elsak Član
Pridružen-a: Čet 30 Sep 2010 22:55 Prispevkov: 571 Aktiv.: 3.02 Kraj: Koroška
Objavljeno: Čet Dec 06, 2012 4:35 pm Naslov sporočila: CANON MG 5200 |
POZDRAV!
ČE IMA MOGOČE KDO TAKŠEN TISKALNIK ALI JE IMEL PODOBNE ZVOKE PRI TISKANJU KOT PRI MOJEM TISKALNIKU.
PO DOLGE ČASU SEM TISKAL NA DVD/CD IN SO BI LI ČUDNI ZVOKI. KO POTEGNE PODAJALNIK PLOŠČKA V TISKALNIK JE VSE TIHO, KO PA ZAČNE PRIPRAVO NA TISKANJE, SO ZVOKI , KOT DA BI GLAVA DRSALA PO SROVI GUMI. KO PRIDE NA DESNO STRAN TISKALNIKA, SE SLIŠI KOT ENO ZATIKANJE. PRI TISAKNJU NA PAPIR JE PA VSE NORMALNO IN TIHO.
OTIPATI SE NE DA NIČ, KER SE NE DA Z ROKO V NOTRANJOST, JE VSE ZAPRTO. OČISTIL SEM PODAJALNIK PLOŠČKA IN VSEENO ISTO. DRUGAČE PA NATISNE LEPO NA DVD.
BI BILO POTREBNO Z ČIM PODMAZATI ALI KAJ?
ČUDNO SE MI ZDI, KER PRI PAPIRJU JE VSE OK, TU PA TAKI ZVOKI. A SO TU PRI PODAJALNIKU PLOŠČKA DRUGAČNI VALJI, KI POTEGNEJO PODAJALNIK V NOTRANJSOT ALI NE?
HVALA ZA POMOČ. _________________ TUDI ZELO SLABOVIDNI SE UKVARJAMO Z ELEKTRONIKO. |
elsak Član
Objavljeno: Pet Dec 07, 2012 2:36 pm Naslov sporočila: |
MOGOČE KDO VE, KE BI SE LAHKO DOBILA PASTA ZA PODMAZOVANJE VALJEV V TISKALNIKU? _________________ TUDI ZELO SLABOVIDNI SE UKVARJAMO Z ELEKTRONIKO. |
Uptime: 233 dni
