elsak Član
Pridružen-a: Čet 30 Sep 2010 22:55 Prispevkov: 571 Aktiv.: 3.18 Kraj: Koroška
Objavljeno: Tor Dec 04, 2012 4:56 pm Naslov sporočila: RF ALI FM MODULACIJA? |
KUPUJEM BREZŽIČNE SLUŠALKE ZA SINA IN NE VEM , KATERA MODULACIJA JE BOLJŠA IN BOLJ KVALITETEN SPREJEM.
PRI WIRELLES JE OVIRA STENA IN ZGUBI PRENOS, RF IN FM PA NE VEM. BI BILO BOLJE FM? ALI JE VSEENO KATERA MODULACIJA?
HVALA _________________ TUDI ZELO SLABOVIDNI SE UKVARJAMO Z ELEKTRONIKO. |
bojans Član
Pridružen-a: Sob 17 Nov 2007 0:52 Prispevkov: 1196 Aktiv.: 5.57 Kraj: Ljubljana
Objavljeno: Tor Dec 04, 2012 5:41 pm Naslov sporočila: |
WIRELES MI DELUJE PREKO DVEH STEN (NOSILNI STENI CCA 35 CM ŠIRINE) IN POTEM ŠE PREKO MONTA PLOŠČE (CCA 60 CM DEBELINE), BREZ PROBLEMA.
KRATICI RF = RADIJSKA FREKVENCA, FM PA FREKVENČNA MODULACIJA.
ŽE V OSNOVI JE RAZLIKA (DIGITALNO - ANALOGNO). NAJ GRE NEKDO VIDEČI S TEBOJ, KO BOŠ KUPOVAL, DA TI PREBERE TEHNIČNE PODATKE IN PREDVSEM DROBNI TISK.
UPORABNI SPREJEM SIGNALA JE POD 50% NAVEDENEGA. ZA SIGURNO VZEMI 30%.
JAZ BI VSEENO VZEL ANALOGNEGA. ČE MALO ZAŠUMI PRESTOPIŠ ZA POL KORAKA, ČE PA SE "DIGITALIJAM ZMEŠA" IMAŠ PA MALO ČUDO ZVOKOV, V NAJBOLŠEM PRIMERU TIŠINO.
VPRAŠEVAL SI TUDI ZA DALJINSKO KRMILJENO LUČ. KOT TI JE ŽE NEKAJ SOGOVORNIKOV PREDLAGALO TI TUDI JAZ. DALJINSKO VODENA VTIČNICA NEKJE BLIZU OKNA, SEVEDA ZNOTRAJ STANOVANJA, IN SVETILKO NA FASADI. ZA TVOJE POTREBE BI VERJETNO BIL KAR KAŠEN "FLOD REFLEKTOR 500W". JE VODOTESEN, OSVETLI PA Z VIŠINE 3 METROV KAR VELIKO POVRŠINO.
V SOBOTO GREM V BAUHAUS, PA LAHKO POGLEDAM ZA TE VTIČNICE IN REFLEKTOR KOLIKO € BI TO BILO. OSTALO PA NA ZS.
LP BOJAN.
PS. KUPIŠ LAHKO TUDI TAKŠEN REFLEKTOR Z VGRAJENIM PIR SENZORJEM, SAMO POTEM BO PRIŽIGAL VSAKOMUR, ŠE MAČKOM ,KAR PA TI VERJETNO NE BO VŠEČ. _________________ Razlike med mrličem in butlom ni. Nobeden od niju se ne zaveda. Trpi pa okolica. |
elsak Član
Objavljeno: Tor Dec 04, 2012 6:45 pm Naslov sporočila: |
PRVO GLEDE SLUŠALK:
KAR SE TIČE WIRELSA IMAM SAMO IZKUŠNJE, KAR SE TIČE TIPKOVNICE/MIŠKE IN MI NE VLEČE V DRUGO SOBO NA ISTI LINIJI, SAMO DA JE 30CM ZID VMES BREZ ŽELEZA. ZATO SEM MISLIL, DA JE TO SLABŠA MODULACIJA-POVEZAVA. SIN JE VIDEL NA EBAYU ENE IN TISTE HOČE MET. SEM MU PA REKEL, DA SE BOM PREJ POZANIMAL, KATERE SO BOLJŠE, DA NE BOM POL JAZ KRIV, KA SEM MU KUPU. TE SLUŠALKE IMAJO VGRAJEN MIC IN RADIJO FM-85-110MHZ. ZA NJEGA NI TK POMEMBNO KAKA KVALITETA JE, KER JIH BOLJ RABI ZA CHAT IN POSLUŠANJE GLASBE IZ AVDIO NAPRAV. JE PA RES, DA MOGOČE JE TU BOLJŠI ODDAJNIK, KOT PA ZA MIŠKO.
DOBER SI TI. A BI RAD, DA NAREDIM FUSBAL PLAC NA PARKIRIŠČU. IMAM TAK REFLEKTOR, KI SMO GA UPORABLAJL NA GRADBIŠČU. FORA JE, DA JAZ SEM 10M NAD TLEMI, LUČ BI PA BILA PRI VHODU V BLOK. MEN JE VSEEN AL JE ŽE VGRAJEN Z LUČJO ALI PA NAVADNA LUČ IN VTIČNICA VGRAJEN MODUL V VODOTESNO PROZORNO OHIŠJE. OČITNO JE LAŽJE DOBIT DALJINSKO VODENO VTIČNICO , KOT PA DA BI BILA TAKŠNA LUČ ZA 230V. GLEDE ONEGA TI PA NAPŠEM VEČ NA ZS. _________________ TUDI ZELO SLABOVIDNI SE UKVARJAMO Z ELEKTRONIKO. |
