elsak Član
Pridružen-a: Čet 30 Sep 2010 22:55 Prispevkov: 571 Aktiv.: 3.18 Kraj: Koroška
Objavljeno: Sre Dec 19, 2012 4:28 am Naslov sporočila: POPRAVILO FOTOAPARATA |
LP!
NE VEM, ČE SE TU GOR KDO Z TEM UKVARJA. IMAM DIGITALEN FOTOAPARAT SAMSUNG S1060 IN JE SKORAJ NOV NERABLJEN. DANES SEM VSTAVLJAL BATERIJEV FOTOAPARAT IN KARTICO IN MI JE SPOLZEL IZ ROK. PADEL MI JE NA TLA PRI ODPRTI ZASLONKI. PADEL JE IZ VIŠŠINE 30CM. DELUJE VSE, SAMO KO ČISTO NOT NE POTEGNE ZASLONKE IN SPREDAJ NE POKRIJE ZAŠČITA ZASLONKE.
BI MI KDO TO POGLEDAL IN POSTAVIL NA PRVOTNO STANJE?
APARAT NI VEČ V GARANCIJI, AMPAK JE BIL SKOZ V ŠKATLI, KER JAZ IMAM DRUG FOTOAPARAT, TEGA SEM PA IMEL NAMEN KOLEGU PRODAT, ZDA PA TO.
PA ČE BI BILO MOŽNO V NAJKRAJŠEM ROKU.
HVALA
_________________ TUDI ZELO SLABOVIDNI SE UKVARJAMO Z ELEKTRONIKO. |
andrejj Član
Objavljeno: Sre Dec 19, 2012 6:11 pm Naslov sporočila: |
TEŽKO BI BILO ZA POPRAVILO.JAZ SEM DOBIL OD ZNANCA FOTOAPARAT KI JE PADEL NA TLA.IN NI MOGEL ZAPRETI OBJEKTIV.IZ RADOVEDNOSTI SEM RAZDRL IN UGOTOVIL DA JE ZLOMILJEN DEL PLASTIKE.JE PA VSE DEL PLASTIKA(ZOBNIKI IN RAZNI DELI)ČE BI DAL V SERVIS SE NE SPLAČA.BI BIL PREDRAG.
mucek Član
Pridružen-a: Tor 01 Avg 2006 10:47 Prispevkov: 5538 Aktiv.: 24.02 Kraj: Domzale
Objavljeno: Sre Dec 19, 2012 6:57 pm Naslov sporočila: |
ZASLONKA??? ELSAK, VERJETNO MISLIŠ LAMELICI, KI SE ZAPRETA SPREDAJ ČEZ OBJEKTIV? POPRAVLJATI SE NE SPLAČA (VERJETNO KAK ODLOMLJEN ZOBEC), ČE DELA, GA PAČ UPORABLJAJ TAKŠNEGA KOT JE, BOŠ EDINO OBJEKTIV SEM IN TJA S KAKŠNO KRPICO ZA OČALA MALO OBRISAL.
ČE PA GRE V RESNICI ZA ZASLONKO, SE PA ZADEVE ZAKOMPLICIRAJO ...
LP, G
elsak Član
Objavljeno: Sre Dec 19, 2012 8:10 pm Naslov sporočila: |
IMAŠ PRAV JA. LAMELCI SE NE ZAPREJO, KER VČERAJ SEM GA ODPRU SPREDAJ NA OBJEKTIVU IN ODVIL VIJAKA IN VZEL DOL NOSILČEK, KJER SO TE DVE LAMELCI, PLASTIKA. UGOTOVIL SEM, DA SE ZAVRTI IN SE ZAPREJO. NAPREJ PA NISEM PRIŠEL. NIKJER NOBENEGA VIJAKA, TK DA NE VEM A JE TO ZA ENKRATNO UPORABO AL KK.
OBJEKTIV ZA 2-3 MM OSTANE VZUNAJ IN KO GA IZKLOPIŠ, SE SLIŠI KOT PRI CD POGONU, ČE NE MORE NOT POTEGNIT PLADNJA IN SE SLII KOT TK TK TK, POTEM PA SPUSTI OPOZORILNI ZVOK, KI JE ISTI KOT ČE SO BATERIJE PRAZNE.
ČE GA PRODAM, BO MOTEČ TA GLAS/OPOZORILO. KUPIL BI GA KOLEGA, KI TUD SLABO VID, SAMO DESETKRAT BOLJ KOT JAZ IN ŠE V ŽIVLJENJU NI IMEL APARATA V ROKAH. NISEM PA SVI... DA BI MU NEKAJ PRODAL, POTEM PA NE BI DELALO.
SEM PREGLEDAL V NASTAVITVAH IN NIMA V NEIJU, DA BI BILO NA VOLJO, ON/OFF BATERY VOLUME ALI OPOZORILNI ZVOK. ČE PA DAM NA TIHO, POTEM PA NE BO VEDEL, KO AF OSTRI.
SEM PAČ MISLIL, ČE JE KDO NA TEM FORUMU, DA JE KAK MAJSTER IN BI TO POGLEDAL, KER NI TAKA NAPAKA, KOT PA ELEKTRONIKA.
MI JE PA NKEKDO REKEL, DA MOGOČ JE KAKŠEN ZOBČEK ALI PRESKOK ZOBNIKA. NE VEM.
ro-bi Član
Objavljeno: Sre Dec 19, 2012 8:41 pm Naslov sporočila: |
V OBJEKTIVU JE SISTEM LEČ, KI SE PREMIKA NAPREJ NAZAJ ZNOTRAJ OBJEKTIVA. TA SISTEM JE NA TREH VODILIH, KI POTUJEJO V UTORIH, KI SO PO NOTRANJI STRANI ZUNANJEGA DELA OBJEKTIVA. IN KO SE ENO OD TEH TREH VODIL ZLOMI ALI SKOČI VEN, SE OBJEKTIV NE ZLOŽI VEČ DO KONCA, VČASIH JE TUDI SLIKA MEGLENA.
NA NOBENEM SERVISU TEGA NE POPRAVLJAJO, KER JE LOTERIJA. DELA JE OGROMNO, REZULTAT PA VPRAŠLJIV.
DA DO TEH DELOV PRIDEŠ, JE REBA APARAT ODPRETI ODZADAJ, POBRATI VEN ELEKTRONIKO, CCD IN OBJEKTIV VZETI VEN IN GA RAZDRETI. NOTRI SO VZMETI, DEBELE KOT LAS, PRI NEKATERIH IMAJO MOTORČKI ŽICE PO ZRAKU, KI SO TUDI KOT LAS,....
_________________ 3 x 3 = 9 |
elsak Član
Objavljeno: Sre Dec 19, 2012 10:14 pm Naslov sporočila: |
HVALA ZA LEPO RAZLAGO. NISEM NIKOLI ŠE RAZDIRAL, KR VEM DA SO TO MIKRONSKI DELI IN MORŠ IMET OSTRO OKO PA ŠE KAKO DOBRO LUPO, DA VSE SKUP SPRAVIŠ.
SLIK ŠE NISEM PREGLEDOVAL P O TEJ NEZGODI. DOBR DA SI POVEDAL BOM POIZKUSU.
JAZ IMAM SVOJEGA KOMPAKTNEGA Z FIKSNIM , OBJEKTIVOM IN SO LEČE VARNE. MOJ MI ŠE NI NIKOLI V DESETIH LETIH IZ ROK UŠEL, KER JE GUMA OKOLI IN IMA DOBER OPRIJEM. TO KAR JE PA TA SAMSUNG, JE PA BOLJ IGRAČKA.
. Neznanec
Objavljeno: Čet Dec 20, 2012 1:24 am Naslov sporočila: |
igo Član
Objavljeno: Čet Dec 20, 2012 1:48 am Naslov sporočila: |
ro-bi je napisal/a: |
V OBJEKTIVU JE SISTEM LEČ, KI SE PREMIKA NAPREJ NAZAJ ZNOTRAJ OBJEKTIVA. TA SISTEM JE NA TREH VODILIH, KI POTUJEJO V UTORIH, KI SO PO NOTRANJI STRANI ZUNANJEGA DELA OBJEKTIVA. IN KO SE ENO OD TEH TREH VODIL ZLOMI ALI SKOČI VEN, SE OBJEKTIV NE ZLOŽI VEČ DO KONCA, |
ČE SO TRIJE ČEPKI SAMO SKOČILI IZ UTOROV, BI BILO TREBA OBJEKTIV "ZOOMATI" POVSEM VEN, NATO PA GA DOBRO PRIJETI (ALI GA Z LEPILNIM TRAKOM NALEPITI NA KAKŠNO CEV) TER GA POČASI IN Z OBČUTKOM PULITI VEN. ČE SE JE KAK ČEPEK ZLOMIL, JE PA PROBLEM.
NAJPREJ BI MORAL VEDETI DOLŽINO OBJEKTIVA, KO JE MAKSIMALNO IZVLEČEN. JO LAHKO KDO IZMERI ZA TA TIP APARATA?
@elsak TI PA TO IZMERI PRI SVOJEM APARATU.
ČE JE TELESKOPSKI (VEČSTOPENJSKI, KOT CEV V CEVI), IZMERI DOLŽINO POSAMEZNIH STOPENJ.
KATERA STOPNJA OSTANE ZUNAJ 2-3mm? ČISTO NOTRANJA, ČISTO ZUNANJA, SREDNJA?
NA NOBENEM SERVISU TEGA NE POPRAVLJAJO, KER JE LOTERIJA. DELA JE OGROMNO, REZULTAT PA VPRAŠLJIV. |
JAZ NAJRAJE POPRAVLJAM POKVARJENE STVARI, KJER NI MOŽNO NIČESAR BOLJ UNIČITI, KOT JE ŽE. NAJHUJE JE, KO SAMO NEKAJ MALEGA NE DELA, POTEM PA ZADEVO PO NESREČI DOKONČNO UNIČIŠ.
LP, Igor |
elsak Član
Objavljeno: Čet Dec 20, 2012 3:53 am Naslov sporočila: |
IGO, TI PAS SI MODEL. MENI PODOBEN . JAZ ISTO PRAVIM, ČE JE ŽE POKVARJEN, BOLJ NE MORŠ UNIČT.
ZADEVA JE TAKA. MALO NAZAJ SEM PREVERIL KVALITETO SLIKE IN JE MOTNA. SE VID PREDMET AMPAK NE ČIST. TAKO DA JE KOT JE RO-BI REKEL DA JE LEČA. VČERAJ SEM SKORAJ FAKULTETO NAREDIL NA NJEMU. TUDI Z ROKO SEM PROBAVAL VSE SORTE, GA ZOOMIRAL VEN IN NOT IN GLEDAL. MALO JE MANKAL, PA BI GA DAL V PRIMEŠ IN STISNU. DELA NORMALNO IN ZOOMIRA NORMALNO.
SESTAVLJEN JE IZ DVEH DELOV OBJEKTIV. PRVI SE SUČE IN VLEČE DRUGEGA NOTRI IN VEN, NATO PA ŠE SEBE PRVEGA NOT POTGNE.
TULE SO MERE:
PRVI OBROČ -16.50MM
DRUGI JE ISTA MERA.
TO SO MERE KO STA OBA ČISTO VZUNAJ.
KO SE ČISTO ZAPRE UGASNE, PRVI VALJ JE 7.3MM VZUNAJ, DRUGI VALJ PA 4MM.
SKUPAJ GA VSTANE VZUNAJ PRI UGASNEJEM APARATU 12.3MM.
SEM ŠE ENKRAT Z KLJUNASTIM MERILNIKOM PREVERIL.
upor_nik Član
Pridružen-a: Ned 11 Jan 2009 13:00 Prispevkov: 450 Aktiv.: 2.24 Kraj: vipavska dolina
Objavljeno: Pet Dec 21, 2012 8:09 pm Naslov sporočila: |
POZDRAV, ..
NE VEM, ČE BO ŠLO, KAJTI MOJ FOTO, KI SEM GA NAMERNO ZABIL V OMARO PRI VKLOPLJENEMU OBJEKTIVU TUDI PO 4-IH POSKUSIH CENTRIRANJA, FOKUSIRANJA, ..IN NE VEM KAJ BI ŠE SPADALO SEM, .. MI NI USPELO, DA BI KAJ VIDEL, OZIROMA JE BIL REZULTAT - ZGUBA ČASA. DOBIL SEM NEJASNO SLIKO, BOLJ ZMAZEK BARV.
MODERATORJE NAPROŠAM, DA NAREDIJO NOVO RUBRIKO, OZIROMA TEMO, RECIMO, .. ELEKTRONIKA ZA SLABOVIDNE, KJER NAJ BI SE, ČE JE LE MOŽNO, VSE DOGAJANJE NA FORUMU, KI JE ZAPISANO Z MALIMI ČRKAMI SPREMENILO V VELIKE. NE IŠČEM IDEJ ZA PODVAJANJE FORUMA, AMPAK ENOSTAVNO REŠITEV, PREKLOP MED VELIKIMI IN MALIMI ČRKAMI.
LP 5ER
_________________ Sanja svinja o koruzi, ... |
PZUFIC Vseved
Objavljeno: Pet Dec 21, 2012 8:17 pm Naslov sporočila: |
TUDI MENI SE JE ZGODILO, DA SEM NAPISAL CEL PRISPEVEK Z UPORABO VELIKIH IN MALIH ČRK. V ISKANJU LAŽJE REŠITVE KOT PONOVNO PISANJE PA SEM NAŠEL TOLE, MOGOČE ŠE KOMU POMAGA.
Lp Primož |
dyfan Član
Pridružen-a: Sob 05 Maj 2007 9:54 Prispevkov: 652 Aktiv.: 2.95
Objavljeno: Pet Dec 21, 2012 8:54 pm Naslov sporočila: |
VELIKOST ČRK V NAPISANEM TEKSTU LAHKO SPREMINJAŠ TUDI V WORDU.
19.63 KB |
0 krat |
kastaneda Član
Pridružen-a: Pet 23 Okt 2009 11:18 Prispevkov: 459 Aktiv.: 2.40
Objavljeno: Sob Dec 22, 2012 10:21 am Naslov sporočila: |
ZA ELSAK-A IN OSTALE SLABOVIDNE, KI UPORABLJAJO FIREFOX:
NALOŽITE DODATEK GREASEMONKEY, KI GA DOBITE TUKAJ
NALOŽITE SKRIPTO UPPERCASE LETTERS, KI JO DOBITE TUKAJ
S TEM DODATKOM JE VES TEKST NA INTERNETNIH STRANEH PISAN Z VELIKIMI ČRKAMI. FUNKCIJO VKLJUČIMO ALI IZKLJUČIMO S KLIKOM NA IKONICO.
_________________ LP
Srečko |
elsak Član
Objavljeno: Sob Dec 22, 2012 2:52 pm Naslov sporočila: |
@UPORNIK. DOBRA IDEJA. SAMO SE MI ZDI, DA SEM JAZ EDINI MODEL, KI TAKO SLABO VIDI. KER DRUGI NIMAJO VOLE, DA BI SE TAKIMI REČMI UBADALI, KI VIDIJO TAKO MALO, DA ŠE LASTENGA PRSTA NE VIDIJO BREZ ELEKTRONSKE POVEČAVE.
NE VEM ČE BI MEN KAJ POMAGALA TA POVEČAVA ZA FIREFOX, KER IMAM ŽE ZDAJ VSE NA VELIKO.
A OBSTAJA MOGOČE MOŽNOST, DA JAZ OZNAČIM VES TEXT OD ČLANOV IN GA POVEČAM?
KAJTI JAZ IMAM ŽE SEDAJ TAKO VELIKO POVEČAVO, DA JE KURZOR OD MIŠKE VELIK KOT A4 LIST.
A GLEDE FOTOAPARATA PA NIHČE NE VE NIČ? ČE JE KAKŠNA VARIANTA.
kastaneda Član
Objavljeno: Sob Dec 22, 2012 3:11 pm Naslov sporočila: |
elsak je napisal/a: |
NE VEM ČE BI MEN KAJ POMAGALA TA POVEČAVA ZA FIREFOX, KER IMAM ŽE ZDAJ VSE NA VELIKO. |
DODATET, KI SEM GA OMENIL, SPREMENI MALE ČRKE V VELIKE.
Srečko |
