WindowsXP
Prispevkov: 16777193
Aktiv.: 70647.46
PrispevekObjavljeno: Sre Mar 29, 2006 2:13 pm    Naslov sporočila:  WindowsXP Odgovori s citatom
jur
Prispevkov: 5142
Aktiv.: 21.65
PrispevekObjavljeno: Sre Mar 29, 2006 4:12 pm    Naslov sporočila:   Odgovori s citatom
Office XP
To disable Error Reporting in Office XP (on any version of Windows), use the Registry script below. Double clicking on a .REG file runs Regedit and makes the changes in the file. The script disables Error Reporting for the current user only, and so must be run by each user of a system. (New users created after the script is run will have the changes made for them, and do not need to re-run the script.)
Registry Script UnWatsonXP.reg
REGEDIT4
[HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\10.0\Common]
"DWNeverUpload"=dword:00000001
"DWNoExternalURL"=dword:00000001
"DWNoFileCollection"=dword:00000001
"DWNoSecondLevelCollection"=dword:00000001
[HKEY_USERS\.Default\Software\Policies\Microsoft\Office\10.0\Common]
Only administrators have access to the Registry. If you receive an error when trying to run this script, contact your administrator or local support group.
RGorazd
Prispevkov: 1715
Aktiv.: 7.22
Kraj: Ig
PrispevekObjavljeno: Sre Mar 29, 2006 4:14 pm    Naslov sporočila:   Odgovori s citatom
Desni klik na MyComputer, potem klikneš advanced in odspodaj imaš Error reporting. Klikneš in daš disable. That's all folks Smile
LP GOrazd
._. _ _ ._. _.__. _|
[ (_](_)[ (_] /_(_]
._|
Aktiv.: 70647.46
PrispevekObjavljeno: Sre Mar 29, 2006 4:26 pm    Naslov sporočila:   Odgovori s citatom
Highlag
Prispevkov: 4034
Aktiv.: 16.99
Kraj: Črnuče
PrispevekObjavljeno: Sre Mar 29, 2006 5:28 pm    Naslov sporočila:   Odgovori s citatom
A ni celo v tistem okencu neka kljukica za to?
reber
Prispevkov: 2279
Aktiv.: 9.60
Kraj: Bled
PrispevekObjavljeno: Sre Mar 29, 2006 5:45 pm    Naslov sporočila:   Odgovori s citatom
Poročila o napakah gredo tudi meni na živce, tako da sem kar takoj preizkusil gorazdov predlog, le malce sem se moral potruditi, ker imam slo pack, da sem našel
oversc0re
Pridružen-a: Tor 13 Sep 2005 15:20
Prispevkov: 460
Aktiv.: 1.94
Kraj: Radomlje
PrispevekObjavljeno: Čet Mar 30, 2006 6:21 pm    Naslov sporočila:   Odgovori s citatom
The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' but 'That's funny ...'
Isaac Asimov (1920 - 1992)
jur
Prispevkov: 5142
Aktiv.: 21.65
PrispevekObjavljeno: Čet Mar 30, 2006 6:38 pm    Naslov sporočila:   Odgovori s citatom
Bljak pa slovenski windowsi.
Če ima še kdo težave z slovenskimi nastavitvami windowsa (odklop error reporta):
Klikniti je potrebno z desno tipko miši na Moj računalnik (ne sme biti shortcut).
Klikniti je potrebno na Lastnosti
Klikniti je potrebno na Dodatno
Klikniti je potrebno na Poročanje o napakah
Izbrati je potrebno Onemogoči poročanje o napakah.
Klikniti je potrebno V redu
robertos
Prispevkov: 792
Aktiv.: 3.34
Kraj: Vuhred JN76OO
PrispevekObjavljeno: Čet Mar 30, 2006 9:42 pm    Naslov sporočila:   Odgovori s citatom
Vse lepo in prav samo napake se še vedno pojavljajo, kako pa te odpravit?
Pri meni večkrat, ko želim odpret *.avi datoteko z Bsplayer-jem zašteka eksplorer (windows okno) ali pa sam Bs Player. Včasih je celo dovolj, da samo kliknem na film s končnico avi. Potem se seveda pokaže poročilo, ki vsebuje tudi podatke. Zanima me ali je kdo razvozlal, kako razbrati iz tega poročila, kaj je šlo narobe, da se napaka odpravi v korenu. Saj praktično nič ne pomaga izklop sporočila, če pa še vedno "šteka". Ko sem sam popolnoma izključil sporočanje je bilo še slabše, win. je poplnoma zaštekal, pa je pomagal samo ctrl+shift+esc. Zato sem moral nazaj vklopit prikaz napake, vendar brez, da me sprašuje, če pošljem Microsoftu. Še enkrat vprašanje, kako odpravit napako v osnovi?
Cheerio baj frm S58S Robert !
http://www.kapunar.eu
Iztok
Prispevkov: 4974
Aktiv.: 20.95
PrispevekObjavljeno: Čet Mar 30, 2006 9:43 pm    Naslov sporočila:   Odgovori s citatom
Ker je @borisz že dobil konkreten odgovor bi v zvezi XPjev imel tudi jaz eno vprašanje: Kje se v XPjih nastavi default fonte?
Zadnjih nekaj dni se mi po odpiranju nekaterih programov (npr. MPLAB ali WSCAD) v njih pojavijo Arial fonti namesto običajni Courier New fonti. Confused
V MPLABu je to malo moteče, ker so TAB presledki precej manjši, huje pa je v programu WSCAD, ki se kar "obesi" in mi javlja sporočilo "The font is not available for the current output device".
V mapi C:\WINDOWS\FONTS so vsi fonti kot na drugem računalniku kjer vse deluje normalno ... se pravi so tudi instalirani v sistem.
Zanima me kaj bi bil lahko vzrok, ker nisem ničesar spreminjal (niti nastavitev grafike)? Kje bi torej lahko nastavil fonte, ki jih uporablja npr. MPLAB?
P.S. Na netu sem našel le nekaj nepreciznih odgovorv s katerimi si nisem mogel prav nič pomagati.
Sokrat
Prispevkov: 5584
Aktiv.: 23.51
PrispevekObjavljeno: Čet Mar 30, 2006 10:05 pm    Naslov sporočila:   Odgovori s citatom
Nastavijo se pod Display Settings, do katerih lahko prides na vec nacinov (en je Display v Control Panelu). Klikni na Appearance | Advanced, tam pa na vsako individualno stvar, ki jo zelis anstaviti (npr. naslovno vrstico, meni, itd.).
NeoTO
Prispevkov: 2752
Aktiv.: 11.59
Kraj: Trzic
PrispevekObjavljeno: Čet Mar 30, 2006 10:26 pm    Naslov sporočila:   Odgovori s citatom
robertos, zgleda si namestil codec-e, ki se ne 'marajo'. Pogosta napaka ob hkratnem nalaganju več med seboj ne čisto kompatibilnih codec-ov!
Rešitev: odstrani vse codece (Control Panel>Add and Remove programs), potem pa na novo namesti samo tiste, ki jih potrebuješ oz. še bolje, da namestiš kakšen codec pack, v katerem so pravi codec-i že skupaj zbrani.
Highlag
Prispevkov: 4034
Aktiv.: 16.99
Kraj: Črnuče
PrispevekObjavljeno: Čet Mar 30, 2006 10:33 pm    Naslov sporočila:   Odgovori s citatom
Za WSCAD ne vem, pri MPLAB-u pa lahko črke zamenjaš znotraj programa. Okna skrbijo samo za črke, ki so prikazana v naslovu okenc (drag-bar-u), ki se odprejo v MPLAB-u. Ostale lahko nastaviš kakor ti paše.
Sam ima tako nastavljene za pomožna orodja manjše črke, da so okenca lahko manjša, okno z kodo pa ima večje. Sam sem pa vse zamenjal z Tahomo, ker mi najbolj ustreza. Enostavno klikneš na okno katerega tip ali velikost črk misliš zamenjati (na besedilo) z desno tipko, izbereš Properties in v okencu nastaviš željeno.
Pri tebi bi bilo možno, da se je datoteka z privzetimi črkami poškodovala, ker praviš, da imata kar dva programa "enake" simptome.
Iztok
Prispevkov: 4974
Aktiv.: 20.95
PrispevekObjavljeno: Pet Mar 31, 2006 1:05 am    Naslov sporočila:   Odgovori s citatom
Sokrat je napisal/a:
V meniju, ki si ga opisal, se nastavlja samo fonte na vrhu oken ... vse imam na default. Mislil sem, da je kje obstaja kakšen drug menu kjer se nastavi "sistemske fonte" ... npr. kakšen Language bar ipd.
Zadevo sem rešil s staro in preizkušeno metodo ... reinstal programa. Sedaj spet deluje BP! Smile :lasko:
Highlag je napisal/a:
Jaz pa sem preiskal že vse zgornje "zavesne" menije MPLABa in nisem pomislil na desni-klik Brick wall
Seveda deluje in tudi meni je Tahoma za ta namen najbolj všeč. Hvala!
