sisoski2 Član
Pridružen-a: Čet 13 Avg 2009 13:14 Prispevkov: 53 Aktiv.: 0.27 Kraj: Strumica
mobwap Član
Pridružen-a: Sre 14 Mar 2012 9:42 Prispevkov: 326 Aktiv.: 2.01 Kraj: Doma
Objavljeno: Pet Dec 21, 2012 2:25 pm Naslov sporočila: |
To zna google translate, koliko toliko ok. Za podrobnosti pa bi moral mojo drago povprašat ko že ravno rusko obvlada.
Koda: |
1.SISTEMNYE REQUIREMENTS.
2.Install PROGRAM.
3.Set DRIVER - only for WIN XP!!!.
4.NACHAT WORK.
5.MODUL tarantula - ADVANCED FOR
BURNING. (From 30.11.11)
6.MODUL woodpecker - ADVANCED FOR
Percussion instruments. (From 01/06/2012)
1. SYSTEM REQUIREMENTS
1G/512M/WinME or WinXp.
2.Zapustit SETUP.EXE
3.USTANOVKA DRIVER GIVEIO.sys only WIN
XP!!!
For the first time under XP, the driver will install automatically and
reboot everything should work fine. If it does not,
while following instructions on how to install it manually.
1. Copy the driver file GIVEIO.sys folder C: \ Windows \ system32 \ drivers \ unless
system you have installed on the C: drive and you did not change the installation path of Windows. Otherwise, the
installation folder Windows.
2. Run the file install.reg Here you will see something like the following message:
Press Yes. In this case, you get the message about the successful introduction of the information in the registry. One can
sure. The program of the registry editor regedit.exe in the branch
HKEY_LOCAL_MACHINE \ System \ CurrentControlSet \ Services \ giveio can see the following.
3. Reboot the computer.
4. BEGIN WORK
Program management.
Hotkeys:
R - Start
S - Stop
P - pause
Z - back to zero
SPACE - an emergency stop, but no buffer - it's like and «S» Stop
F5 - on / off manual control
In manual mode available
F1 - the movement to a minimum schag
F2 - move 0.5mm
F3 - 10mm movement
F4 - moving 100mm
Cursor - is moving coordinates
Left / Right - Channel 0, I have this X coordinate
Up / Down - Channel 1, Y
SHIFT + Left / SHIFT + right - channel 2, Z
SHIFT + top / SHIFT + down - Channel 3, A
V and then + / - Increase / decrease in the rate)
F12 - reset the position and set to zero.
The program can be linked to the expansion of the type «maz» and at start of the file,
gun control will be transferred to the "spider". In the folder with the executable
need to be on file atomic_p.ini. This allows us to
individual machine settings when starting from different folders.
Description of the configuration file atomic_p.ini
X-mm steps along the coordinate X
X_Vstart-speed (mm / min) with a coordinate can confidently and comfortably
start
X_Vforsag-maximum speed (mm / min) with a coordinate can confidently and
comfortably move
X_Time - the time (in milliseconds) for which coordinates accelerates
X_naprav - inverts coordinate. Example: 0 - normal 1-inversion.
GL_X_PORT_NUM - channel (0/1/2/3). Example 0 - use pin 2 and 3 LPT-
port for management coordinate.
Similarly for the Y / Z / A
The rest of the team has not yet touch.
Example atomic_p.ini in no-buffer:
Y = 31.25;
Z = 31.25;
X = 31.25;
A = 72.2222222222222222222222222222222222;
X_Vstart = 800;
X_Vforsag = 2000;
X_Time = 400;
Z_Vstart = 800;
Z_Vforsag = 2000;
Z_Time = 400;
Y_Vstart = 800;
Y_Vforsag = 2000;
Y_Time = 400;
A_Vstart = 600;
A_Vforsag = 1000;
A_Time = 300;
B_init = 3;
B_paused = 1000;
B_front = 0;
Step_invert = 0;
X_naprav = 0;
Y_naprav = 1;
Z_naprav = 1;
A_naprav = 0;
DEBUG_TICTAC = 0;
DEBUG_KADR = 0;
DEBUG_BASE = 0;
SPEED_KOEF = 1;
GL_X_PORT_NUM = 0;
GL_Y_PORT_NUM = 1;
GL_Z_PORT_NUM = 2;
GL_A_PORT_NUM = 3;
InfoFile = C: \ info.txt;
GL_PORT_BASA = 888; LPT port number
With version 4.3 (+ module Tarantula) may burn.
See below for description.
With version 4.4 + the free distribution of signals at DIR and STEP
pines LPT port
Standard, if you do not remap channels (teams GL_? _PORT_NUM = 0, PIN_? _DIR Or PIN_? _STEP) Connect pins LPT port of the computer, through
which is managed drivers stepper motors:
- Channel 0 (the default X coordinate): pin 2 direction, pin 3 step
- Channel 1 (default coordinate Y): pin 4 direction, pin 5 step
- Channel 2 (default coordinate Z): pin 6 direction, pin 7 step
- Channel 3 (default coordinate A): pin 8-way, pin 9 step
To reassign a file to add the following atomic_p.ini
control commands:
PIN_X_DIR = 00000001, and the signal will be sent to pin 9
PIN_X_STEP = 00000010;
PIN_Y_DIR = 00000100;
PIN_Y_STEP = 00001000;
PIN_Z_DIR = 00010000;
PIN_Z_STEP = 00100000;
PIN_A_DIR = 01000000;
PIN_A_STEP = 10000000, and the signal will be sent to pin 2
If we write PIN_X_DIR = 10000001, and the signal will be sent to pins 2 and 9
Attention!
1) if at least one team PIN_? _DIR Command group
GL_? _PORT_NUM - Off!
2) a set of commands? _naprav - Remains in force
With version 4.5 (+ module Woodpecker) can be processed drums.
With version 4.6 + free customizable management 4th outputs
LPT (1,14,16,17).
Adjusting the signal response is in the file atomic_p.ini. Let us consider the
Example feet 1 LPT:
PIN1 = 0,1,1,1,1,1,1,1,0;
Only 9 of values separated by commas.
Active Offline
Launch
Spider-4x
Start UP Pause Stop
Emergency
Stop
Movement
Close
Spider-4x
1 2 3 4 5 6 7 8 9
1/0 1/0 1/0 1/0 1/0 1/0 - 1/0
Meaning is as follows:
1) values from 3 to 9 is emerging in the program of the event. In them we can write 1 if
signal is active and 0 if the signal is inactive.
2) 1 and 2 is the signal itself! The first value is what signal is active.
The second meaning - it is inactive.
Now an example. Suppose we need to define Enable signal on the first
leg LPT.
His behavior is primitive:
1) When you run the Spider it will activate and stop being active when
off Spider. Hence the column from 3 to 8 is "1." Column 9 - is a "0."
2) Now it would be logical to write that "An active" (column 1) - is "1", and
Inactive (column 2) "0." However, the signals on the legs are 1,14,17
inverted. So what if you have a positive level Enable the team in
atomic_p.ini. would be:
If Enable is at a negative level:
PIN1 = 1,0,1,1,1,1,1,1,0;
Similarly describe the reactions of the other leg:
PIN14 = 1,0,1,1,1,1,1,1,0; PIN16 = 1,0,1,1,1,1,1,1,0;
PIN17 = 1,0,1,1,1,1,1,1,0;
In manual mode, you can activate and deactivate the signal status on legs
by pressing SHIFT +1 / +2 / +3 / +4.
Attention! The Spiders did not show the output level, namely
active / inactive!
Version 4.8 + extension module works Woodpecker (drums heads) after
failure.
When working with a shock head on power, you can continue
from any location!
To do this, go to the desired point and click Start (or "R").
SPIDER ask "Continue to work with the current position?". Click "Yes" and
continued ....
In addition to a file stored waste tictac.dat coordinates, it is in
folder with the processed image or a folder with a spider.
Thus it turns out that if there was a crash.
1) Exit the reference point (machine for any lost if power to the engines
was filmed.)
2) Zero The coordinates (F12).
3) Next, go to the point at which we wish to continue. Define it visually
or look at the last entry in tictac.dat and exit to these coordinates.
4) not resetting the coordinates, press START.
Note: the file can not be saved tictac.dat last point. This is a technical
feature writing to the hard drive. But recent data, will still be very
useful for reference.
Version 5.0.
There are two quality improvement:
1) Module "Tarantula" now distinguishes all 25,500 shades of gray. Began to burn
shades. Burning out mechanism operates much smoother.
2) the "Woodpecker" learned to pass the black fields on the edges of the image. For this
to add to the team atomic_p.ini EXPRESS = 1;
5. MODULE tarantula - ADVANCED
FOR BURNING
Spiderman 4 with module "Tarantula" is able to burn the image to a bitmap. For this
the image must be in the format bmp 256 colors. The program changes the speed
NC Burner is proportional gradation. The darker, the lower the rate.
The program believes that zero is the top left corner of the image and the "down" to
line down.
F_speed_01 = 350, black Speed in mm / min (or delay strike
100000 = 1 second)
F_speed_02 = 372;
F_speed_03 = 402;
F_speed_04 = 440;
F_speed_05 = 490;
F_speed_06 = 550;
F_speed_07 = 627;
F_speed_08 = 724;
F_speed_09 = 850; F_speed_10 = 1000;
F_speed_11 = 1200;
F_speed_12 = 1465;
F_speed_13 = 1800;
F_speed_14 = 2240;
F_speed_15 = 2820;
F_speed_16 = 4000 Speed White
F_z = 0; handling of one way back to the height Z
F_type = 0, 0-type processing in both directions / 1 - one strontium
F_dir = 0; machining direction during burning in one direction 0-from left to right / 1 -
from right to left
F_step = 0.5; Pixel pitch
Key_BMP = 0 Registration Key module "Tarantula"
Unregistered works with limited 100x100 pixels.
To register:
1) Run the processing bmp file, and the message will be a preliminary
key
2) Send a message to the mailbox with the subject info@x4axis.com registration and
after the pre-shared key format № D-xxxxxxxxxxxxxxxxx. If the body of the message
will thank you - I will be pleased .
3) During the day you will be sent a registration key, using
program for non-commercial purposes, it's FREE! Obsuzhdaemo else.
Attention! Key generates a manual mode! Pray with understanding to what
the key during the day.
Special thanks to Timur Askarov (tim_pro84@mail.ru). Formulate
technical problem, tested and identified errors. Took
part in what used to science had such a function.
Their experience and advice on what to consider when burning of the NC,
Timur set out in a separate article. Study it can be reached at
http://www.x4axis.com/info20111130.htm
6. MODULE woodpecker - ADVANCED
For drums
Spiderman 4 with module "Woodpecker" is able to burn the image to a bitmap. For this
the image must be in the format bmp 256 colors. The program, in proportion
gradations of color changes the force of impact. The darker, the less impact. Program
believes that zero is the top left corner of the image and the "down" line by line
down.
For this module the necessary commands:
1) Dendrocopos_pin = number of pins on the LPT, a signal blow, removing the signal shock.
2) MODULE = 1, To activate the module, "Woodpecker", with a value of "zero" or no
BMP-file command module runs tarantula (vyzhiganie!!)
EXAMPLE:
Dendrocopos_pin = 17, 0, 1;
MODULE = 1;
Available for the purpose and inverted feet 2-8,16 1,14,17.
It should be understood that the management will be the busiest on the leg 17 LPT. In view of the fact that this
signal is inverted, then the level of "0" is output corresponding to "1"!
If necessary, invert the signal ... = 17,1,0;
Attention! Make sure that the signal is not got used to control motors or
other devices! Attention! Also, if MODULE = 1, all the settings for the
"Tarantula (Burner)," become active for the module "Woodpecker"! see item 5 (MODULE
Tarantulas)
F_speed_01 = 350, Power Shot in black in arbitrary units (or delay strike
100000 = 1 second) depends on the design of the impactor
F_speed_02 = 372;
F_speed_03 = 402;
F_speed_04 = 440;
F_speed_05 = 490;
F_speed_06 = 550;
F_speed_07 = 627;
F_speed_08 = 724;
F_speed_09 = 850;
F_speed_10 = 1000;
F_speed_11 = 1200;
F_speed_12 = 1465;
F_speed_13 = 1800;
F_speed_14 = 2240;
F_speed_15 = 2820;
F_speed_16 = 4000 Power to strike white.
F_z = 0, while processing one way to return the height Z.
F_dir = 0; machining direction on one side 0-from left to right / 1 - with the right to
Left
MODULE = 1, the module switches from "Tarantula" on module "Woodpecker."
Dendrocopos_Key = 0 Registration Key module "Woodpecker"
To register:
key.
the key during the day. |
sisoski2 Član
Objavljeno: Sob Mar 16, 2013 7:59 pm Naslov sporočila: thx |
Hvala veliko, a dali ima neki drugi program da moze raditi nesto slicno kao Pauk?
hval jos jednom
