Attiny45 - problem branja dveh ADC-jev
jozzze2000
Pridružen-a: Pet 25 Nov 2011 8:36
Prispevkov: 167
Aktiv.: 1.01
Kraj: Novo mesto
PrispevekObjavljeno: Čet Mar 31, 2016 3:24 pm    Naslov sporočila:  Attiny45 - problem branja dveh ADC-jev Odgovori s citatom
Poizkušam uporabiti Attiny45 za branje dveh ADC-jev. Če berem ločeno vsakega posebej (torej enega v kodi ne uporabim) oba delujeta kot pričakovano.
V kombinaciji, ko potrebujem branje obeh, se branje enega ne izvede (v tem primeru ADC1 - Funkcija "BranjeVolt1").
Mi lahko kdo pomaga rešiti uganko?
Spodaj je relevantna koda:
Koda:
#define F_CPU 8000000UL
volatile float voltage_on_bit1, before_adcl1, voltage_on_bit2, before_adcl2, ocr_value;
void PortInit(void)
       DDRB  = 0b00000001; // 1 -> output port;   //  0 -> input port
       PORTB = 0b00001000; // pull-up
void ADC_init(void)
         ADMUX =
         (1 << ADLAR) |     // left shift result
         (0 << REFS1) |     // Sets ref. voltage to VCC, bit 1
         (0 << REFS0) |     // Sets ref. voltage to VCC, bit 0
         (0 << MUX3)  |     // use ADC2 for input (PB4), MUX bit 3
         (0 << MUX2)  |     // use ADC2 for input (PB4), MUX bit 2
         (1 << MUX1)  |     // use ADC2 for input (PB4), MUX bit 1
         (0 << MUX0);       // use ADC2 for input (PB4), MUX bit 0
         ADCSRA =
         (1 << ADEN)  |     // Enable ADC
         (1 << ADPS2) |     // set prescaler to 64, bit 2
         (1 << ADPS1) |     // set prescaler to 12864, bit 1
         (1 << ADPS0);      // set prescaler to 12864, bit 0
         ADCSRA |= (1 << ADSC);  // Start  A2D Conversions
void BranjeVolt1(void)            // ADC1
       ADMUX=1;                   // Set  to ADC1
       _delay_ms(30);
       while(!(ADCSRA & 0x10)); // wait for it
       before_adcl1 = ADCL;
       voltage_on_bit1 = ((ADCH * 0xff) + before_adcl1)/204.8;
       ocr_value = 20 * voltage_on_bit1;
void BranjeVolt2(void)            // ADC2
       ADMUX=2;                   // Set  to ADC2
       _delay_ms(30);
       before_adcl2 = ADCL;
       voltage_on_bit2 = 6*((ADCH * 0xff) + before_adcl2)/204.8;          //*6 zaradi delilnika na vhodu.
int main(void)
       PortInit();
       ADC_init();
       PWM_Init();
       stevec = stevec_start;
       plus = 0;
       while (1)
             BranjeVolt2();
             _delay_us(50);
             if (voltage_on_bit2 < 10)
                    FMH();
             else if (voltage_on_bit2<13)
                    if (bit_is_clear (PINB, 3))
                           OCR0A = 190;
                    else
                           OCR0A = 0;
             else
                           OCR0A = 190;
                    else
                           /*   TA KODA NORMALNO DELUJE IN UTRIPA, KO SO IZPOLNJENI POGOJI
                           OCR0A=250;
                           _delay_ms(200);
                           OCR0A=0;
                           _delay_ms(100);
                           BranjeVolt1();
                           OCR0A = ocr_value;
                           _delay_us(30);
