Pridružen-a: Ned 19 Sep 2004 22:04 Prispevkov: 16777193 Aktiv.: 70642.29
Objavljeno: Tor Nov 28, 2006 9:20 am Naslov sporočila: Zamenjava ikone |
jur Član
Objavljeno: Tor Nov 28, 2006 9:35 am Naslov sporočila: |
Narediš shortcut na disk. Desni klik na shortcut> lastnosti>zamenjaj ikono in zamenjaj ikono.
Jur |
Objavljeno: Tor Nov 28, 2006 9:41 am Naslov sporočila: |
bungee Član
Pridružen-a: Pon 07 Mar 2005 18:49 Prispevkov: 1479 Aktiv.: 6.23 Kraj: Ljubljana
Objavljeno: Tor Nov 28, 2006 11:30 am Naslov sporočila: |
Sem najprej mislil da pomaga TweakUI, pa sem se zmotil. To kar hočeš narediti se naredi takole:
To change the icon displayed within explorer for a drive requires changes to the windows registry.
1. Create (if it does not already exist) the registry key:
HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ Explorer\ DriveIcons\ X\ DefaultIcon
where 'X' is the drive letter of the drive for which you wish to change the drive icon.
2. Change the key's default value to hold the fully qualified name of the icon file (e.g. 'c:\myicons\cdrive.ico').
If the file contains more than one icon then follow it with a comma and the zero-based index of the icon (e.g. 'c:\myicons\mylib.dll,2').
3. To see the affect restart windows - although, depending on the version of windows simply refreshing the window might be sufficient.
From Windows 2000 onwards it is also possible to change the default label shown for each drive.
1. Navigate to (or create):
HKEY_LOCAL_MACHINE\ SOFTWARE\Microsoft\ Windows\CurrentVersion \Explorer\ DriveIcons\ X\ DefaultLabel
where 'X' is the drive letter of the drive for which you wish to change the label.
2. Change the key's default value to hold the required label.
P.S.: To je urejanje registra in za posledice napačnega urejanja ne odgovarjam  |
jur Član
Objavljeno: Tor Nov 28, 2006 3:08 pm Naslov sporočila: |
Kot sem rekel, najenostavneje in najvarneje je popraviti shortcut.
Jur |
