Napaka na pomivalnem stroju Bosch (e09)
peternilsson
Pridružen-a: Sre 14 Dec 2022 4:04
Prispevkov: 1
Aktiv.: 0.03
PrispevekObjavljeno: Sre Dec 14, 2022 4:14 am    Naslov sporočila:  Napaka na pomivalnem stroju Bosch (e09) Odgovori s citatom
Best Features of Shark Apex Uplight Lift-Away Duoclean Vacuum Cleaner
The Shark apex uplight lift-away duoclean is one of the best vacuum cleaners in the market this year. This vacuum has the best of both worlds – powerful as a full-sized upright vacuum but lightweight and slim as a stick vacuum. So if you're looking for the right vacuum for your cleaning needs, you can consider purchasing a Shark apex uplight.
Product Specifications - Shark Apex Uplight Duoclean
Type: Upright/Stick vacuum
Weight: 10.7 lbs
Product dimensions: 11.38 x 46.9 x 10.4 inches
HEPA filter: Yes
Anti-Allergen complete seal: Yes
Self-Cleaning brush roll: Yes
Power cord length: 30 ft
Dust capacity: 0.68 dry quarts
LED headlights: On floor nozzle
Duoclean technology: yes
Lift-Away: Yes
Warranty: limited five-year period
Attachments: A crevice-duster tool, a pet multi-tool, and an accessory holder
User Ratings
The Shark apex uplight lift-away duoclean received multiple positive feedbacks from users all around the world. This model has 1,111 5-star global ratings, with an average of 4.5 out of 5-star ratings. Most users are happy that they can finally replace their old bulky upright vacuum with the Shark uplight. In addition, owners praised that the vacuum provides exceptional cleaning performance on all types of floorings: bare floors, carpeted floors, area rugs, and tiles.
Best Features Of The Shark Apex Uplight Vacuum
For More Information:
TheKingLive
Outstanding features of the Shark APEX AZ1002
  • Impressive Suction Power
The Shark uplight vacuum includes Shark's Hyper Velocity technology, which means the machine never loses the suction. In addition, the accelerated motor allows the Shark uplight to pick up dirt and debris on the floors with ease.
  • Lift-Away Pod
You can use the Shark apex uplight lift-away duoclean as both the upright/stick vacuum and the handheld cleaning device. The detachable pod allows you to carry the Shark uplight vacuum in one hand and clean above-flooring spaces such as stairs, drapes, furniture, and car interiors. Our favorite thing about this vacuum is using the extendable hose to reach even higher ground, such as the ceiling fans.
  • HEPA Filter and Anti-Allergen Complete Seal Technology
The HEPA filtration and anti-allergen seal system can trap up to 99.97 percent of dust and particles inside the main unit. These features are often available in premium, top-of-the-line products, but you can get the same protective measures in the Shark uplight at a more affordable price. If you or your family have asthma or any other respiratory conditions, we highly suggest that you pick the vacuum with a HEPA filter and sealed system.
  • DuoClean Technology
The duoclean technology features two different brush rolls to help you clean more dust and particles in your home. The bristled brush can perform carpet deep cleaning tasks, while the extra soft microfiber brush can pick up dust on hardwood and bare floors without damaging the surfaces. Now you can switch between different floor types without spending more money on a second vacuum.
  • LED headlights
The Shark apex uplight corded lift away includes one of the most powerful LED lights to help users clean in dark areas.
Final words
If you're looking for a super lightweight but powerful vacuum in 2024, the Shark apex uplight duoclean might be your best choice. Let us know if you have any further questions about the product.
Nazadnje urejal/a peternilsson Tor Feb 06, 2024 5:23 am; skupaj popravljeno 4 krat
cici
Prispevkov: 766
Aktiv.: 3.23
Kraj: Trbovlje
PrispevekObjavljeno: Sre Dec 14, 2022 6:38 am    Naslov sporočila:   Odgovori s citatom
Tu je opis postopka v primeru E09.
Srecko
Prispevkov: 1014
Aktiv.: 4.27
Kraj: Okolica Cerkna
PrispevekObjavljeno: Sre Dec 14, 2022 7:37 pm    Naslov sporočila:   Odgovori s citatom
Ta napaka se pojavi ko je nekaj narobe z gretjem kot ti je dal link @cici. Nič nisi napisal kateri tip stroja je ali je starejši ali mjajši, novejši. Lahko je marsikaj, če je grelec in je stroj novejši bo popravilo kar drago ker ima grelec integriran v motor obtočne črpalke in se to zamenja vse skupaj. Lahko je kaj z ožičenjem, kakšna prekinitev v zglobu vrat, lahko slab rele za grelec ali pa premala napetost za rele. Lahko je temperaturno tipalo. Very Happy
LP Srečko
Samouk
Tukaj sem doma
Uptime: 4 dni
