagam datoteko, če bo kdo izdeloval programator, da se ne bo mučil z velikostjo:
Ime datoteke: |
Oprog.pdf |
33.54 KB |
Downloadano: |
87 krat |
brake; |
Pridružen-a: Pon 24 Feb 2003 17:09 Prispevkov: 14673 Aktiv.: 61.95 Kraj: Koroška-okolica Dravograda
Objavljeno: Sre Nov 25, 2009 7:28 pm Naslov sporočila: |
Izvorna datoteka "OprogBasePCB_BN.pdf" je čisto vredo. Je pač potrebno ustrezno nastaviti Acrobat pred tiskanjem. V prilogi natisnjena tiskanina iz orginala.
Velikost pri taki nastavitvi ne bo pravilna |
173.38 KB |
102 krat |
Pravilna nastavitev za izpis |
174.25 KB |
63 krat |
419.28 KB |
44 krat |
_________________ lp
ljudsko Član
Objavljeno: Sre Nov 25, 2009 7:37 pm Naslov sporočila: |
Vztrajam, saj mama ni nikoli nič nastavljala, pa je vedno prinesla prave mere domov. No ne vem, lahko, da imaš prav, ampak kako zdaj to mami dopovedat, da bo nastavila kot je potrebno. Saj sploh ne vem, kateri program ima v službi za pdf datoteke in če bi jo vprašal, verjetno ne bi vedela. Obstaja kakšna možnost, da se v datoteki nastavijo mere in takšne ostanejo? Da se potem samo sprinta.
brake; |
Objavljeno: Sre Nov 25, 2009 7:45 pm Naslov sporočila: |
Jaka umetnost pogledat pred tiskanjem kako je nastavljeno?
ljudsko Član
Objavljeno: Sre Nov 25, 2009 7:47 pm Naslov sporočila: |
No ok, bom že, pustimo potem, se opravičujem..
PS.: Mama je pa le mama
brake; |
Objavljeno: Sre Nov 25, 2009 8:01 pm Naslov sporočila: |
ljudsko je napisal/a: |
PS.: Mama je pa le mama  |
Dejstvo je, da se to lahko zgodi vsakemu ne le "mami", zato je dobro pogledati nastavitve pred tiskanjem. Tudi sam sem že naredil neustrezno tiskanino, ravno zaradi tega sem napisal tole opozorilo.
ljudsko Član
Objavljeno: Sre Nov 25, 2009 8:26 pm Naslov sporočila: |
Ne, narobe sva se razumela. S stavkom "mama je pa le mama" sem mislil, da bo mamo težko naučiti nastaviti stvari ampak bom že...
brake; |
ljudsko Član
Objavljeno: Pet Nov 27, 2009 11:34 am Naslov sporočila: |
Silvo, ali si ti dodatno zrcalil vezje pred tiskanjem? Ker meni je narobe prišlo.
brake; |
ljudsko Član
Objavljeno: Ned Nov 29, 2009 2:37 pm Naslov sporočila: |
Se bi na forumu našel kdo, ki bi mi hotel sprogramirati tale PIC18F2550? Poslal bi ga po pošti (seveda, jaz plačam poštnino).
Drugače pa sem malo brskal po internetu in me zanima, če bi ga na tak način lahko sam sprogramiral. Ker pa piše, da čip potrebuje zunanje napajanje, bi tak napajalnik naredil iz 9V baterije in 78L05 regulatorjem. Bi šlo?
brake; |
ljudsko Član
Objavljeno: Ned Nov 29, 2009 7:24 pm Naslov sporočila: |
Res ni koga?
brake; |
