ST-LINK/2 -> STM32F103
markc
Pridružen-a: Čet 21 Feb 2008 18:02
Prispevkov: 77
Aktiv.: 0.36
Kraj: Dobropolje
PrispevekObjavljeno: Pet Feb 15, 2013 6:33 pm    Naslov sporočila:  ST-LINK/2 -> STM32F103 Odgovori s citatom
zanima me če je že kdo poizkušal "Eclipse + OpenOCD + ST-LINK/v2 + STM32f103" ?
Namreč... "sposodil" sem si ST-LINK/v2 debuger, ki ga ima DiscoveryF0.
Če uporabim nastavitve pri uporabi stm32f051, ki se nahaja na ploščici ni težav.
Koda:
# This is an STM32F0 discovery board with a single STM32F051R8T6 chip.
# http://www.st.com/internet/evalboard/product/253215.jsp
source [find interface/stlink-v2.cfg]
set WORKAREASIZE 0x2000
source [find target/stm32f0x_stlink.cfg]
# use hardware reset, connect under reset
reset_config srst_only srst_nogate
Odstranim "jumperje" da debuger postane samostojen, povežem SWD signale v ciljno napravo, ki je STM32f103, spremenim nastavitve,
Koda:
##file discoveryf0_vesna.cfg
# This is the config file for VESNA debugg and programin with OpenOCD
source [find ../interface/stlink-v2.cfg]
# Set work area in uC RAM to 20kB
# Load stm32 microcontroller specific settings
#transport init
source [find ../target/stm32f1x_stlink.cfg]
#transport select
zaženem....
Koda:
Open On-Chip Debugger 0.6.1 (2012-10-07-10:39)
Licensed under GNU GPL v2
For bug reports, read
   http://openocd.sourceforge.net/doc/doxygen/bugs.html
adapter speed: 1000 kHz
srst_only separate srst_nogate srst_open_drain
Info : clock speed 1000 kHz
Info : stm32f1x.cpu: hardware has 1 breakpoints, 0 watchpoints
Error: jtag status contains invalid mode value - communication failure
TARGET: stm32f1x.cpu - Not halted
Think
Je že kdo poizkušal kaj podobnega?
Mare
mujo
Prispevkov: 746
Aktiv.: 3.14
Kraj: MB
PrispevekObjavljeno: Pet Feb 15, 2013 10:14 pm    Naslov sporočila:   Odgovori s citatom
Jaz sem z uporabo st-link utility in preko iar ewarm brez kakršnih koli komplikacij uspel preko različnih discovery boardov (F4, VL, L) programiral vezje povezano preko SWD povezve.
Kako si nastavil BOOT pine?
markc
Prispevkov: 77
Aktiv.: 0.36
Kraj: Dobropolje
PrispevekObjavljeno: Ned Feb 17, 2013 4:40 pm    Naslov sporočila:   Odgovori s citatom
Hvala za odgovor!
BOOT pine? uh.... Boot1/PB2 je preko 1M Omega vezan proti GND ter BOOT0 vezan na reset vezje. Vezje deluje tako, da če držim tipko reset več kot 3 s se mikrokrmilnik postavi v stanje USART bootloaderja.
Platformo brez težav programiram z JTAG-om, le SWD ne deluje.
BOOT pini igrajo kakšno drugačno vlogo če programiram z JTAG ali SWD?
Na osciloskopu sem videl, da ST-LINK naredi pravilno sekvenco, da mikrokrmilnik postavi v stanje za programiranje z SWD!
Ni mi jasno naslednje:
Koda:
Na ST-LINK-u sem ven peljal le SWDIO in SWDCLK ter GND da sem vezji izenačil v potencjalu. Bi moral uporabiti tudi reset pin? Kolikor sem opazoval na osciloskopu ga ST-LINK pri programiranju niti ne uporablja.
Bi mi lahko prosim posredoval kako skripto, kako imaš nastastavljen debuger?
Mare
mujo
Prispevkov: 746
Aktiv.: 3.14
Kraj: MB
PrispevekObjavljeno: Ned Feb 17, 2013 5:21 pm    Naslov sporočila:   Odgovori s citatom
Z BOOT določiš od kot se naj program zažene - iz flash memory, iz system memory ali z sram-a.
Torej v "navadnem načinu" se program naloži iz flash memory, ko pa držiš tipko reset pa iz system memory kjer je vgrajen bootloader.
Kolikor vem boot pini ne igrajo vloge pri JTAG oz SWD.
Za reset povezavo nisem prepričan - sam sem ga imel priklopljenega, ampak ko se mi je povezava izmaknila sem vezje še vedno lahko programiral. Naprej nisem šel raziskovat.
GPIO za SWD imaš pravilno nastavljene (alternate function)?
Skripte nimam nobene - programiram direktno iz IAR EWARM - z default nastavitvami.
markc
Prispevkov: 77
Aktiv.: 0.36
Kraj: Dobropolje
PrispevekObjavljeno: Ned Feb 17, 2013 6:57 pm    Naslov sporočila:   Odgovori s citatom
mujo je napisal/a:
Shocked želiš povedati da bi moral najprej preko JTAG naložit program, ki nastavi GPIO na SWD ??
Se to ne zgodi v začetni sekvenci ko debuger dostopa do kontrolerja? Anxious
mujo
Prispevkov: 746
Aktiv.: 3.14
Kraj: MB
PrispevekObjavljeno: Pon Feb 18, 2013 11:15 am    Naslov sporočila:   Odgovori s citatom
Samo sprašujem - da vidim kaj imaš različno kot jaz.
Sem preveril v datasheetu - JTAG pini so po resetu v input stanju - tako da to verjetno ni problem.
Sem ravnokar probal programirati stm32l152 preko programatorja na discovery-F4 plati in dela z samo priklopljenimi GND, SWCLK, SWDIO.
Si probal z katerim drugim orodjem za programiranje? Da izločiš problem na softweru za programiranje?
markc
Prispevkov: 77
Aktiv.: 0.36
Kraj: Dobropolje
PrispevekObjavljeno: Pon Feb 18, 2013 4:57 pm    Naslov sporočila:   Odgovori s citatom
Uhhh... REŠENO!
Brick wall
V dokumentaciji piše da po resetu SWDIO pinu priklopi interni pull-up SWCLK pa pull-down. Piše tudi, da standard za JTAG priporoča pinom zunanje 100k pull-up upore. To je izvedeno na platformi, ki jo uporabljam z izjemo SWDCLK. Čisto iz obupa sem dodal 100k proti masi in procesor je postal berljiv.
Prilagam še skripto če se bo kdo želel poigrat z OCD-jem:
Koda:
telnet_port 4444
gdb_port 3333
tcl_port 6666
init
reset init
p.s. Ne garantiram da je popolna! Če kdo bolje pozna OpenOCD naj se počuti popolnoma domače in deli svoje znanje Smile
Mujo HVALA za trud in predloge! sbeer
mujo
Prispevkov: 746
Aktiv.: 3.14
Kraj: MB
PrispevekObjavljeno: Pon Feb 18, 2013 9:57 pm    Naslov sporočila:   Odgovori s citatom
Huh zanimivo - sam nimam nobenih dodatnih uporov. Si pa velja zapomniti v kolikor se bo začelo kaj čudno obnašati.
Uptime: 5 dni
